I have been working on my most ambitious arduino project for about a week now. The project is a home radar and defense system, and uses multiple continuous servos to move around and target, along with rotate the radar ultrasonic sensor. I've been testing it with Tinkercad circuits and Wokwi, and it worked perfectly. But when I got out my old giga R1, the right drive servo wouldn't stop spinning. I tried troubleshooting with AI and help from my teacher, but to no avail. Help!
/// HOME A.D.S - AIR DEFENSE SYSTEM ///
#include <Servo.h>
// Pins
const int JOY_X_PIN = A0;
const int JOY_Y_PIN = A1;
const int JOY_SW_PIN = 26;
const int PIR_PIN = 22;
const int TRIG_PIN = 24;
const int ECHO_PIN = 25;
const int LEFT_DRIVE_SERVO_PIN = 6;
const int RIGHT_DRIVE_SERVO_PIN = 7;
const int TOP_SERVO_PIN = 8;
const int SCAN_SERVO_PIN = 9;
// RGB LED pins
const int RGB_RED_PIN = 30;
const int RGB_GREEN_PIN = 31;
const int RGB_BLUE_PIN = 32;
// Servo objects
Servo leftDriveServo;
Servo rightDriveServo;
Servo topServo;
Servo scanServo;
// Separate stop values
const int LEFT_DRIVE_STOP = 90;
const int RIGHT_DRIVE_STOP = 94;
const int TOP_SERVO_STOP = 90;
// Drive ranges
const int DRIVE_OFFSET_MIN = -30;
const int DRIVE_OFFSET_MAX = 30;
const int JOYSTICK_DEADZONE = 3;
// Top servo offsets
const int TOP_CW_OFFSET = 25;
const int TOP_CCW_OFFSET = -25;
// Scan servo settings
const int SCAN_START_POS = 10;
const int SCAN_MIN = 10;
const int SCAN_MAX = 170;
// Reverse options
const bool REVERSE_LEFT_DRIVE = false;
const bool REVERSE_RIGHT_DRIVE = true;
const bool REVERSE_TOP_SERVO = false;
// Current commands
int leftDriveCmd = LEFT_DRIVE_STOP;
int rightDriveCmd = RIGHT_DRIVE_STOP;
// Top state
int topState = 0; // 0 = front, 180 = back
int topTargetState = 0;
bool topTurning = false;
unsigned long topTurnStartTime = 0;
unsigned long TOP_TURN_TIME_MS = 900;
// Top output tracking
int topTurnOutputCmd = TOP_SERVO_STOP;
// Scan state
int scanPos = SCAN_START_POS;
bool scanForward = true;
// Keyboard override
bool keyboardMode = false;
int kbMove = 0;
int kbTurn = 0;
// Alert settings
const int DETECTION_DISTANCE_CM = 60;
unsigned long ACTION_COOLDOWN_MS = 5000;
unsigned long lastActionTime = 0;
unsigned long ALERT_HOLD_MS = 1200;
unsigned long alertHoldUntil = 0;
// Timers
unsigned long lastScanUpdate = 0;
unsigned long lastRadarSend = 0;
unsigned long lastDistanceRead = 0;
unsigned long lastJoyButtonTime = 0;
// Timing values
const unsigned long SCAN_INTERVAL_MS = 15;
const unsigned long RADAR_SEND_INTERVAL_MS = 35;
const unsigned long DISTANCE_READ_INTERVAL_MS = 40;
const unsigned long BUTTON_DEBOUNCE_MS = 250;
// Distance cache
long lastDistance = -1;
// Alert flash state machine
bool alertActive = false;
bool alertLedOn = false;
int alertToggleCount = 0;
int alertTargetToggles = 0;
unsigned long alertLastChange = 0;
unsigned long alertOnTime = 150;
unsigned long alertOffTime = 150;
// Helper functions
int clampValue(int value, int minVal, int maxVal) {
if (value < minVal) {
return minVal;
} else if (value > maxVal) {
return maxVal;
return value;
int applyContinuousCommand(int stopValue, int offsetValue, bool reversed) {
int cmd;
if (reversed) {
cmd = stopValue - offsetValue;
cmd = stopValue + offsetValue;
return clampValue(cmd, 0, 180);
// RGB LED helpers
void setRGB(bool redOn, bool greenOn, bool blueOn) {
