I’m working on an Arduino-based project where I collect sensor data (temperature, humidity, and voltage) and want to display it on a simple web dashboard for monitoring and analysis.
I’m currently exploring different approaches such as:
Using Arduino with ESP8266/ESP32 to host a basic web server
Sending data to a local server or cloud service via HTTP or MQTT
Structuring the data efficiently for real-time updates
My main goals are:
Reliable data transmission
Lightweight and stable setup
Easy-to-understand code for long-term maintenance
I’d really appreciate advice on:
Recommended libraries or frameworks
Common pitfalls to avoid
Whether a local dashboard or cloud-based solution works better for small projects
Thanks in advance for your guidance. I’m looking forward to learning from your experience.
I use ESP8266 based sensors to send sensor readings like those you mentioned to my home server. The server stores them on an SQL database and they can be viewed on web pages as graphs & tables.
This means that the sensors can be small and battery powered, spending most of their time in deep sleep mode to extend the battery life.
The above is a good way if you want to learn about Arduino, C++, REST APIs, SQL databases, PHP scripts, HTML, SVG etc.
But if not interested in those things, there are other ways using available apps such as Home Assistant
There are many ways to display measurements on a website, depending on your needs. Maybe this simple solution, which only requires an ESP32, can be one of the options to consider:
