I tried to trim it down to the relevant area... but here it is:
// include the library code
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(4, 5, 6, 7, 8, 10);
// LCD RS pin to digital pin 4
// LCD EN pin to digital pin 5
// LCD D4 pin to digital pin 6
// LCD D5 pin to digital pin 7
// LCD D6 pin to digital pin 8
// LCD D7 pin to digital pin 10
// select the input pin for the pot
const int potPin = 0;
// select the pin from which to output to the four H-Bridge transistor Base legs
const int r1PinYellow = 9; // a PWM output pin
const int r2PinBlue = 2;
const int r3PinOrange = 11; // a PWM output pin
const int r4PinWhite = 3;
// H-Bridge Motor Control
// COMMAND Q1 Q2 Q3 Q4
// coast/roll/off LOW LOW LOW LOW
// forward LOW *HI* *HI* LOW
// brake/slow down *HI* LOW *HI* LOW
// reverse *HI* LOW LOW *HI*
// select the pin for the pushbutton switch
const int s1Pin = 12;
// variable for reading the pushbutton status
int buttonState = 0;
// previous state of the button
int lastButtonState = 0;
// variable to store peak value in loop() function
int peakValue = 0;
// initialize the pushbutton pin as an input:
pinMode(s1Pin, INPUT);
// turns on the pullup resistor
digitalWrite(s1Pin, HIGH);
// declare pins driving the transistor Base legs as OUTPUT
pinMode(r1PinYellow, OUTPUT);
pinMode(r2PinBlue, OUTPUT);
pinMode(r3PinOrange, OUTPUT);
pinMode(r4PinWhite, OUTPUT);
// Begin by turning the motor OFF
analogWrite(r1PinYellow, 0);
digitalWrite(r2PinBlue, LOW);
analogWrite(r3PinOrange, 0);
digitalWrite(r4PinWhite, LOW);
// set up the LCD's number of columns and rows
lcd.begin(16, 2);
// display intro message #1
// center text -- Column 4, Row 0 (top row)
lcd.setCursor(4,0);
lcd.print("TAKAIR");
// center text -- Column 2, Row 1 (bottom row)
lcd.setCursor(2, 1);
lcd.print("Electronics");
delay(3000);
// print intro message #2
// clear the LCD and position cursor @ top-left
lcd.clear();
// top row message
lcd.print("Press Switch To");
// set the cursor to bottm row (column 0, line 1)
lcd.setCursor(0, 1);
// bottom row message
lcd.print("Start");
// read the pushbutton input pin
buttonState = digitalRead(s1Pin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == LOW) {
// if the current state is HIGH then the button
// went from off to on:
// call the findPeak() function and store result
peakValue = findPeak();
// print peakValue to LCD
// bottom row formatting: Temp=xxx Pk=xxx
// set the cursor to bottom row (column 9, line 1)
lcd.setCursor(9, 1);
lcd.print("Pk=");
lcd.setCursor(12,1);
lcd.print(peakValue, DEC);
// call the turnMotorReverse() function
turnMotorReverse(peakValue);
// if the current state is LOW then the button
// went from on to off: DO NOTHING
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
void turnMotorForward()
// MOTOR FORWARD
// Clear the LCD and position cursor @ top-left
lcd.clear();
// Print a message to the LCD.
// top row message
lcd.print("Leaning: Mtr FWD");
digitalWrite(r2PinBlue, HIGH);
analogWrite(r3PinOrange, 200); // 127 for small motor
void turnMotorReverse(int peak)
int potVal = 0;
int targetVal = peak - 50;
// print targetVal
// Serial.print("targetVal is ");
// Serial.println(targetVal, DEC);
// Position cursor @ top-left
lcd.setCursor(0,0);
// top row message
lcd.print("Stby to Enrich..");
// Position cursor to overwrite Pk=xxx
// Display Tv=xxx instead (Target Value)
// bottom row formatting: Temp=xxx Tv=xxx
lcd.print("Tv=");
lcd.print(targetVal, DEC);
// stop the motor first
lcd.setCursor(0,0);
// top row message
lcd.print("Riching: Mtr OFF");
// wait half a second
// begin motor reversal
lcd.setCursor(0,0);
// top row message
lcd.print("Riching: Mtr REV");
delay(50);
analogWrite(r1PinYellow, 140); // 60 for small motor
digitalWrite(r4PinWhite, HIGH);
// read potVal [while turning motor] until it equals targetVal
while (potVal != targetVal)
// read pot value
potVal = analogRead(potPin);
// remap to a 0 to 255 range
potVal = map(potVal, 0, 1023, 0, 255);
// print out the value to LCD
lcd.print("Temp=");
lcd.setCursor(5,1);
lcd.print(potVal, DEC);
// small delay
delay(10);
// stop motor
lcd.setCursor(0,0);
// top row message
lcd.clear();
// top row message
lcd.print("Set Fuel Mixture");
int findPeak()
// variable to store whether the peak has been detected
int peakNotFound = 1;
// variable to store new values from the pot
int newVal = 0;
// variable to store current values from the pot
int val = 0;
// variable to store the peak value
int peak = 0;
while (peakNotFound)
// call the turnMotorForward() function
turnMotorForward();
if (newVal >= val || (val-newVal) < 3)
// keep on reading the potentiometer...
val = analogRead(potPin);
val = map(val, 0, 1023, 0, 255);
// LCD was cleared in turnMotorForward()
lcd.print("Temp=");
lcd.setCursor(5,1);
lcd.print(val, DEC);
// small delay
// read the analog input into the "newval" variable
newVal = analogRead(potPin);
newVal = map(newVal, 0, 1023, 0, 255);
delay(10);
// print out the value to Serial Monitor
// Serial.print(" newVal is ");
// Serial.println(newVal, DEC);
else // peak has been detected... exit "while" loop
// store the latest val into peak
peak = val;
// peakNotFound is now false
peakNotFound = 0;
// return the value of peak to main program
return peak;
