BARN DOOR (STAR TRACKER)
Hello coders,
I am not coder or professional , ı need help about one part .First of all , ı found 3d design on the internet and try to finish its for my astro tracker .But there are two button upgrade , one button speed ,second one is the stop button but ı can not do this in real because my code skills are not enough !
Below code , and video everything is fine but when ı press my buttons at the same time not stop the system .Could you look at this code and what am ı missing ?
// Control box for Astrophotohraphy barn door tracker
// By Nicolas Dupont  https://www.thingiverse.com/ndupont/about
// Based on https://www.thingiverse.com/thing:1133193  by fermunoz https://www.thingiverse.com/fermunoz/about
// Release history
// v0     Original code by fermunoz
// v1     Added button control
// v2     Added tracking ON/OFF control
// v2.1   Solved the motor disable that was not working properly
// SOME MATH :
// radius of the barn door tracker = 200mm (hinge to threaded rod)
// full revolution is 2 * radius * PI = 2 * 200 * 3.141592 = 1256.6368mm
// a full day is 23:56 = 23 * 60 + 56 = 1436 minutes
// movement speed (of the hinge) = 1256.6368 / 1436 = 0.87509 mm/min at threaded rod level
// the M5 stdandard picth is 0.8mm
// Rotation speed of the large gear = 0.85509 / 0.8 = 1.0939 RPM
// Larger gear has 43 teeth, the small one has 10 teeth, gear ratio = 43 / 10 = 4.3
// Small gear (and motor) speed has to be 1.0939 * 4.3 = 4.7036 RPM
// That's 60 / 4.7036 = 12.76 sec/turn ==> useful value to check is all is ok.
// NEMA17 motor usually have 200 steps/rotation
// Stepper pulses = 4.7036 * 200 = 940.72 steps/min or 15.679 pulses/sec
// with 16x microstepping = 250.86 pulses/sec --> 3.986ms delay between pulses = 3986µs
// with 32x microstepping = 501.72 pulses/sec --> 1.993ms delay between pulses = 1993µs
#define DELAY 3997 //3997 = 1.09 RPM of the large gear  ==>  WITH 1/16 microstepping  (original value from fermunoz
// Setting the variables
const int motor_dir = 8;          // Output pin for DIR control of the driver
const int motor_step = 9;         // Output pin for STEP control of the driver
const int motor_enable = 10;      // Output pin for ENABLE control of the driver
const int led = 13;               // Output pin for the LED
int ledState = LOW;               // Will store the current ON/OFF state of the LED
unsigned long previousMillis = 0; // used for timing
const long interval = 500;        // interval for the blinking LED
int tracking=1;                   // Tracking ON/OFF state
const int btn_up = 2;             // Input pin for the UP/FORWARD push button
const int btn_down = 3;           // Input pin for the DOWN/REWIND push button
int btnreadup=0;                  // Will store the UP button status
int btnreaddown=0;                // Will store the DOWN button status
int fastratio=1;                  // variable containing the ratio that will be applied to the delay between motor pulses
// the setup routine runs once when you press reset:
  pinMode(motor_step, OUTPUT);    // The 3 motor control line are set as OUTPUT
  pinMode(motor_dir, OUTPUT);
  pinMode(motor_enable, OUTPUT);
  pinMode(led, OUTPUT);           // The LED pin is also an OUTPUT...
  pinMode(btn_up, INPUT_PULLUP);  // Push button input are set as INPUT with PULLUP enable (+5V is applied with an internal resistor)
  pinMode(btn_down, INPUT_PULLUP);// And the switches will have an inverted logic = ACTIVE_LOW  (the button will apply the ground to the inputs)
// the loop routine runs over and over again forever:
    if(tracking==0) {        // If tracking is disabled...
                      digitalWrite(motor_enable,HIGH);                                    // disable the motor  (inverted logic on the driver)
                      while(digitalRead(btn_up)+digitalRead(btn_down)==2) {delay(50);     // wait until a button is pressed
        toggle_led();} // and blink fast
                      tracking=1;
          else        // IF tracking is not disabled
              digitalWrite(motor_enable,LOW);                                            // enable the motor  (inverted logic on the driver)
              unsigned long currentMillis = millis();                                     // read current timer
              if(currentMillis - previousMillis >= interval) {                            // if time has passed more than the specified interval
                              // save the last time you blinked the LED
                              previousMillis = currentMillis;                             // store the current timer
                              toggle_led();                                               // call the toggle_led() function, that will invert the LED output
             btnreadup=digitalRead(btn_up);                                               // read the button UP status, will return 0 if pressed and 1 if not (inverted logic)
             btnreaddown=digitalRead(btn_down);                                           // read the button DOWN status, will return 0 if presses, and 1 if not (inverted logic)
             if(btnreadup+btnreaddown==0) {tracking=0; delay(2000);}                      // if both the buttons are pressed (0+0=0), stop the tracking and wait for 2 sec
             if(btnreadup+btnreaddown==2) {fastratio=1;}                                  // if no button is pressed (1+1=2), set the ratio to 1
             else {fastratio=50;}                                                        // if any button was pressed, set the ratio to 800
             if(btnreaddown==1) {digitalWrite(motor_dir,LOW);}                            // if the button DOWN was pressed, invert the motor DIRECTION
             else {digitalWrite(motor_dir,HIGH);}                                         // else setp the motor to the FORWARD direction
              digitalWrite(motor_step, LOW);                                              // pulse the motor ouput LOW
              digitalWrite(motor_step, HIGH);                                             // set the motor ouput HIGH again
              delayMicroseconds(DELAY/fastratio/2);     // /2 for 1/32 microstepping      // pause the defined time, with ratio applied
             } //else
void toggle_led()        // function that inverts the LED status
 // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)        // logic that reads and invert the LED status variable
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(led, ledState);                                                          // actual toggle of the LED ouput
as link
BUTTON DIAGRAM
    btnreadup = digitalRead(btn_up);                                             // read the button UP status, will return 0 if pressed and 1 if not (inverted logic)
    btnreaddown = digitalRead(btn_down);                                         // read the button DOWN status, will return 0 if presses, and 1 if not (inverted logic)
    if (btnreadup + btnreaddown == 0)
      tracking = 0;  // if both the buttons are pressed (0+0=0), stop the tracking and wait for 2 sec
      delay(2000);
As the comment says, if both buttons are found to be pressed there should be a 2 second pause in the running of the program. Don't forget that if one or other (or both) of the buttons is still pressed at the end of 2 seconds then the values read from them will be acted upon by the rest of the code such as
    if (btnreaddown == 1)
      digitalWrite(motor_dir, LOW); // if the button DOWN was pressed, invert the motor DIRECTION
      digitalWrite(motor_dir, HIGH); // else setp the motor to the FORWARD direction
What does happen when you press both buttons at the same time ?
What do you want to happen when you press both buttons at the same time ?
sir , really thank you so much ,it is working
Please post your working code here so that anyone reading teh topic in future may benefit from your solution
