avrdude: verification error, first mismatch at byte 0x0000 0x0c != 0x62
i have prolem when i uploading my code
0x0c != 0x62
avrdude: verification error; content mismatch
any help
What do you have for these?
i did board : arduino uno
serial port com4
i try to change my serial port but still this error shown !
Start over, what happens?
Unplug the UNO
Close all IDE windows
Plug UNO back in
Start up the IDE
Select UNO
Select the correct COM port
i uninstall arduino software then i instal
i plug arduino usb and check board
also i check the serial port
all are ok
still this error
What happens on the LEDS?
when i plug usb of arduino to the software the led will turn on
and the other led will turn 3 time
so this ok
but when i click to upload my code still do this but give me this error
0x0c != 0x62
Try a new USB cable
Try a different USB port
Have you every downloaded to the UNO successfully prior?
You may need a new controller or re-burn the bootloader
interesting I am getting the same error trying to learn some HTML...
this error:
avrdude: verification error, first mismatch at byte 0x7800
0x8c != 0xff
the sketch attached:
you can see I am just trying to move the HTML off to the SD card...
compiles to: Binary sketch size: 31,678 bytes (of a 32,256 byte maximum)
I have a similar one (with SD library, but without the call to the file) that works. On my UNO with the stock Wiznet Shield...
I also have the F() macro giving me this:
NTPClockWithWebPageWithSD.ino: In function 'void updateLCD()':
NTPClockWithWebPageWithSD.ino:95: warning: only initialized variables can be placed into program memory area
NTPClockWithWebPageWithSD.ino (9.02 KB)
sorry BulldogLowell
but did you solved this problem ??
also i check your code there are an error with liquidCrystal_I2C lcd(0x27, 16, 2);
zouz:
I use a different library https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
zouz:
sorry BulldogLowell
Yes, I worked down the memory requirements, removed the String class.
