Hi, I used the code from this link.
I want to compare different codes. I tried various solutions that didn't work.
I would like to sum a string of code characters.
E.g. int length = myString_KODE.length();
Do you have any ideas ?
Thanks
Thanks
Please post your sketch here so we can see what you are doing. Please use code tags when you post the code
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
#include <usbhid.h>
#include <usbhub.h>
#include <hiduniversal.h>
#include <hidboot.h>
#include <SPI.h>
String scan_kode;
class MyParser : public HIDReportParser {
public:
MyParser();
void Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf);
protected:
uint8_t KeyToAscii(bool upper, uint8_t mod, uint8_t key);
virtual void OnKeyScanned(bool upper, uint8_t mod, uint8_t key);
virtual void OnScanFinished();
MyParser::MyParser() {}
void MyParser::Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf) {
// If error or empty, return
if (buf[2] == 1 || buf[2] == 0) return;
for (uint8_t i = 7; i >= 2; i--) {
// If empty, skip
if (buf[i] == 0) continue;
// If enter signal emitted, scan finished
if (buf[i] == UHS_HID_BOOT_KEY_ENTER) {
OnScanFinished();
// If not, continue normally
else {
// If bit position not in 2, it's uppercase words
OnKeyScanned(i > 2, buf, buf[i]);
return;
uint8_t MyParser::KeyToAscii(bool upper, uint8_t mod, uint8_t key) {
// Letters
if (VALUE_WITHIN(key, 0x04, 0x1d)) {
if (upper) return (key - 4 + 'A');
else return (key - 4 + 'a');
// Numbers
else if (VALUE_WITHIN(key, 0x1e, 0x27)) {
return ((key == UHS_HID_BOOT_KEY_ZERO) ? '0' : key - 0x1e + '1');
return 0;
void MyParser::OnKeyScanned(bool upper, uint8_t mod, uint8_t key) {
uint8_t ascii = KeyToAscii(upper, mod, key);
scan_kode=ascii; // global variable STRING
int length = scan_kode.length();
Serial.print(length);
void MyParser::OnScanFinished() {
Serial.println(" - Lectura Correcta!!");
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
MyParser Parser;
Serial.begin( 115200 );
Serial.println("Escaner Iniciado Correctamente!");
if (Usb.Init() == -1) {
Serial.println("OSC did not start.");
delay( 200 );
Hid.SetReportParser(0, &Parser);
Usb.Task();
Serial Monitor : 17:38:23.399 -> 32222222222222 - Lectura Correcta!!
I managed, problem solved
