Beginner stopwatch
Hello! I'm a beginner in using arduino and currently trying to build a stopwatch with a button that stop/starts the timer, but got really stuck at the moment, for now I've been trying to use tinkercad before actually using the real components since I thought I'd be a better idea. I've been following this tutorial https://www.youtube.com/watch?v=kVBe3pCWCHA&t=108s.
It consists of using 1 pushbutton, 1 10000 kΩ Potentiometer, 1 Arduino Uno R3 and an 1 Arduino Uno R3
The current issue is that upon running the code the lcd does nothing even after uploading the code or pressing the button, here's the schematic I made on tinkercad:
The code I've been using:
#include <LiquidCrystal.h>
#define button 2
int timerMode = 0;
long startTime;
LiquidCrystal lcd(7,8,9,10,11,12);
  lcd.begin(16,2);
  lcd.clear();
  pinMode(button, INPUT_PULLUP);
  lcd.print("Press to start:");
  lcd.setCursor(0, 1);
  if (digitalRead(button) == LOW) {
    startTime = millis();
    timerMode++;
    delay(400);
  if(timerMode == 1) {
    lcd.setCursor(0,1);
	lcd.print((millis() - startTime) / 1000.0);
  if (timerMode > 1) {
    delay(2000);
    timerMode = 0;
    lcd.clear();
    lcd.print("Press to start");
If anyone could help or perhaps tweak the schematic I've been making that would be a really huge help, this is the link: Circuit design Stopwatch - Tinkercad
Try one of the example sketches from the <LiquidCrystal.h> library to test if your display is connected properly and is not faulty.
Show a picture of your LCD connections and make a wiring diagram that shows pin numbers.
Your code works. Check wiring.
Files for WOKWI.COM
sketch.ino
#define button 2
int timerMode = 0;
long startTime;
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
  lcd.begin(16, 2);
  lcd.clear();
    timerMode++;
    delay(400);
  if (timerMode == 1) {
    delay(2000);
    timerMode = 0;
    lcd.clear();
diagram.json
  "version": 1,
  "author": "Anonymous maker",
  "editor": "wokwi",
  "parts": [
    { "type": "wokwi-arduino-nano", "id": "nano", "top": -4.8, "left": -38.9, "attrs": {} },
    { "type": "wokwi-lcd1602", "id": "lcd1", "top": -207.77, "left": -89.6, "attrs": {} },
      "type": "wokwi-pushbutton",
      "id": "btn1",
      "top": -51.4,
      "left": 153.6,
      "attrs": { "color": "green" }
  "connections": [
    [ "lcd1:RS", "nano:7", "green", [ "v57.6", "h57.9" ] ],
    [ "lcd1:E", "nano:8", "green", [ "v9.6", "h-28.8" ] ],
    [ "lcd1:D4", "nano:9", "green", [ "v19.2", "h-96" ] ],
    [ "lcd1:D5", "nano:10", "green", [ "v28.8", "h-105.5" ] ],
    [ "lcd1:D6", "nano:11", "green", [ "v38.4", "h-124.6" ] ],
    [ "lcd1:D7", "nano:12", "green", [ "v48", "h-143.7" ] ],
    [ "nano:2", "btn1:1.l", "green", [ "v0" ] ],
    [ "nano:5V", "lcd1:A", "red", [ "v-105.6", "h-9.5" ] ],
    [ "nano:GND.1", "btn1:2.l", "black", [ "v0" ] ],
    [ "nano:GND.1", "lcd1:K", "black", [ "v-115.2", "h-19.2" ] ]
  "dependencies": {}
I keep checking but everything looks fine, perhaps the potentiometer could be the issue?
Remove the potentiometer and try again.
A wire was in the +zone instead of the - actually and I fixed that, now the connection to the lcd is made but we're apparently getting too much backlight, I checked a lot and I really cannot see anything else wrong, any ideas? Is it that this potentiometer in tinkercad has all its 3 terminals in the front instead of 2 in the front and 1 in the back and I didn't place the wires for it right?
Yes. You are not verifying the wiring is correct.
Check that your LCD wiring is similar to the following (Fig-1):
Figure-1:
Please post photos of your setup.
Some breadboards have split power rails. You may need to install jumpers to connect and complete the rails.
Start by just using the lcd example from the library and twiddle the pot to get the best readability .
When that works try your stopwatch .
