Hello
I am making an Automatic parking lot, where if the PIR sensor detects the car then the servo will open
and the LCD will display how much space is left, and when you want to leave will be done by entering values through a keypad and typing "paid" in the serial monitor.
the issue I am facing is
- The time spent inside the parking lot should be calculated between the keypad entries of (*n#)
and (#n*), where n represents the car number (1-5) based on the order of entry.
- I am facing an issue with millis() I tried to convert it minutes but whenever it goes above 0.60 it continues as (0.61....0.7) it doesn't convert to (1.00....1.12). the reason I need this is so I can calculate the cost as mentioned in the point above (Parking Fee (fils) = time(sec) x fare, are= 0.29 fils/sec)
I would like your help to understand how to implement those two points.
// C++ code
#include <Keypad.h>
#include <LiquidCrystal.h>
#include <Servo.h>
Servo myservo;
int pos;
int led = 3;
int count = 0;
int pir = A4;
int value = 0;
int Slot = 5; //Enter Total number of parking Slots
int flag1 = 0;
int flag2 = 0;
double i = 0;
double a = millis();
double c ;
const int rs = 8, e = 9, d4 = 10, d5 = 11, d6 = 12, d7 = 13;
LiquidCrystal lcd(rs, e, d4, d5, d6, d7);
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'},
byte rowPins[ROWS] = {7, 6, 5, 4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A3, A2, A1, A0}; //connect to the column pinouts of the keypad
Keypad myKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
pinMode(led, OUTPUT);
pinMode(pir, INPUT);
lcd.begin(16, 2);
myservo.attach(2);
myservo.write(0);
lcd.setCursor (0, 0);
lcd.print("PARKING SYSTEM");
lcd.setCursor (0, 1);
lcd.print("PROJECT");
delay (2000);
lcd.clear();
Serial.println("");
char key = myKeypad.getKey();
if (digitalRead (pir) == HIGH && flag1 == 0) { //pir sensor
if (Slot > 0) {
flag1 = 1;
if (flag2 == 0) {
myservo.write(0);
Slot = Slot - 1;
digitalWrite(led, HIGH);
digitalWrite(led, LOW);
lcd.print("Parking Full");
delay (3000);
lcd.clear();
if (key != NO_KEY) //time
if (isdigit(key))
//Serial.print(key);
value = value * 10 + key - '0';
else if(){
a = millis();
while (true)
c = millis();
s = ((c - a) / 1000) / 60;
i = s * (1.00 / 0.60);
Serial.println(i);
delay(600);
if (Serial.available()) { // serial
String cmd = "paid";
if (cmd == "paid") {
flag2 = 1;
if (flag1 == 0) {
myservo.write(0);
Slot = Slot + 1;
if (flag1 == 1 && flag2 == 1) {
delay (1000);
myservo.write(90);
flag1 = 0, flag2 = 0;
lcd.print("Available");
lcd.print("Slot: ");
lcd.print(Slot);
