Barcode scanner
Good morning
I am working on a code to help people track their dially consumption of different food nutrients. The user have two choices between:
  1. Scanning the barcode of the food item
  2. Enter the food code and the quantitiy, for items without a barcode using a keypad
The barcode scanner code was taken from Arduino playground, and it succeesfully scan and identify the food item. However, when I intergrate the codes of 1 and 2, the barcode scanner doesn’t identify the items.
I added the run results for the scanner alone, and after the intigration.
Any help is appreciated.
Thanks
RunResult_Integration.pdf (253 KB)
RunResult_ScannerAlone.pdf (28.9 KB)
We can't help you using screenshots. Post the code.
I am having a problem posting the code.
I got this message"exceed size"
I can send it via email
The code is very long.
Kindly check the attached error message.
ErrorMessage.pdf (125 KB)
How can I post the code ?? Please I need your support.
Thanks
looking at the code in the file RunResult_Integration.pdf in post #1 you appear to be repeating the same sequence of statements on different data multiple times which is probably why your code is very long
could you use a function ?
post you original scanner code?
original barcode scanner code, from Arduino play ground
Barcode Scanner
	This code reads the input from a ps/2 keyboard or keyboard-like
	device (e.g. a barcode scanner), translates the scan-codes into
	numbers (only numbers from 0 to 9 can be used at the moment)
	It is nowhere near a complete implementation of the ps/2 protocol,
	but it should give you a starting point.
	mys .// Benjamin Maus	( benjamin.maus <at> allesblinkt.com )
	2007
int SCAN_ENTER = 0x5a; int SCAN_BREAK = 0xf0;
int breakActive = 0;
int clockPin = 20; // Clock is only output.
int dataPin = 21; // The data pin is bi-directional
				// But at the moment we are only interested in receiving
int ledPin = 13;  // When a SCAN_ENTER scancode is received the LED blink
int clockValue = 0; byte dataValue;
byte scanCodes[10] = {0x45,0x16,0x1e,0x26,0x25,0x2e,0x36,0x3d,0x3e,0x46}; char characters[10] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9'};
int quantityCodes = 10;
char buffer[64] = {};	// This saves the characters (for now only numbers)
int bufferPos = 0;
int bufferLength = 64;
	pinMode(dataPin, INPUT);
	pinMode(clockPin, INPUT);
	pinMode(ledPin, OUTPUT);
	dataValue = dataRead();
	// If there is a break code, skip the next byte
	if (dataValue == SCAN_BREAK) {
		breakActive = 1;
	// Translate the scan codes to numbers
	// If there is a match, store it to the buffer
	for (int i = 0; i < quantityCodes; i++) {
		byte temp = scanCodes[i];
		if(temp == dataValue){
			if(!breakActive == 1){
				buffer[bufferPos] = characters[i];
				bufferPos++;
	//Serial.print('*'); // Output an asterix for every byte
	// Print the buffer if SCAN_ENTER is pressed.
	if(dataValue == SCAN_ENTER){
		Serial.print("\nbuffer: ");
		// Read the buffer
		int i=0;
		if (buffer[i] != 0) {
			while(buffer[i] != 0) {
				Serial.print( buffer[i] );
				buffer[i] = 0;
				i++;
		Serial.println(" [Enter]");
		bufferPos = 0;
		// Blink the LED
		digitalWrite(ledPin, HIGH);
		delay(300);
		digitalWrite(ledPin, LOW);
	// Reset the SCAN_BREAK state if the byte was a normal one
	if(dataValue != SCAN_BREAK){
		breakActive = 0;
	dataValue = 0;
int dataRead() {
	byte val = 0;
	// Skip start state and start bit
	while (digitalRead(clockPin));  // Wait for LOW.
	// clock is high when idle
	while (!digitalRead(clockPin)); // Wait for HIGH.
	for (int offset = 0; offset < 8; offset++) {
		val |= digitalRead(dataPin) << offset; // Add to byte
// Skipping parity and stop bits down here.
