avrdude: verification error, first mismatch at byte 0x0000
Tried different PC, reinstalled Arduino IDE, updated libraries, changed USB cable yet genuine Arduino UNO R3 throws me this.
Sketch uses 4030 bytes (12%) of program storage space. Maximum is 32256 bytes.
Global variables use 520 bytes (25%) of dynamic memory, leaving 1528 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Andrejs Zavaruhins\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Andrejs Zavaruhins\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\ANDREJ~1\AppData\Local\Temp\arduino_build_348570/i2c_scanner.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Andrejs Zavaruhins\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\ANDREJ~1\AppData\Local\Temp\arduino_build_348570/i2c_scanner.ino.hex"
avrdude: writing flash (4030 bytes):
Writing | ################################################## | 100% 0.64s
avrdude: 4030 bytes of flash written
avrdude: verifying flash memory against C:\Users\ANDREJ~1\AppData\Local\Temp\arduino_build_348570/i2c_scanner.ino.hex:
avrdude: load data flash data from input file C:\Users\ANDREJ~1\AppData\Local\Temp\arduino_build_348570/i2c_scanner.ino.hex:
avrdude: input file C:\Users\ANDREJ~1\AppData\Local\Temp\arduino_build_348570/i2c_scanner.ino.hex contains 4030 bytes
avrdude: reading on-chip flash data:
Reading | #############################################An error occurred while uploading the sketch
##### | 100% 0.65s
avrdude: verifying ...
         0x62 != 0x0c
avrdude: verification error; content mismatch
avrdude done.  Thank you.
Bootloader says,
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
yet I am able to get board info.
did you solved the error?
what didi you do?
