Basic blink failure
I just acquired a GIGA R1 and attempted the basic test using the standard Blink example, slightly modified to include a few Serial.println() statements.
I installed the board package and opened the Blink example, and added a few lines:
int i;
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
Serial.begin(19200);
Serial.println("Starting blink test");
// the loop function runs over and over again forever
  i++;
Serial.println(i);
digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
delay(1000);                      // wait for a second
digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
It compiles and uploads, but all I ever see in the serial window is this:
Starting Provisioning version 0.6.2
BLE Available
I also tried adding this to setup(), but still no serial output:
 while (!Serial) {};
This is the most basic test I use on every Arduino I have ever tried (for the last 20 years!).
What is wrong?
Thanks,
.Andy
Write LOW to turn it ON.
The logic for LED_BUILTIN is reversed if compared to the behavior of, for example, the Arduino UNO board. What this means is that if you write HIGH to LED_BUILTIN, the LED will turn off, and on respectively if you write LOW.
https://docs.arduino.cc/tutorials/giga-r1-wifi/cheat-sheet/
Make sure you selected the same baudrate (19200) in Arduino Monitor on the PC
Thank you, I missed that in the docs.
I realize that the reason is that the LED_BUILTIN on the Giga is just the green component of an RGB LED, and it is common anode, rather than common cathode. But this is rather counter-intuitive for what the programmer usually encounters with LED_BUILTIN. Too bad.
Is that RGB LED used by other system processes?
The datasheet (same link) suggests, only if intentional.