	return val;
/////food database
int Calories  = 0;
int Fat_g =0;
int Carbohydrate_g = 0;
int Calories_sum  = 0;
int Fat_g_sum =0;
int Carbohydrate_g_sum = 0;
///// Keypad
char m[4];
byte y=0;
boolean OK=0;
byte n = 0;
int REF=0;
char Quantity[2]= {0,0};
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'#','0','*'}
byte rowPins[ROWS] = {5, 4, 3, 2};
byte colPins[COLS] = {8, 7, 6};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
/////////////////////////////////// Serial LCD
#include <SoftwareSerial.h>
SoftwareSerial mySerial(15,14); /
////////////////////////////////////////////////////////Barcode
int clockPin = 7;
int dataPin = 6;
int clockValue = 0;
byte dataValue;
char check[10]={'0','0','0','0','0','0','0','0','0','0'};
int bufferPos = 0;
char tag1[5] = {'6','2','9','1','0'}; //masafi
int count=0;
void setup(){
  mySerial.begin(9600);
  delay(500); /
  ///////////////////     Barcode
void loop(){
  //count = count +1;
  Serial.print("countStart");  Serial.print(count);
  mySerial.write("Scan barcode or Enter 5555:");
  while (n<4)
    char key = keypad.getKey();
    if (key != NO_KEY)
      m[n]=key;
      n=n+1;
      mySerial.print(key);
      Serial.print(key);
      if (strcmp(m, "5555") == 0)  {ClearLCD(); mySerial.write("Enter food code: ");delay(2000);     ClearLCD();  n=0; for (int i=0; i<4; i++) {m[i]='\0'; }EnterQunatity(); }
      else {ClearLCD(); mySerial.write("Scan barcode: ");  for (int i=0; i <= 50; i++) {barcode();} mySerial.write("Done "); }
int EnterQunatity()
double Amount;
  while (n<4)
    if (key != NO_KEY)
      m[n]=key;
      n=n+1;
      Serial.print(key);
      if (strcmp(m, "1111") == 0)  { mySerial.write("Peacon");delay(1000); REF=11;ClearLCD();n=0;
                                     for (int i=0; i<4 ; i++) {m[i]=0;} mySerial.write("Enter Quantity: ");delay(1000);
                                     Amount=Get_Number_Keypad(); Peacon(Amount); Total_AND_DisplayLCD();}
  Serial.print("check="); delay(2000);
  for (int k=0; k<4; k++) {Serial.print(Amount); delay(1000);}
  return Amount;
///////////////////////////////////clear LCD
void ClearLCD()
  mySerial.write(254); mySerial.write(128);
  mySerial.write("                ");
int Get_Number_Keypad()
  n=0;
     while (n < 4)
     { char key = keypad.getKey();
     if (key != NO_KEY)
       Quantity[n]=key;
       n=n+1;
       Serial.print(key);
   double Amount = atoi(&Quantity[0]);
   Serial.print("Amount="); Serial.print(Amount);
   int test = Amount + 10;
   Serial.print("test="); Serial.print(test);
   return Amount;
/////////////////////////////////////Total and  display
void Total_AND_DisplayLCD (void)
   Calories_sum = Calories_sum + Calories;
   Carbohydrate_g_sum = Carbohydrate_g_sum + Carbohydrate_g;
   Fat_g_sum = Fat_g_sum + Fat_g;
   Serial.print("\tcarb_sum=");Serial.print(Carbohydrate_g_sum);
   Serial.print("\tfat_sum=");  Serial.print(Fat_g_sum);
   Serial.print("\tprotein_sum=");  Serial.print(Protein_g_sum);
   ClearLCD();
   mySerial.write("Calories:");mySerial.print(Calories_sum);
   mySerial.write(254); mySerial.write(192);
   mySerial.write("Carb:");mySerial.print(Carbohydrate_g_sum);mySerial.write("g"); delay(5000);
   ClearLCD();
/////////////////////////////////// barcode scanner
void barcode (void)
  Serial.print("countA=");
  Serial.println(count);
  count = count +1;
////////////////////////////////// dataRead() function
  byte val = 0;
	//return val;
dataValue = val;
Serial.print("countB=");
        Serial.print(dataValue);
		breakActive = 1;
				bufferPos++;
Serial.println("countC=");
		// Read the buffer
		int i=0;
				Serial.print( buffer[i]);
                                 check[i]=buffer[i];
				 buffer[i] = 0;
				i++;
 Serial.println("countD=");
////////////////////////////////////////////Masafi
                 if (check[0] ==tag1[0]  && check[1] == tag1[1] && check[2] ==tag1[2]  && check[3] ==tag1[3] && check[4] ==tag1[4]  )
                    {Serial.println("\tMasafi");
                     mySerial.write("Masafi");
                     count=count+1;
                     Serial.print("CNT=");Serial.println(count);
                     mySerial.write("count");mySerial.print(count);}
Serial.print("countE=");
		breakActive = 0;
	dataValue = 0;
///////////////////// food database from barcode
int Masafi() {
 Calories =5;
 Fat_g =5;
 Carbohydrate_g = 5;
 Protein_g = 5;
 Sodium_mg = 5;
return Calories; Fat_g; Carbohydrate_g; Protein_g; Sodium_mg;  }
   int Peacon(double Amount)
     Serial.print("Amount 3rd time="); Serial.print(Amount); delay(2000);
     Calories  = 691* (Amount/100);  Serial.print("Amount");Serial.print(Amount/100); delay(3000); Serial.print("Calories=");Serial.print(Calories); delay(3000);
     Fat_g =72 * (Amount/100);
     Carbohydrate_g = 14 * (Amount/100);
 return Calories; Fat_g; Carbohydrate_g;  }
I removed the redundant parts and I divided the code into two posts.
Please advise.
For what it's worth, if you know how to attach a .pdf, you know how to attach an .ino