digitalWrite(RGB_RED_PIN, redOn ? HIGH : LOW);
digitalWrite(RGB_GREEN_PIN, greenOn ? HIGH : LOW);
digitalWrite(RGB_BLUE_PIN, blueOn ? HIGH : LOW);
void startRedAlert(int times, unsigned long onTime, unsigned long offTime) {
alertActive = true;
alertLedOn = false;
alertTargetToggles = times * 2;
alertLastChange = millis();
alertOnTime = onTime;
alertOffTime = offTime;
setRGB(false, false, false);
void updateAlertFlash() {
if (!alertActive) {
return;
unsigned long now = millis();
unsigned long interval = alertLedOn ? alertOnTime : alertOffTime;
if (now - alertLastChange >= interval) {
alertLastChange = now;
alertLedOn = !alertLedOn;
alertToggleCount++;
if (alertLedOn) {
setRGB(true, false, false);
if (alertToggleCount >= alertTargetToggles) {
alertLedOn = false;
// Top control
void stopTopServo() {
topTurnOutputCmd = applyContinuousCommand(TOP_SERVO_STOP, 0, REVERSE_TOP_SERVO);
topServo.write(topTurnOutputCmd);
topTurning = false;
void startTopTurnToState(int newTargetState) {
if (topTurning) {
return;
if (newTargetState == topState) {
return;
topTargetState = newTargetState;
int offset = 0;
if (newTargetState == 180) {
offset = TOP_CW_OFFSET;
offset = TOP_CCW_OFFSET;
topTurnOutputCmd = applyContinuousCommand(TOP_SERVO_STOP, offset, REVERSE_TOP_SERVO);
topTurnStartTime = millis();
topTurning = true;
void updateTopTurn() {
if (!topTurning) {
return;
if (now - topTurnStartTime >= TOP_TURN_TIME_MS) {
stopTopServo();
topState = topTargetState;
void zeroTopState() {
stopTopServo();
topState = 0;
topTargetState = 0;
// Serial command handling
// Commands:
// KB,move,turn
// KBMODE,0
// KBMODE,1
// ALERT
// ZERO
void handleSerialLine(String line) {
line.trim();
if (line.length() == 0) {
return;
if (line.startsWith("KBMODE,")) {
int mode = line.substring(7).toInt();
if (mode == 1) {
keyboardMode = true;
kbMove = 0;
kbTurn = 0;
} else if (line.startsWith("KB,")) {
int firstComma = line.indexOf(',');
int secondComma = line.indexOf(',', firstComma + 1);
if (firstComma >= 0 && secondComma > firstComma) {
kbMove = clampValue(line.substring(firstComma + 1, secondComma).toInt(), -30, 30);
kbTurn = clampValue(line.substring(secondComma + 1).toInt(), -30, 30);
} else if (line == "ALERT") {
startRedAlert(4, 150, 150);
} else if (line == "ZERO") {
zeroTopState();
void readSerialCommands() {
while (Serial.available()) {
String line = Serial.readStringUntil('\n');
handleSerialLine(line);
// Drive control
void updateDrive() {
int moveValue = 0;
int turnValue = 0;
if (keyboardMode) {
moveValue = kbMove;
turnValue = kbTurn;
int xVal = analogRead(JOY_X_PIN);
int yVal = analogRead(JOY_Y_PIN);
moveValue = map(yVal, 0, 1023, -30, 30);
turnValue = map(xVal, 0, 1023, -30, 30);
if (abs(moveValue) < JOYSTICK_DEADZONE) {
moveValue = 0;
if (abs(turnValue) < JOYSTICK_DEADZONE) {
turnValue = 0;
int leftOffset = clampValue(moveValue + turnValue, DRIVE_OFFSET_MIN, DRIVE_OFFSET_MAX);
int rightOffset = clampValue(moveValue - turnValue, DRIVE_OFFSET_MIN, DRIVE_OFFSET_MAX);
leftDriveCmd = applyContinuousCommand(LEFT_DRIVE_STOP, leftOffset, REVERSE_LEFT_DRIVE);
rightDriveCmd = applyContinuousCommand(RIGHT_DRIVE_STOP, rightOffset, REVERSE_RIGHT_DRIVE);
leftDriveServo.write(leftDriveCmd);
rightDriveServo.write(rightDriveCmd);
// Joystick button reset
void updateJoystickCalibration() {
if (digitalRead(JOY_SW_PIN) == LOW) {
