barcode scanner
Hey
I have bought Barcode Scanner Module, 1D/2D and programmed it. This scanner should control the servo motor.
When barcode scanners scan the barcode, if the third number is 8, the servo motor goes to 90degrees and comes back (to open the door). Although I have scanned the POR232 code, my scanner cannot scan the EAN code. So my servo motor does not work correctly. I have copied my codes here
Can someone help me to correct my codes?
#include "Servo.h"
#include "SoftwareSerial.h"
#include "SparkFun_DE2120_Arduino_Library.h"
SoftwareSerial softSerial(2, 3); //RX, TX: Connect Arduino pin 2 to scanner TX pin. Connect Arduino pin 3 to scanner RX pin.
DE2120 scanner;
#define BUFFER_LEN 40
char scanBuffer[BUFFER_LEN];
Servo myServo;
myServo.attach(9);
Serial.begin(38400);
Serial.println("DE2120 Scanner");
if (scanner.begin(softSerial) == false)
Serial.println("Scanner did not respond. Please check wiring. Did you scan the POR232 barcode? Freezing...");
while (1)
Serial.println("Scanner online!");
myServo.write(0);
if (scanner.readBarcode(scanBuffer, BUFFER_LEN))
Serial.println("Code found: ");
for (int i = 0; i < strlen(scanBuffer); i++)
Serial.println(scanBuffer*);*
  • Serial.println();*
  • myServo.write(90);*
  • delay(50000);*
  • myServo.write(0);*
  • delay(200);*
pegah-1991:
Hey
You just hijacked this topic. You need to start a new topic.
ToddL1962:
Please read the forum instructions on posting before you do.
@pegah-1991
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Perhaps it is disabled by default? Try calling "scanner.enableAll1D();" and/or "scanner.enableAll2D();" after scanner.begin().
