Another update--the routine seems to be fairly consistent. I haven't had to manually correct the blinds' position in quite some time.
I figured out how to fix the reset problem. One night, I found my blinds trying to close at 1 AM or so, when they had already closed at 11 PM as usual. This explains the problem I was having where I found the blinds double-closed, which had cropped up a few times. I fixed this by adding a boolean "closed" to my program. This boolean gets set to "false" when the blinds close at 11 PM , and to "true" when they open. Not only that--the scheduled "close" and "open" routines are only run if the boolean is what would be expected. So, no more double-closing in the middle of the night.
Here's my current code.
Making a continuous-rotation servo perform certain routines
at certain times of day
David Garrett, david.j.garrett@live.com
Notes:
My servo stops at value 95, not value 90 (Parallax continuous rotation servo, 2014)
Any value less than ~85 or greater than ~105 seem to be equivalent
--this is when the servo is unloaded mechanically,
haven't tested it loaded
Writing speed > 95 gives counterclockwise motion.
Writing speed < 95 gives clockwise motion.
^^^These are when looking at the arm's "face".
My Wiring:
green = ground
yellow = 5V
Orange = signal
From neutral (blinds level and open,) turn servo clockwise 5 times
to close blinds.
From there, turn counterclockwise 5 times to open them.
When open, the blinds are horizontal, level.
When closed in the correct direction, the proximal edge goes down.
#include <Servo.h>
#include <Time.h>
Servo myservo; // create servo object to control a servo
// Write values from 0 to 179 to the servo. 95 means
// stop. 179 is full speed ahead. 0 is full speed
// backwards.
long openTime = 15625 * 10.0/4 ; // How many milliseconds it takes to open my blinds
long closeTime = 10578 * 9.5/4 ; // How many milliseconds it takes to close my blinds
long incrementTime = openTime * (3.4/50) ; // A smaller chunk of time -- useful for making the blinds open over a longer
// time period
boolean closed = false; // Answers the question, "The blinds are currently closed--true or false?"
// Change to "true" if they're starting out closed
Serial.begin(9600); // Allows for serial monitoring during potential troubleshooting
myservo.attach(9); // attaches the servo on pin 9 to the servo object
setTime(11,05,0,3,6,14); // Hour, minute, second, day, month, year.
// (Change these numbers to reflect whatever time and date
// it is when you plug the Arduino in.)
// myservo.write(93); // Use these two lines to make sure the blinds start in the right position based on
// delay(openTime); // what time it is when you boot the Arduino (plug it in or reset it.)
myservo.write(95); // Tell the servo to hold still
//Useful for quick-ish testing:
if ( hour()==12 && minute()==00 && second()==03) {
for (int j = 1; j<6; j++){
//Test close direction:
myservo.write(97);
delay(closeTime);
//myservo.write(95);
//delay(100);
//wait for 2 seconds:
myservo.write(95);
delay(2000);
//Test open direction.
//Open 2/5 of the way:
myservo.write(93);
delay(2*openTime/5);
//Then pause:
myservo.write(95);
delay(300);
//Then open 3/50 of the way 10 times in a row, with pauses
// in between, making 3/5 taken together and 5/5 of the way
// all in all.
for (int i=1; i<11; i++){
myservo.write(93);
delay(incrementTime);
myservo.write(95);
delay(300);
myservo.write(95); //and stop.
Serial.println("End loop");
delay(2000);
//FINAL CODE TO IMPLEMENT
//OPEN the blinds at 9:45 am, if the blinds are currently closed:
if (hour()==9 && minute()==45 && second()==0 && closed) {
myservo.write(93);
//Then pause:
myservo.write(95);
delay(300);
// all in all.
myservo.write(93);
delay(incrementTime); //Open 3/50 of the way
myservo.write(95);
delay(90000); //Pause in between
myservo.write(95); //and stop, wait for closing time.
closed = false;
//CLOSE the blinds at 10 PM:
if (hour()==22 && minute()==0 && second()==0 && !closed) {
myservo.write(97);
delay(closeTime);
closed = true;
I bought an HC-06 bluetooth module from fastTech.com, which came with a convenient set of 6 attached jumper cables for its 6 pins. I learned from this video ( - YouTube ) that I need to use a few resistors between the Arduino and the HC-06's RX ports to reduce the voltage so I don't fry the HC-06. That means I need a board to make a simple circuit on. I would like that board to fit in my enclosure.
I went to Radio Shack and bought a Proto Shield by Seeed Studio. I hoped it would provide the circuit-place I needed while also stacking on top of the Arduino nicely. Unfortunately, it doesn't fit within the enclosure in its current state. It's too wide. I may find a way to shave the side of it off so it will fit in. If I do end up being able to use it, I'll still need to do some soldering using my school's equipment. Bit of a hassle. Maybe I should just get
In the meantime, I need to figure out the code. I'll need to teach the Arduino to get info from the HC-06, and I'll need to teach my tablet to send info via Bluetooth to the HC-06.
