Barcode Reader/Scanner Module to Arduino
I am working on a project where I need to interface a barcode scanner to Arduino.
Can you refer to any bar code scanner that can be easily interfaced with Arduino.
Thanks.
I will appreciate any feedback.
What's wrong with this? Is just the first of 210000 result of google -> arduino barcode scanner...
Ciao, Ale.
FutureEngineer:
Thanks.
Hi, we developed a solution to connect the Arduino Uno board with our OEM barcode scanner which with TTL interface. we built a converter board which connect oem barcode scanner via 12pins flat cable in one side and connect the Arduino board by Dupont Line in the other side. the solution can be very cheap if you no need buzzer or you add the buzzer by yourself, and we also have solution which with buzzer together.
With our solution, no need extra power adapter, no need RS232 cable, but connect to Arduino board directly.
For more details, please visit:
