Buenas, resulta que estoy haciendo una programacion para arduino usando el modulo RFID RC522, y uso la libreria de miguel balboa que descargue de aca: GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522, pero resulta que al abrir el primer ejemplo que contiene la libreria que es una carpeta llamada "ChangeUID" intento verificarla y de inmediato me arroja un error en esta linea:
"MFRC522::MIFARE_Key key;";
ChangeUID:37: error: 'MIFARE_Key' in 'class MFRC522' does not name a type
ChangeUID.ino: In function 'void setup()':
ChangeUID:43: error: 'class MFRC522' has no member named 'PCD_Init'
ChangeUID:48: error: 'key' was not declared in this scope
ChangeUID.ino: In function 'void loop()':
ChangeUID:65: error: 'class MFRC522' has no member named 'PICC_IsNewCardPresent'
ChangeUID:65: error: 'class MFRC522' has no member named 'PICC_ReadCardSerial'
ChangeUID:74: error: 'class MFRC522' has no member named 'uid'
ChangeUID:75: error: 'class MFRC522' has no member named 'uid'
ChangeUID:76: error: 'class MFRC522' has no member named 'uid'
ChangeUID:96: error: 'class MFRC522' has no member named 'MIFARE_SetUid'
ChangeUID:101: error: 'class MFRC522' has no member named 'PICC_HaltA'
ChangeUID:102: error: 'class MFRC522' has no member named 'PICC_IsNewCardPresent'
ChangeUID:102: error: 'class MFRC522' has no member named 'PICC_ReadCardSerial'
ChangeUID:108: error: 'class MFRC522' has no member named 'PICC_DumpToSerial'
ChangeUID:108: error: 'class MFRC522' has no member named 'uid'
Multiple libraries were found for "MFRC522.h"
Used: C:\Program Files\Arduino\libraries\MFRC522-master
Not used: C:\Program Files\Arduino\libraries\rfid-master
Y lo mismo pasa con los demas ejemplos, todos me arrojan error en algun punto, y necesito por favor que alguien me colabore tal vez aportando una nueva libreria o explicandome que puede estar pasando pues tengo que entregar el proyecto el otro mes y no se porque falla, les agradezco mucho.
