Hello dear Arduino community,
I riddle which kind of infinite loop is better? Are there any differences at all (because of the optimization)?
for( ; ; ) {
// any code
... or ...
while( true ) {
// any code
Many thanks in advance!
for( ; ; ) {
// any code
... or ...
while( true ) {
// any code
No. Because the body is empty the optimizer excises both of them equally.
Use the one that makes the most sense to you. The one that, a year from now, says "infinite loop" to you.
#define EVER (;;);
for EVER
;D
This community rocks! 8)
#define ever (;;)
for ever {
thank(CodingBadly && AWOL);
void loop(){}
KenF:
void loop(){}
Yes, this is an infinite loop, but you can't do multiple ones, or can you? But thank you for the good will providing another answer to my question! ![]()
Since I didn't mention it in my start posting: After connecting the Arduino into the PCs USB port, I want to run a specific main loop, which can be selected by a dip switch. Since there is no need to switch to another main loop at run time, I simply jump to the desired one when entering "loop()" for the first time. This way I can save some computation time, since I don't have to use "switch()" or "if()" on every cycle.
Brduino:
If any loop is infinite, there's no time for another ![]()
byte breakout = 0;
void setup(){
// read dip swithches or something to determine which segment to run
void loop(){
switch(segment){ // jump to a segment & stay there
case 0:
while (breakout==0){
// infinite loop 0
case 1:
// infinite loop 1
case 99:
// infinite loop 99
} // end switch - but each while will never exit unless the code segment sets breakout = 1;
// could also change segment to jump to another section - becomes like a state machine
} // end loop
Thanks CrossRoads! Your code nearly looks like mine, except that I saved the comparation "breakout==0", since the state doesn't need to be changed at runtime. (I'm currently hunting down a semicolon bug, so I didn't post the code, yet ...at least I guess it's a semicolon bug)
KenF:
Only true if no break is present and they are not nested. ![]()
(well... of course only the most inner one is really looping...)
Aw, man, AWOL...you stole my thunder!! ![]()
That is not correct. Sorry about the mistake.
The second sentence still stands.