if (now - lastJoyButtonTime >= BUTTON_DEBOUNCE_MS) {
zeroTopState();
lastJoyButtonTime = now;
// Motion response
void updateMotionResponse() {
if (topTurning) {
return;
if (alertActive) {
return;
if (millis() < alertHoldUntil) {
return;
int motionDetected = digitalRead(PIR_PIN);
if (motionDetected == HIGH) {
if (topState != 180) {
startTopTurnToState(180);
if (topState != 0) {
startTopTurnToState(0);
// Ultrasonic
long readDistanceCM() {
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
long duration = pulseIn(ECHO_PIN, HIGH, 30000);
if (duration == 0) {
return -1;
return duration * 0.034 / 2;
void updateDistanceReading() {
if (now - lastDistanceRead >= DISTANCE_READ_INTERVAL_MS) {
lastDistanceRead = now;
lastDistance = readDistanceCM();
// Scan servo
void updateScanServo() {
if (now - lastScanUpdate >= SCAN_INTERVAL_MS) {
lastScanUpdate = now;
if (scanForward) {
scanPos++;
if (scanPos >= SCAN_MAX) {
scanPos = SCAN_MAX;
scanForward = false;
scanPos--;
if (scanPos <= SCAN_MIN) {
scanPos = SCAN_MIN;
scanForward = true;
scanServo.write(scanPos);
// Directional alert behavior
void handleUltrasonicAlert(long distance) {
unsigned long currentTime = millis();
if (distance > 0 && distance <= DETECTION_DISTANCE_CM) {
if (currentTime - lastActionTime >= ACTION_COOLDOWN_MS) {
if (!topTurning) {
if (scanPos >= 90 && topState != 180) {
} else if (scanPos < 90 && topState != 0) {
lastActionTime = currentTime;
alertHoldUntil = currentTime + ALERT_HOLD_MS;
// Serial output
// SCAN,angle,distance,motion,topState,leftCmd,rightCmd,keyboardMode
void sendRadarData(long distance) {
Serial.print("SCAN,");
Serial.print(scanPos);
Serial.print(",");
Serial.print(distance);
Serial.print(",");
Serial.print(motionDetected);
Serial.print(",");
Serial.print(topState);
Serial.print(",");
Serial.print(leftDriveCmd);
Serial.print(",");
Serial.print(rightDriveCmd);
Serial.print(",");
Serial.println(keyboardMode ? 1 : 0);
void updateRadarSend() {
if (now - lastRadarSend >= RADAR_SEND_INTERVAL_MS) {
lastRadarSend = now;
sendRadarData(lastDistance);
// Setup
Serial.setTimeout(10);
pinMode(JOY_SW_PIN, INPUT_PULLUP);
pinMode(PIR_PIN, INPUT);
pinMode(TRIG_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(RGB_RED_PIN, OUTPUT);
pinMode(RGB_GREEN_PIN, OUTPUT);
pinMode(RGB_BLUE_PIN, OUTPUT);
leftDriveServo.attach(LEFT_DRIVE_SERVO_PIN);
rightDriveServo.attach(RIGHT_DRIVE_SERVO_PIN);
topServo.attach(TOP_SERVO_PIN);
scanServo.attach(SCAN_SERVO_PIN);
leftDriveServo.write(applyContinuousCommand(LEFT_DRIVE_STOP, 0, REVERSE_LEFT_DRIVE));
rightDriveServo.write(applyContinuousCommand(RIGHT_DRIVE_STOP, 0, REVERSE_RIGHT_DRIVE));
topServo.write(applyContinuousCommand(TOP_SERVO_STOP, 0, REVERSE_TOP_SERVO));
// Main loop
readSerialCommands();
updateDrive();
updateJoystickCalibration();
updateTopTurn();
updateScanServo();
updateDistanceReading();
handleUltrasonicAlert(lastDistance);
updateMotionResponse();
updateAlertFlash();
updateRadarSend();
// My main sources are listed below:
// Joystick Code based on “arduinogetstarted.com/tutorials/arduino-joystick”
// Motion Sensor Code based on “arduinogetstarted.com/tutorials/arduino-motion-sensor”
// PC-to-Arduino Serial Code based on “arduinogetstarted.com/tutorials/arduino-serial-monitor”
// Millis() Function Syntax based on “docs.arduino.cc/language-reference/en/functions/time/millis/”
