Automatic sanitiser
Guys,
I was making a automatic sanitizer dispenser using ultrasonic and dc pump.
now am facing a problem
I have set the distance ton turn on the pump to less than 10cm
but it detects the surfaces even at at a far distance, this keeps my pump is running even with out detecting the hands.
Please help me out its urgent;
My code is attached here;
/*------------------AUTOMATIC SANITIZER DISPENSER--------------------------------------------*/
/*_____________________USING ULTRASONIC SENSOR_______________________________________________*/
int const pump = 8;
int const uvcc = 9; //vcc to ultrasonic
int const trig = 10;
int const echo = 11;
int const ugnd = 12; //GND to ultrasonic
int const power = A4; // power indicator
int const disp = A5;  //Dispensing indicator
long duration; // variable for the duration of sound wave travel
int distance; // variable for the distance measurement
pinMode(pump,OUTPUT);
pinMode(uvcc,OUTPUT);
pinMode(trig,OUTPUT);
pinMode(echo,INPUT);
pinMode(ugnd,OUTPUT);
pinMode(power,OUTPUT);
pinMode(disp,OUTPUT);
digitalWrite(pump,LOW);
digitalWrite(uvcc,HIGH);  //VCC to ultrasonic
digitalWrite(ugnd,LOW);   //GND to ultrasonic
digitalWrite(power,LOW);
digitalWrite(disp,HIGH);  //Dispensing indicator
  digitalWrite(pump, LOW);
  digitalWrite(trig, LOW);
  delayMicroseconds(2);
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echo, HIGH);
  distance = duration * 0.034 / 2;
  if(distance <10 && distance >1)
    sanitise();
    search_for_hand();
void sanitise()
  digitalWrite(pump, HIGH);
  digitalWrite(disp, LOW);
  digitalWrite(uvcc, LOW);  //VCC to ultrasonic, SENSOR IS OFF
  delay(300);
  digitalWrite(disp, HIGH);
  delay(3000);
  digitalWrite(uvcc, HIGH);  //VCC to ultrasonic, SENSOR IS ON
void search_for_hand()
  digitalWrite(disp, HIGH); //Dispensing indicator
Forum_upload_arduino.ino (1.81 KB)
Have you thought of using debug prints?
Or not hijacking unrelated topics?
@VISHNUMK
TOPIC SPLIT
DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
@AWOL
yes, i did try serialprint
calculation values are correct
this is what it prints when i have issue actual distance to floor is approx 20cm
but it detects as 19cm,10cm and finally 0 cm...
couldnt find why it is like it
