Hello experts,
I am rather new to the Arduino so any help is much appreciated. I am sure there are other forum questions about this but i have been searching without any luck.
I am trying to turn on 16 LEDs individually using 2 74HC595 shift registers using the serial monitor. So the flow would be:
Serial monitor prompts user for which LED (0-15) to turn on
Input gets analyzed and single LED turned on
Repeat this process until a "x" character is entered to clear the data registers.
My issue is that when i reach ch = 8 (or the Q0 bit of the second register, i do not get the LED to turn on). Additionally, when i enter a value of '10', I get two entries - ch =1 and ch = 0.
Thoughts on how to make this work???
The code that I initally referenced is here...
int latchPin = 5;
int clockPin = 6;
int dataPin = 4;
byte leds1 = 0;
byte leds2 = 0;
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
updateShiftRegister();
while (! Serial);
Serial.println("Enter LED Number 0 to 15 or 'x' to clear");
if (Serial.available())
int ch = Serial.read();
Serial.print("ch = ");
Serial.println(ch);
if (ch >= 48 && ch <= 56) // betweeon 0 and 7 in integer
int led = ch - '0';
bitSet(leds1, led);
Serial.print("Turned on LED ");
Serial.println(led);
if (ch >= 57 && ch <= 64) // betweeon 8 and 16 in integer
int led = ch - '0';
bitSet(leds2, led);
if (ch == 'x')
leds1 = 0;
Serial.println("Cleared");
void updateShiftRegister()
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, leds2);
shiftOut(dataPin, clockPin, MSBFIRST, leds1);
digitalWrite(latchPin, HIGH);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Hello experts,
int latchPin = 5;
int clockPin = 6;
int dataPin = 4;
byte leds1 = 0;
byte leds2 = 0;
while (! Serial);
Serial.println(ch);
int led = ch - '0';
bitSet(leds1, led);
int led = ch - '0';
bitSet(leds2, led);
if (ch == 'x')
leds1 = 0;
Moderator edit:
tags added.
When you send "10" from serial monitor, 2 characters are sent, '1' and '0'. Receiving 10 requires 2 reads. The serial input basics tutorial shows how to receive multi digit numbers.
Give this a try:
int latchPin = 5;
int clockPin = 6;
int dataPin = 4;
unsigned int leds;
while(!Serial);
leds = 0;
#define BUFF_SIZE 5
int
ch;
int
idx;
char
*ptr,
chIncoming[BUFF_SIZE];
idx = 0;
do
if( Serial.available() > 0 )
ch = Serial.read();
if( ch >= '0' && ch <= '9' || ch == 'x' )
chIncoming[idx] = (char)ch;
idx++;
if( idx > BUFF_SIZE-1 )
idx = BUFF_SIZE-1;
}//if
}//if
}while( ch != 0xa );
chIncoming[idx] = 0; //null termination
if( strchr( chIncoming, (int)'x' ) )
leds = 0;
}//if
ch = (unsigned int)strtol( chIncoming, &ptr, 10 );
if( ch >=0 && ch<=15 )
Serial.print("Adding LED "); Serial.println(ch);
leds |= (1<<ch);
Serial.print("Bit Pattern: 0b");
for( int i=0; i<16; i++ )
Serial.print( (leds & (1<<(15-i)))?"1":"0" );
}//if
}//else
}//loop
digitalWrite( latchPin, LOW );
shiftOut( dataPin, clockPin, MSBFIRST, ((leds >> 8) & 0xff) );
shiftOut( dataPin, clockPin, MSBFIRST, (leds & 0xff) );
digitalWrite( latchPin, HIGH );
}//updateShiftRegister
As for LEDs in the 2nd register not showing up, double-check your wiring, connections and power.
Cross posted in Project Guidance. Don't cross post. Cross posting wastes member's time.
