I'm a c# guy, so I need some opinions on how to best accomplish this in arduino c/c++:
I have a class library (is that the correct term? A .h and .cpp file that defines a class). Let's call it ClassA. And then I have another class library (from an external part), lets call it ClassB.
ClassA is to use some methods in ClassB in a few places.
What I've done now is, in ClassA i included ClassB.h, and in the constructor of ClassA I pass an instance of ClassB that is stored as a private variable in ClassA. Like so:
Is this a good way of doing it? Will _b in ClassA be a reference to the instance of ClassB that is passed?
Is there a better way of doing this?
I'm thinking it would be neater to pass a reference to the method of ClassA, instead of the class, so then ClassA could be any method of any object that does the work I want... And then ClassA wouldn't need to have a reference to ClassB. But I have not managed to figure out how to do this, pass a reference and store the reference to a method in a private variable, there's too much * and & and () going on...
Fredrik:
No, because you haven't declared the variable as a reference (that is there is no "&" symbol there). It will be a copy, and how good a copy depends on your copy constructor, or your operator=.
Fredrik:
Almost certainly. What are you ultimately trying to achieve here?
I am using a shield that handles more pins than the regular arduino, so instead of the regular globally available digitalRead() I have to call XX.digitalRead(), a method of instance of the class that handles the pins for my shield.
I am developing some classes of my own to use, for example a Button class, that takes care of the state of the buttons for the pins of the shield, debouncing and stuff. So, I want to create an amount of instances of my button class, one for different pins, and then I want the button to read the pin, which has to be done via a call to XX.digitalRead().
So, that's what I'm trying to achieve.
So I realized i could use the keyword "extern XX" to achieve the same thing as the globally available digitalRead(), but that's a bit too ugly I think.
If XX is an instance of a class, that probably won't work, anyway.
Enough of the handwaving. Post your actual code, and we'll help you modify it is pass things properly by reference.
I tried it out, it did indeed work!
Thanks, ok, I'll try to get it sorted out a bit and post something.
I just thought this would be like a very obvious thing to do... one class that uses functionality provided by another... But maybe I'm thinking the wrong way.
No, that happens all the time. Generally, one class would get a pointer to an instance of the other class. Since pointers are limited on the Arduino (there being no new operator that would generally be used to create a pointer to an instance of a class), objects are created, rather than pointers to objects. Without a pointer to pass around, a reference to the object is passed around, instead.
References are a little more challenging to set up and use, but they are then almost the same as pointers (except for using . instead of ->).
#include <Wire.h>
#include <Centipede.h>
#include <SBButton.h>
Centipede CS;
SBButton stepButtons[STEPCOUNT] = {SBButton(16),SBButton(31),SBButton(17),SBButton(30)};
(initialization etc removed....)
for (int i = 0; i < STEPCOUNT; i++){
if (stepButtons[i].stateChanged()){
Serial.println("State changed");
So, the extern Centipede CS statement in SBButton::stateChanged gives me access to the Centipede instance in my scetch, but naturally it's a quite ugly solution. I would like to make something nicer and more reusable. On the other hand, if that comes with unreadable * & code or overhead, maybe I should settle with this, I guess it's quite efficient...
Well, I guess "unreadable" is in the eye of the beholder.
Do you need access to the Centipede object in the sketch? If not, you could declare the Centipede object as a private class member, and not have to worry about passing the object to the SBButton instances.
If you do, then you need to pass (a reference to) the Centipede object to the SBButton constructor, and save that reference in the SBButton class, as a private member.
You can (more easily) create, in the SBButton class, a pointer to the Centipede object, and initialize that pointer in the constructor, from a reference:
// Header
class SBButton
public:
SBButton(Centipede *pCent, int pin);
private:
Centipede *_pCent;
int _pin;
// Source
SBButton::SBButton(Centipede *pCent, int pin)
_pCent = pCent;
_pin = pin;
// Sketch
Centipede CS;
SBButton someButton(&CS, 14);
Finally, you could possibly derive your class from the Centipede class, so that SBButton would inherit the digitalRead() method. I don't know if this would be advantageous or not.
If you pass a pointer around, that might save a lot of mucking around.
As PaulS says, though, in a constructor of one class you can initialize a reference to another class, however you need to be aware of static initialization orders then.
Great, that was exactly what I was looking for, tried to create this the other day, but I failed to put the *:s and &:s in the right place. This is a nice clear example, super, thanks!
The Centipede class will be used by other classes I'm creating as well, a similar class like the button-class but for handling Led:s. And centipede has an initialize function that needs to be executed before the Buttons and Leds can start their work, so I guess doing this in the scetch and passing it on is good and flexible.
Accessing the methods of the referenced class instance in the example by PaulS has to be done with "->" not "."
I'd have mentioned that, but I thought it was obvious. I've been using C++ for 15 years, and I still don't have a good answer for why dereferencing an object and dereferencing a pointer use different operators. They just do.
Yeah, well, to a c#/javascript guy like me, pointers and references, the * & syntax, and things like -> instead of . is a bit tricky.But I realize that is because it is advanced stuff that offers great potential, I just need to study it some more.
But then, the fact that arduino is "a bit" different, and lacks "new" (and other things?) makes me go hmm, is it c, c++ or arduino/avr c/c++ I am supposed to study... What code examples that I find out there works in the arduino and what does not, you know, and the arduino manual is a dead end when it comes to describing this.
