Basic C++ Array question
My C++ is very rusty, trying to polish the rust off here !
I thought this code shouldnt compile for C++
int size = 5;
int array;
This seems to compile OK for me in the Arduino IDE and PlatformIO.
Setting an array size at run time is kind of handy and saves me having to struggle with
getting an STL library. Can someone clarify why this compiles without requiring
const int size = 5;
Thanks
Context, not snippets
Why does int size have to be a constant; C++ Arrays?
int size = 5;
int array[size];
Does not compile for me in the Arduino IDE
sketch_dec08d:2:15: error: array bound is not an integer constant before ']' token
 int array[size];
exit status 1
Please post comparable code that compiles
Idahowalker:
Is this a question?
OP, turn on Compiler Warnings in preferences and the compiler will complain.
When you declare an array, the array size cannot be changed by the program, so it needs to be a const int.
Some C++ compilers allow a non constant array size specifier if the array is automatic. That is, it is defined within a function. Not, however, as a global.
Thanks for the reply Helibob
That error message that you got was what I was anticipating getting, but it puzzled me by compiling OK.
The difference between mine and your example is that my quick test I put inside the setup function.
  int size = 5;
  int array[size];
That compiles OK for me, but if I move it out to a global I do get the error you show.
I am still puzzled as to why it is valid if inside setup ?
If I put those 2 lines in a function and try and compile with Visual Studio, I get the expected const error whether it is global or not
Thanks for the reply 6v6gt, my experiment just confirmed exactly what you stated. It is down to different behaviours between compilers. The sizing of an array is pretty simple and fundamental stuff, I am surprised they arent more consistent.
Thanks
geoffw123:
Because the Arduino IDE enables GCC extensions to C++:
Variable-length automatic arrays are allowed in ISO C99, and as an extension GCC accepts them in C90 mode and in C++. These arrays are declared like any other automatic arrays, but with a length that is not a constant expression. The storage is allocated at the point of declaration and deallocated when the block scope containing the declaration exits.
The MSVC compiler doesn't support this extension, but GCC does.
According to the official C++ standard, the size of an array should be a constant expression:
https://en.cppreference.com/w/cpp/language/array
Pieter
Thanks for the info, I'll use constants from now on to describe array sizes instead of just a plain old int.
If the size of array needs to be determined in the run-time, use the dynamic array.
