avoiding delay
hello guys
I'm new with arduino
I've made a button which controls two leds.
I want one led to stay on for three seconds and the other one for 10 seconds.
I want to avoid delay because I don't want my entire program to stop
can anybody help me out?
many thanks in advance
Look at the BlinkWithoutDelay example in the IDE
dijkie350:
What have you tried so far: what worked, what didn't?
I looked at the example with the blinking led and at the millis() in te reference.
so far I didn't manage to get this in my sketch.
This thread should probably be a sticky post:
http://forum.arduino.cc/index.php?topic=223286.0
dijkie350:
Well as I said before....
JimboZA:
.... what code have you tried? Post it here, and explain what it's (not) doing. Also post a schematic of your circuit: we need to see how the button is connected.
I just used this simple button sketch, only with a led added.
everything is working fine so far.
now I have to keep te leds on.
one for three seconds and the other for fifteen for example
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2;
const int belPin =  12;
const int rgbPin = 11;
int buttonState = 0;
  // initialize the LED pin as an output:
  pinMode(belPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(rgbPin, OUTPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    digitalWrite(belPin, HIGH);
    digitalWrite(rgbPin, HIGH);
  else {
    // turn LED off:
    digitalWrite(belPin, LOW);
     digitalWrite(rgbPin, LOW);
polymorph:
Demonstration code for several things at the same time - Project Guidance - Arduino Forum
moderator: done
Yay!
robtillaart:
moderator: done
Thank you.
It's a rather long Thread with a lot of esoteric discussion. I hope newcomers start at the first (oldest) post.
...R
Robin2:
robtillaart:
moderator: done
Thank you.
...R
I expect they still start with posting their problem first :wink:
