I have an ESP32 powered epaper display. I'd like to display.print letters with strikethrough and I'm looking at ways to achieve this.
I could create a custom set of letters (e.g. using https://tchapi.github.io/Adafruit-GFX-Font-Customiser/ ) - but is there a better option? e.g. being able to draw a line through text - although i'd only want it to be the width of the sentance, which may change.
ec2021
February 18, 2025, 3:28pm
2
Hi @jimbo101 ,
welcome to the forum!
I think it's a tradeoff between
additional memory consumption and time to create the font and
effort to implement a strike-through routine
In a different thread related to tft displays I used this function
tft.getTextBounds(stringText, x,y, &x1, &y1, &w, &h);
to get the boundary coordinates of a given string.
If that's available for your epaper it might be a reasonable (and interesting ) solution to develop a function.
ec2021
Thanks, much appreciated. I will have a play with this function later to see if I can get it to work for my use case and report back!
ec2021
February 20, 2025, 4:59pm
4
Welcome!
If you use proportional fonts the different characters have specific widths. This is taken care of by the getTextBounds() function.
I have prepared an example for a tft display:
https://wokwi.com/projects/423332516171588609
Forum: https://forum.arduino.cc/t/best-way-to-print-letters-with-strikethrough/1355282
Wokwi: https://wokwi.com/projects/423332516171588609
2025-02-20
ec2021
Realization of a simple "Strike Through" function for TFT displays
Known limitation: String must fit in one line
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#define TFT_DC 9
#define TFT_CS 10
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
void Print(String txt, int atX, int atY, int tSize, uint16_t col){
int boxX, boxY, width, height;
tft.setCursor(atX, atY);
tft.setTextColor(col);
tft.setTextSize(tSize);
tft.println(txt);
tft.getTextBounds(txt,atX,atY, &boxX, &boxY, &width, &height);
tft.drawFastHLine(boxX,boxY+height/2,width,col);
tft.begin();
tft.setRotation(0);
Print("Strike Through",10,10, 1, ILI9341_RED);
Print("Strike Through",10,30, 2, ILI9341_BLUE);
tft.setRotation(1);
Print("Strike Through",10, 120, 3, ILI9341_GREEN);
The example does not deal with text wrapping ...
Good luck!
ec2021
system
Closed
August 19, 2025, 4:59pm
5
