Lundin:
Hi Mike.. hope you've gotten this straight since it was some time you posted the questions.. if not.. check this out
This is another method of tieing "dht_pin" to the physical pin.. ( check up on # define in Arduino glossary)
if i remember corrrectly the compiler treats the "#define" command differently than the regular way and this might be better to use in some situations.. i haven't read up on it though as i got my projects running and haven't had reasons to code it differently.
I almost gave up and just happened to come back here. THANKS for the explanation. Let me start again with this project.
hello Billies, very good its design, unfortunately happened to me this error in time to check the code before sending to the controller, you can help me, thank you Claudio
Arduino: 1.6.5 (Windows 7), Placa:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Opções de compilação alteradas, recompilando tudo
C:\arduino-1.6.5-r2\libraries\UTFT\DefaultFonts.c:21:14: error: variable 'SmallFont' must be const in order to be put into read-only section by means of 'attribute((progmem))'
fontdatatype SmallFont[1144] PROGMEM={
C:\arduino-1.6.5-r2\libraries\UTFT\DefaultFonts.c:125:14: error: variable 'BigFont' must be const in order to be put into read-only section by means of 'attribute((progmem))'
fontdatatype BigFont[3044] PROGMEM={
C:\arduino-1.6.5-r2\libraries\UTFT\DefaultFonts.c:234:14: error: variable 'SevenSegNumFont' must be const in order to be put into read-only section by means of 'attribute((progmem))'
fontdatatype SevenSegNumFont[2004] PROGMEM={
Erro compilando.
Este relatório deveria ter mais informações
"Mostrar saída verbosa durante a compilação"
habilitado em Arquivo > Preferências.
Is there some code that you can include to sense whether it is marijuana that is being cultivated and then disable the watering if this is the case? My concern is that this could fall into the hands of druggies.
pH değeri ölmek için bir sensör kullanılmış ama suyun EC değerini nasıl kontrol ediyoruz? Bunun için herhangi bir sensör kullanılmıyor mu, internette analog ec meter diye bazı sensörler buldum ama gerek yok mu anlayamadım ?
So I got the freezing issue taken care of, but have been beating my head on the desk for a while now. The touch buttons do not do anything. I changed to the 1_1_0 version to no avail. All my libraries look up to date and correct, and it has no problem compiling. Thoughts?
Actually, The touch buttons do kind of function, but they are reversed, and are not on spot. Almost like they are not calibrated. I even tried plugging the TFT straight into the shield to account for any OE. Basically if I hit where the PH control button should be, it takes me to the Manual tank control. If I touch the manual tank button, it takes me to the ph control, and the up and down button don't function. Anyone possibly give me a few pointers?
well i read many about this project, its sounds really good, i think i understand all to star working, except how to connect the 3.2" TFT LCD Shield, anyone can help me with that please? Thank you so much!!!
hello, I solved the above compilation error by moving the libraries to the correct space.
this being said the compilation works fine but there is nothing that happens when the sketch is uploaded to the Mega.
I would like to just start by getting the PH sensor to output correct PH values to a serial terminal.
I don't exactly see how this is supposed to work when there is no #include(phidgits21.h) in the start code.
what library is this sketch using to utilize the PH phidgit sensor?
and if at all possible what lines in the sketch are seting the parameters?
Hydroponic_Controller:1549: error: 'class DateTime' has no member named 'get'
seconds_elapsed_total = now.get() - start_time;
exit status 1
Thank you
So are you still interested in working with this. it seems no one is following up on this. it looks like it was outdated and other projects in the ether have become more relevant so I have decided to recode and wok with this. I will try and post to here but think I will start with a new build thread as I am not going to work this the same way as the original poster. this will be a lab grade ph adjustment controller. if you would like to work with me PM me and we can tsk parts of this build and work together.
I have started by asking the simplest question.
How do I get these or similar items (shields and phidgets) to work just by them selves?
Going to start first with the pH Phidget 1130.
(Because it is the most important to me.)
So first thing. Phidgets are a little different in the way they report data back to the device.
I originally found good info about this here Phidgets and Arduino - Sensors - Arduino Forum
ill give a thanks to that user. (mapiram)
you will need the above info so look at it. I'm not gonna re write it because looking for information will strengthen your understanding in the end. so even though I have given you the place to look you still have to put a little effort in to get and understand the info.
your welcome.
Please make sure you understand how to utilize the Arduino before attempting a project. I like www.udemy.com courses but there are plenty of free resources out there. But remember when you pay for something you can expect support.
If you don't understand the other post ask and ill address your issue.
So back to the Phidgets pH 1130 and interfacing to your Arduino.
I stated by grabbing a set of jumper wires.
Red = 5v
Black = GND
White = Read (this will go on my A0 pin on my Mega)
I hooked my device through a bread board. When looking at the pics to ignore the wires I don't mention.
your welcome.
Red = 5v
Black = GND
tfixa:
Does anyone have the updated code? or where to get it from along with the libraries? Thanks.
This looks to be out dated, the original author doesn't seem to be following the thread.
This is why I have began to rebuild the project.
If interested in working on it let me know. Also you can find current garden control systems on the Instructables Web site.
Good luck.
everone:
thanks
@everone can you share the correct lib file that you used to compile this Hydroponic_Controller_v1_1_2b.ino. thanks for any help.
