I am trying to output a bitmap to the ssd1306 screen in Wokwi.
The bitmap is stored in a static field of the class. Output occurs using a class method, which is passed a display object as a parameter. The problem is that instead of the normal bitmap output, I get a crooked drawing.
Main file code:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "SomeClass.h";
Adafruit_SSD1306 display(128, 64, &Wire, -1);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;);
display.clearDisplay();
SomeClass::drawBitmap(display);
display.display();
SomeClass.h file code:
#ifndef SOMECLASS_H
#define SOMECLASS_H
class SomeClass {
public:
static void drawBitmap(Adafruit_SSD1306& display) {
display.drawBitmap(10, 10, sprite, 8, 8, SSD1306_WHITE);
static const unsigned char sprite[8];
static const unsigned char SomeClass::sprite[8] {
B11111111, // Рядок 1 (верхній рядок)
B10000001, // Рядок 2
B10000001, // Рядок 3
B10000001, // Рядок 4
B10000001, // Рядок 5
B10000001, // Рядок 6
B10000001, // Рядок 7
B11111111
#endif
Also, when I try to display the bitmap obtained from the SomeClass sprite field in the loop() function like "display.drawBitmap(10, 10, SomeClass::sprite, 8, 8, SSD1306_WHITE)", it is also displayed crookedly. What could be the problem?
Does it display how you want if you do everything outside of a class? If so, post the code that does that.
Here's the code without using the class
#include <Wire.h>
unsigned char sprite[8] {
B11111111,
B10000001,
B10000001,
B10000001,
B10000001,
B10000001,
B10000001,
B11111111
for(;;);
display.display();
This code outputs the bitmap as it should
If I pass an array from the SomeClass instead of the local one to the drawBitmap function, it will also be drawn crookedly
See if doing the following helps:
Remove the extraneous semicolons (';') from the end of all #include statements.
Move the definition of sprite from the .h to a separate .cpp file.
Remove the 'static' attribute from the definition but not the declaration.
SomeClass.h:
#ifndef SOMECLASS_H
#define SOMECLASS_H
#include <Arduino.h>
class SomeClass {
public:
#endif
SomeClass.cpp:
B11111111
Same result, the bitmap is not displayed as it should be
Next I would start instrumenting the library's source code with print statements to track down the difference between the class and non-class cases.
jimLee
April 2, 2024, 7:37pm
7
Post a link to your Wokwi project. Then we can see EXACTLY what's going on.
-jim lee
b707
April 2, 2024, 9:12pm
9
try
display.drawBitmap(10, 10, SomeClass : : sprite, 8, 8, SSD1306_WHITE);
b707
April 3, 2024, 7:52am
13
To test purpose, try with using the class, but with sprite as independent array and not a class member
In this case, the sprite is also displayed incorrectly
unsigned char someSprite[8] = {
B11111111,
B10000001,
B10000001,
B10000001,
B10000001,
B10000001,
B10000001,
B11111111
display.drawBitmap(10, 10, someSprite, 8, 8, SSD1306_WHITE);
jimLee
April 4, 2024, 4:05am
15
In your class, why are you making things static?
I mean, there are reasons to do this, but typically they are rare. Like building a fast car then leaving the driver's seat laying next to it on the road.
It doesn't matter if the class members have the static attribute, the bitmap still renders poorly. Although really, I'm primarily interested in storing and using a bitmap in a non-static field
b707
April 4, 2024, 9:15am
17
To work with bitmap you need to instantiate a SomeClass object first.
Could you try this
#include <Wire.h>
SomeClass sc; // <<<<< instantiate of SomeClass object
for(;;);
sc.drawBitmap(display); // <<<<<<< call drawBitmap as an object method
display.display();
All the same, the bitmap displays crookedly. Although it's a little different
b707
April 4, 2024, 9:47am
19
Could you try another variant ?
The loop() (the rest of the file without changes)
sc.drawBitmap(&display);
display.display();
SomeClass.h:
#ifndef SOMECLASS_H
#define SOMECLASS_H
class SomeClass {
public:
static void drawBitmap(Adafruit_SSD1306* display) {
display->drawBitmap(10, 10, SomeClass::sprite, 8, 8, SSD1306_WHITE);
B11111111
#endif
b707
April 4, 2024, 10:00am
21
Sorry, I haven't more ideas
