I'm testing BLYNK ON MEGA+WiFi R3 ATmega2560+ESP8266 from:
the first few steps all good, the second last step got error:
Failed to leave Flash model. in the ESP8266 Flash Downloader window. which happened in the tutorial also.
and then the last step failed by the avrdude: stk500v2_ReceiveMessage(): timeout
// LIBRARY-Blynk
#define BLYNK_PRINT Serial
#include <ESP8266_Lib.h> // insert this library
#include <BlynkSimpleShieldEsp8266.h>
// Initialitation
char auth[] = "2626aXgFo0b3_bDAQURC_FE66OsAG-8A";
char ssid[] = "VVVV";
char pass[] = "BBBB";
#define EspSerial Serial3
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// write data from blynk on virtual 2
BLYNK_WRITE(V2) {
if (param.asInt()) {
digitalWrite(13, HIGH);
//turn led on arduino mega wifi
else {
digitalWrite(13, LOW);
//turn led off arduino mega wifi
delay(10);
pinMode(13, OUTPUT);
Serial3.begin(115200);
delay(10);
EspSerial.begin(ESP8266_BAUD);
delay(10);
// Blynk.begin(auth, wifi, ssid, pass); //Reguler server
Blynk.begin(auth, wifi, ssid, pass,"blynk-cloud.com", 8080); //Local server
delay(10);
delay(10);
Blynk.run();
if ( Serial3.available() ) {
Serial.write( Serial3.read() );
if ( Serial.available() ) {
Serial3.write( Serial.read() );
ERROR:
Arduino: 1.8.16 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 17492 bytes (6%) of program storage space. Maximum is 253952 bytes.
Global variables use 839 bytes (10%) of dynamic memory, leaving 7353 bytes for local variables. Maximum is 8192 bytes.
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: ser_recv(): read error: Access is denied.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: stk500v2_command(): failed miserably to execute command 0x14
avrdude: stk500v2_paged_load: read command failed
avrdude: stk500v2_command(): failed miserably to execute command 0x1d
avrdude: stk500v2_cmd(): failed to send command
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
option enabled in File -> Preferences.
