After I installed drivers for a NANO clone (CH340G chip) Arduino IDE stopped uploading sketches, even to the UNO I have used for months. I always get the same message: "avrdude: error at C:\Users\milto\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:402: syntax error
avrdude: error reading system wide configuration file "C:\Users\milto\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
I've tried:
-Different COM ports
-Unplugging RX/TX pins
-Old bootloader
-Resetting board
-Uninstalling CH340G drivers
-Uninstalling and reinstalling Arduino IDE (2.0.4 and 1.8.19)
I tried also de online IDE version and it works with the old UNO so I'm sure the board and USB cable are ok. I don't know what else should I try. Any ideas?
Hi @miltonch. It appears your installation of the AVRDUDE tool was somehow corrupted. I think it will be solved by uninstalling and then reinstalling the "Arduino AVR Boards" platform.
I'll provide instructions:
- Select Tools > Board > Boards Manager from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
- Scroll down through the list of boards platforms until you see the "Arduino AVR Boards" entry.
- Hover the mouse pointer over the "INSTALLED" label on the "Arduino AVR Boards" entry. You will now see it change to an "UNINSTALL" button.
- Click the "UNINSTALL" button.
- A confirmation dialog will now appear. Click the "YES" button.
- Wait for the uninstallation to finish.
- Select the newest version from the dropdown version menu at the bottom of the "Arduino AVR Boards" entry.
- Click the "INSTALL" button at the bottom of the "Arduino AVR Boards" entry.
- Wait for the installation to finish.
Now try uploading your sketch again. Hopefully the error will no longer occur.
Dear Ptillisch
Thanks so much!! It worked fantastically. I spent the whole week trying to fix it up
I owe you a beer my friend!!
Thanks again
Milton
You are welcome. I'm glad it is working now.
Regards,
Per
Hello, in order not to delete and not lose all the data, I rolled back to the next version, it works
No data is lost. The instructions I shared only reinstall the corrupted boards platform.
The only way they could affect any of your own user data is if you manually added or modified files under the C:\Users\<username>\AppData\Local\Arduino15\packages\arduino folder, which is only done rarely by advanced users (you would surely remember if you did it).
I'm glad it is working for you now!
