AVR-ISP-MKII on OSX [not working]
Hello everyone
I bought an boarduino and an AVR-ISP-MKII from olimex.
Currently I'm running OSX 10.10 on a Macbook Pro.
TO use the programmer with the Arduino IDE the manual of the programmer instructs you to upload a different firmware with the dfu-progammer:
this is what i get:
i press the upgradebutton on the programmer an the leds go out. then i use the terminal:
User:~ Fischr$ dfu-programmer at90usb162 erase
User:~ Fischr$ dfu-programmer at90usb162 flash --debug 6 /Users/Fischr/Desktop/dfu_programmer_install/libUSB-AVRISP-MKII.hex
     target: at90usb162
    chip_id: 0x2ffa
  vendor_id: 0x03eb
    command: flash
      quiet: false
      debug: 6
device_type: AVR
------ command specific below ------
   validate: true
   hex file: /Users/Fischr/Desktop/dfu_programmer_install/libUSB-AVRISP-MKII.hex
Validating...
10288 bytes used (83.72%)
User:~ Fischr$
looks like the firmware got uploaded. The leds on the programmer are still off. When i pull out and reconnect the programmer, they light up green and red.
also the programmer gets recognized by the laptop:
So now I tried to upload the blink programm with the Arduino IDE 1.6.5 and this is the output:
avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Users/Fischr/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/Fischr/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200012345
avrdude: stk500v2_recv_mk2: error in USB receive
avrdude: stk500v2_getsync(): timeout communicating with programmer
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: AVRISP mkII
as soon as I unplug the programmer I get this message:
avrdude: usbdev_send(): wrote -32 out of 2 bytes, err = Broken pipe
avrdude: stk500_send_mk2(): failed to send command to serial port
so somehow the programmer is recognized.
it says on the productpage that there are some problems with the 6.x.x versions of avrdude and an older version should be used. so i downloaded the Arduino IDE 1.0.5 and tried the upload the blink program while getting this result:
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : usb
avrdude: usbdev_open(): using read endpoint 0x83
avrdude: Sent: . [01]
avrdude: Recv: . [01] . [00] . [0a] A [41] V [56] R [52] I [49] S [53] P [50] _ [5f] M [4d] K [4b] 2 [32]
avrdude: stk500v2_getsync(): found AVRISP mkII programmer
         AVR Part                      : ATMEGA328P
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: Sent: . [03] . [90]
avrdude: Recv: . [03] . [00] . [00]
avrdude: Sent: . [03] . [91]
avrdude: Recv: . [03] . [00] . [01]
avrdude: Sent: . [03] . [92]
avrdude: Recv: . [03] . [00] . [11]
         Hardware Version: 0
         Firmware Version Master : 1.17
avrdude: Sent: . [03] . [94]
avrdude: Recv: . [03] . [00] ! [21]
         Vtarget         : 3.3 V
avrdude: Sent: . [03] . [98]
avrdude: Recv: . [03] . [00] . [06]
         SCK period      : 8.00 us
avrdude: Sent: . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00]
avrdude: Recv: . [10] . [c0]
avrdude: stk500v2_command(): command failed
avrdude: Sent: . [03] . [a1]
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: Unknown status 0x00
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: Sent: . [11] . [01] . [01]
avrdude: Recv: . [11] . [00]
avrdude done.  Thank you.
Have you encountered the same problems? If so, how did you solve it?
Sincerely
bluebubble
