Basic example of UNO Q: Analog volt. to WebUI problem
I try to make a very basic app that reads an analog voltage to be displayed in WebUI (and a LCD, if connected). Everything seems to wrk well exept that the value don't show in the WebUI.
UNO-Q 2MB, windows
    Sketch:  Analog input to WebUI
    (LCD connected via voltage level translation 3,3V to 5V)
// include the library code:
#include <LiquidCrystal.h>
#include <Arduino_RouterBridge.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 7, en = 6, d4 = 1, d5 = 5, d6 = 2, d7 = 3;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int rw = 10;
int ext_input_A = 9;  // isolated input rom shield 5V
int D2_LED = 12;      // isolated output to shield 5V: D2-LED
int D3_LED = 11;      // isolated output to shield 5V: D3_LED
boolean LCD_on_ext_A = false;  // default as LOW when LCD shield is not connected
const float V_REF = 3.3;                         // 3,3V for UNO-Q inputs
const float R_BITS = 10.0;                       // number of bits ADC-resolution
const float ADC_STEPS = (1 << int(R_BITS)) - 1;  // Number of steps (2^R_BITS - 1)
int sensorValueDigital = 0;  // binary/digital value
float quotient = 0.0;        // floating point number with integer and decimal part
int intPart = 0;             // the integer part of conversion from binary to decimal value from ADC: A0
float decimal_part = 0.0;
int desimal_as_int = 0;
  Bridge.begin();
  Monitor.begin();
  pinMode(rw, OUTPUT);
  digitalWrite(rw, LOW);
  pinMode(ext_input_A, INPUT);
  LCD_on_ext_A = digitalRead(ext_input_A);
  if (LCD_on_ext_A == true) {  // LCD shield connected?
    // ---------------LCD 40x2 setup --------------------
    lcd.begin(40, 2);
    delay(3000);  // wait for LCD to start up
    lcd.setCursor(0, 0);
    delay(50);
    lcd.print("UNO-Q: Analog voltage from A0, ");
    delay(30);
    lcd.print(int(R_BITS));
    delay(30);
    lcd.print(" bits: ");
    delay(50);
    //Monitor.println("LCD is connected. ");
  pinMode(D2_LED, OUTPUT);    // (leds can be used for extra info)
  digitalWrite(D2_LED, LOW);  // shield-5V: D2-LED off
  pinMode(D3_LED, OUTPUT);
  digitalWrite(D3_LED, LOW);  // shield-5V: D3-LED off
  // main code run repeatedly:
  delay(5000);
  digitalWrite(D2_LED, HIGH);  // shield-5V: D2-LED ON
  sensorValueDigital = analogRead(A0);
  // asynchronous notification
  Bridge.notify("sensor_data", sensorValueDigital);  // send binary value to main.py
  Monitor.print("ADC bin value: ");
  Monitor.println(sensorValueDigital);  // check the value in Serial Monitor
    printOut_LCD();  // convert and print to LCD
  delay(2000);
// convert the binary value to two integer numbers separated by a decimal point
// and print to LCD
void printOut_LCD() {
  quotient = (sensorValueDigital / ADC_STEPS) * V_REF;  //  floating point number with integer and decimal part
  intPart = (sensorValueDigital / ADC_STEPS) * V_REF;   //  the integer part of the conversion
  decimal_part = quotient - intPart;                    //  the decimal part of the conversion
  desimal_as_int = decimal_part * 1000;                 //  move the decimal point; keeping three digits, and convert to integer
  lcd.setCursor(0, 1);
  delay(50);
  lcd.print("                                        ");  // delete previous content in row
  delay(30);
  delay(50);
  lcd.print(intPart);  // integer part: (x,---)
  delay(30);
  lcd.print(",");
  delay(30);
  if (desimal_as_int < 10) {
    lcd.print("00");
    delay(30);
    lcd.print(desimal_as_int);  // thousandths: (-,00x)
    delay(30);
  } else if (desimal_as_int < 100) {
    lcd.print("0");
    delay(30);
    lcd.print(desimal_as_int);  //  hundredths and thousandths: (-,0xx)
    delay(30);
    lcd.print(desimal_as_int);  // tenths, hundredths and thousandths: (-,xxx)
    delay(30);
  lcd.print(" Volt");
  delay(3);
python:
import time
from arduino.app_utils import App, Bridge
from arduino.app_bricks.web_ui import WebUI
# initialize WebUI
web_ui = WebUI()
print("Hello world!")
def sensor_data_callback(value):
  # Prosess the data if needed
  print(f"Received from sketch: ", {value})
  # Send the data to the web UI using the same key/event name
  web_ui.send_message('sensor_data_update', value)
# Register the callback function with the Bridge
Bridge.provide("sensor_data", sensor_data_callback)
def loop():
    time.sleep(1)
App.run(user_loop=loop)
# See: https://docs.arduino.cc/software/app-lab/tutorials/getting-started/#app-run
app.js:
let errorContainer;
 * Socket initialization. We need it to communicate with the server
 * <script src="app.js"></script>
const socket = io(`http://${window.location.host}`); // Initialize socket.io connection
// Start the application
document.addEventListener('DOMContentLoaded', () => {
    errorContainer = document.getElementById('error-container');
    initSocketIO();
function initSocketIO() {
  socket.on('connect', () => {
      if (errorContainer) {
          errorContainer.style.display = 'none';
          errorContainer.textContent = '';
  socket.on('sensor_data_update', (value) => {
    updateValue(value);
  socket.on('disconnect', () => {
      errorContainer.textContent = 'Connection to the board lost. Please check the connection.';
      errorContainer.style.display = 'block';
function updateValue(bin_value) {
  console.log("Received binary value: ", bin_value);
  document.getElementById("my-text-box").textContent = bin_value;
  //valueTxtBox.textContent = status;
index.html:
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>Analog input to web UI</title>
</head>
<body>
    <h1>Binary code value: <span id="my-text-box">n/a</span></h1>
    <script src="libs/socket.io.min.js"></script>
</body>
</html>
I have run your app in my App Lab 0.4.0 and it works well. I have connected 3.3/2 = 1.65 V at A0-pin and the UI shows the following which seems to be alright:
==> (1023/3.3) x 3.3/2 = 512
Thank you for helping. Could I have a problem because of the browser; Microsoft Edge Beta?
What is your setup?
My setup:
IBMPC WIN10
App Lab 0.4.0
UNO Q
I have copied an app from the examples of App Lab and then have deleted sketch, python, js, html. After that I have just copied your codes from #1 into the appropriate locations of the editor and then have clicked on the RUN button. Your app is working!
A miracle has happened!!!
I tried to do like you: deleted all content in a app copy and pasted my code instead and now it works.
Thank you a lot! I have struggeled with this for weeks...
This is the joyful moment when something works!
@ptillisch may explain why is the app working this way.
