Ayuda principiante
Hola!! hace poco me llegó de China un kit Arduino con el que comencé con esto de la electrónia. Trae la placa con un shield incorporado, arduino UNO (infiduino R3, dice abajo)... luego de instruirme un poco comencé montando la pantalla lcd que traía el kit. y cargué el programa ejemplo "hola mundo", para pantallas lcd ... pero no aparece ningun mensaje... solo aparece la fila superior del lcd y nada mas... AYUDA!!1 ..
LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
The circuit:
  • LCD RS pin to digital pin 12
  • LCD Enable pin to digital pin 11
  • LCD D4 pin to digital pin 5
  • LCD D5 pin to digital pin 4
  • LCD D6 pin to digital pin 3
  • LCD D7 pin to digital pin 2
  • LCD R/W pin to ground
  • LCD VSS pin to ground
  • LCD VCC pin to 5V
  • 10K resistor:
  • ends to +5V and ground
  • wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
Saludos
Ante todo lee las normas del foro. Como ayudarte si no suministras informacion. Codigo, diagramas de conexiones etc.
Y además lee el punto 6. El título no puede ser AYUDA PRINCIPIANTe porque no dice nada a otra persona que tenga tu problema. Asi que busca algo que se corresponda con tu problema.
Como sabes que el LCD esta funcionando?
No publicaste el código, y eso también lo dice las reglas del foro como bien te señaló Max_saeta.
Para mi esta mal cableado.
ojaoja... efectivamente estaba mal cableado... lo siento. Gracias por su tiempo
Cambia el titulo y coloca Solucionado
