Avrdude FTD1232 Programmer with Arduino Nano
Hi
I would like to program my Arduino board with FTDI232 programmer under Ubuntu avrdude software.
I tried to many times under Arduino IDE it didn't work.
$ avrdude -v
avrdude: Version 6.3-20171130
FTDI---->ARDUINO NANO
DTR(-)---->(+)RST (there is 100uF 16V Cap Between)
RX---->TX
TX---->RX
VCC (5V)---->VCC (5V)
CTS---->X
GND---->GND
$ /usr/bin/avrdude -Cavrdude.conf -patmega328p -cft232r -P/dev/ttyUSB0 -b115200 -Uflash:w:/tmp/arduino_build_264240/Blink.ino.hex:i
avrdude: ft245r_open(): invalid device identifier '        '
$ /usr/bin/avrdude -C/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/arduino_build_264240/Blink.ino.hex:i
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/home/petty/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
^C
two questions…
  1. Is the bootloader installed ?
  2. what is the 100u/16V for ? perhaps 100nF ?
I think you need to review the source of your guidance.
Are the device and com port properly selected?
I couldn't find any proper guidance for that.But I would like to try out programming with FTD1232.
Improvment
DTR---->RST (there is 100nF Cap Between)
RX---->TX
TX---->RX
GND---->GND
GND(-) between 16v 100uF cap (+) +5V
`$ sudo avrdude -pm328p -cft232r -v -v -v -Pusb:ft0 -Uflash:w:/tmp/arduino_build_264240/Blink.ino.hex:i
     User configuration file is "/root/.avrduderc"
     Using Port                    : usb:ft0
     Using Programmer              : ft232r
avrdude: : Pin is ok.
avrdude: VCC: Pin is ok.
avrdude: BUFF: Pin is ok.
avrdude: RESET: Pin is ok.
avrdude: SCK: Pin is ok.
avrdude: MOSI: Pin is ok.
avrdude: MISO: Pin is ok.
avrdude: ERRLED: Pin is ok.
avrdude: RDYLED: Pin is ok.
avrdude: PGMLED: Pin is ok.
avrdude: VFYLED: Pin is ok.
avrdude: ft245r_open(): device number parsed as: 0
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : ftdi_syncbb
     Description     : FT232R Synchronous BitBang
     Pin assignment  : 0..7 = DBUS0..7
       VCC     =  (not used)
       BUFF    =  (not used)
       RESET   =  4
       SCK     =  0
       MOSI    =  2
       MISO    =  1
       ERR LED =  (not used)
       RDY LED =  (not used)
       PGM LED =  (not used)
       VFY LED =  (not used)
avrdude: Device is not responding to program enable. Check connection.
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
The FT232R with Avrdude is an ICSP programmer. Not for programming via the bootloader.
The nano already has a FT232r USB to ttl converter on board. Why are you trying to use an external adaptor?
Actually I have Arduino pro mini too and It was not that easy and most of the time I had to change to Usbasp.But I need every time breadboard and connector cables etc. I need to learn how to use it.
This is Arduino pro mini connected FTD1232 but not soldered.
$ sudo avrdude -C/etc/avrdude.conf -patmega328p -carduino-ft232r -Pusb:ft0 -U flash:r:flash.hex:i -v -v -v -v
         Using Programmer              : arduino-ft232r
avrdude: <unknown>: Pin is ok.
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Description     : Arduino: FT232R connected to ISP
           VCC     =  (not used)
           BUFF    =  (not used)
           RESET   =  7
           SCK     =  5
           MOSI    =  6
           MISO    =  3
         this check.
Different Computer
$ sudo avrdude -p m328p -carduino-ft232r -v -v -v -P /dev/ttyUSB0 -b 19200 -U flash:r:backup.bin:r
avrdude: Version 7.1
         Copyright the AVRDUDE authors;
         see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
         System wide configuration file is /etc/avrdude.conf
         User configuration file is /root/.avrduderc
         Overriding Baud Rate          : 19200
avrdude: <unknown>: pin is OK
avrdude: VCC: pin is OK
avrdude: BUFF: pin is OK
avrdude: RESET: pin is OK
avrdude: SCK: pin is OK
avrdude: SDO: pin is OK
avrdude: SDI: pin is OK
avrdude: ERRLED: pin is OK
avrdude: RDYLED: pin is OK
avrdude: PGMLED: pin is OK
avrdude: VFYLED: pin is OK
avrdude: ft245r_open(): no device identifier in portname, using default
ft245r_set_bitclock: bitclk 19200 -> FTDI rate 19200, baud multiplier 1
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         Serial program mode           : yes
         Parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           Memory Type Alias    Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           lfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           hfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           efuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           lock                    0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           signature               0     0     0    0 no          3    1      0     0     0 0x00 0x00
           calibration             0     0     0    0 no          1    1      0     0     0 0x00 0x00
           VCC     =  (not used)
           BUFF    =  (not used)
           RESET   =  7
           SCK     =  5
           SDO     =  6
           SDI     =  3
avrdude ft245r_program_enable() [ft245r.c:525] error: device is not responding to program enable; check connection
avrdude main() [main.c:1246] error: initialization failed, rc=-1
        - double check the connections and try again
        - use -B to set lower ISP clock frequency, e.g. -B 125kHz
        - use -F to override this check
You can't use arduino-ft232r to program an ATmega 328P
If you want to program a pro mini via the bootloader then use -c arduino.
Are you trying to burn the bootloader?
I would just use the Arduino IDE to program a pro mini.
Is it possible to read and save Arduino device under Arduino IDE? I would also like to read rom (dump).
I found this Youtube video [https://www.youtube.com/watch?v=jynlynjOOek](https://Linux d2xx Driver Installation Guide ) but after reinstall it didn't helped either.
It's not going to help.
If you are having a problem programming a pro mini using the IDE please show your wiring diagram and the error messages you receive.
Wiring is normal I just added jumper wire
$ sudo avrdude /home/petty/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino18/etc/avrdude.conf -pm168 -carduino -v -v -v -P/dev/ttyUSB0 -b 19200 -U flash:r:backup.bin:r
         AVR Part                      : ATmega168
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           eeprom                 65    20     4    0 no        512    4      0  3600  3600 0xff 0xff
           flash                  65     6   128    0 yes     16384  128    128  4500  4500 0xff 0xff
         Programmer Type : Arduino
         Description     : Arduino for bootloader using STK500 v1 protocol
         Hardware Version: 2
         Firmware Version: 1.16
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01 s
avrdude: device signature = 0x1e9406 (probably m168)
avrdude: reading flash memory ...
Reading | ################################################## | 100% 12.28 s
avrdude: writing output file backup.bin
Yes It worked.
Glad you got it to work
Have a nice day!
Thank you
I was all the time with with parameter -c arduino-ft232r ft232r ttl232r confused.
Well I did tell you to use -c arduino back in post #9
yes after that It worked.
Happy I could help
An FT232R is a USB ~ serial converter, it won’t help with ICSP programming.
I found this scratches, can we use avrdude as a programmer software or we need a windows software like Pony Prog 2000 etc.? If we able to use it with atmega which programmer type?
https://www.sparkfun.com/tutorials/104
I've used my FT232 with avrdude many times as an ICSP programmer.
Burned the bootloader on many 328s
