Blank screen on Arduino IDE installation
When I installed the Arduino IDE 2.3.10 the screen opens up and seems active but never stops to an edit screen, it just keeps on spinning and spinning.
Any idea what is going on?
Thanks.
Where did you download the install package?
How did you run the install package?
What operating system?
I'm on Windows 10. I installed the arduino-ide_2.3.10_Windows_64bit.exe app, and I can't seem to get a good install anywhere I put it. I tried in the suggested C:\Users\ascar\AppData\Local\Programs\Arduino IDE, in a C:\Arduino directory on Windows, in the standard Windows programming directory where all the norman apps go. I would delete them first via the Control Panel, then reinstall them. Maybe I'm not doing it right?
Thanks
Hi @tonyatms. I'm going to ask you to provide some additional information that might help us to identify the problem.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Close all Arduino IDE windows if the IDE is already running.
  2. Start Windows "File Explorer".
  3. Open the Arduino IDE installation folder.
    ⓘ The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
      • :red_exclamation_mark: Note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  4. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
    A context menu will open
  5. Select "Open PowerShell window here" from the menu.
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  6. Type the following command in the PowerShell window:
    & ".\Arduino IDE"
  7. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  8. Wait until you are sure the IDE startup has gone into the hang state
    (as indicated by no additional output being printed to the terminal).
  9. Switch back to the PowerShell window if the Arduino IDE window took the focus.
  10. Press the Ctrl+Shift+A keyboard shortcut.
    This will select all the text in the PowerShell window.
  11. Press the Ctrl+C keyboard shortcut.
    This will copy the contents of the PowerShell window to the clipboard.
  12. Open a reply here on this forum topic by clicking the "Reply" button.
  13. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  14. Press the Ctrl+V keyboard shortcut.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the "Reply" button to publish the post.
Please let us know if you have any questions or problems while following those instructions.
PS C:\Users\ascar\AppData\Local\Programs\Arduino IDE>
Arduino IDE 2.3.10
Checking for frontend application configuration customizations. Module path: C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.10" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.5.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2026-06-09T16:48:46.639Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.10","cliVersion":"1.5.1","buildDate":"2026-06-09T16:48:46.639Z"}
Starting backend process. PID: 14100
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/ascar/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2026-10-17T18:41:36.424Z root INFO Backend u.initialize: 33.0 ms [Finished 0.719 s after backend start]
2026-10-17T18:41:36.425Z root INFO Backend Object.initialize: 31.1 ms [Finished 0.719 s after backend start]
2026-10-17T18:41:36.425Z root INFO Backend a.initialize: 1.6 ms [Finished 0.719 s after backend start]
2026-10-17T18:41:36.425Z root INFO Backend a.initialize: 1.3 ms [Finished 0.719 s after backend start]
2026-10-17T18:41:36.425Z root INFO Backend u.initialize: 1.7 ms [Finished 0.720 s after backend start]
2026-10-17T18:41:36.428Z root INFO Backend l.initialize: 32.7 ms [Finished 0.721 s after backend start]
2026-10-17T18:41:36.436Z root INFO configured all backend app contributions
2026-10-17T18:41:36.437Z root INFO Backend l.onStart: 1.4 ms [Finished 0.733 s after backend start]
2026-10-17T18:41:36.438Z root INFO Backend d.onStart: 0.1 ms [Finished 0.734 s after backend start]
2026-10-17T18:41:36.439Z root INFO Backend a.onStart: 0.5 ms [Finished 0.734 s after backend start]
2026-10-17T18:41:36.439Z config INFO >>> Initializing CLI configuration...
2026-10-17T18:41:36.439Z root INFO Backend x.onStart: 0.5 ms [Finished 0.735 s after backend start]
2026-10-17T18:41:36.439Z config INFO Loading CLI configuration from c:\Users\ascar\.arduinoIDE\arduino-cli.yaml...
2026-10-17T18:41:36.439Z daemon INFO Starting daemon from C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2026-10-17T18:41:36.439Z root INFO Backend w.onStart: 0.5 ms [Finished 0.736 s after backend start]
2026-10-17T18:41:36.439Z discovery-log INFO start
2026-10-17T18:41:36.439Z discovery-log INFO start new deferred
2026-10-17T18:41:36.439Z root INFO Backend v.onStart: 0.3 ms [Finished 0.736 s after backend start]
2026-10-17T18:41:36.439Z root INFO Backend a.onStart: 0.1 ms [Finished 0.737 s after backend start]
2026-10-17T18:41:36.446Z root INFO Theia app listening on http://127.0.0.1:64642.
2026-10-17T18:41:36.446Z root INFO Finished starting backend application: 6.8 ms [Finished 0.744 s after backend start]
2026-10-17T18:41:36.447Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ascar/.arduinoIDE/plugins does not exist.
2026-10-17T18:41:36.447Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ascar/.arduinoIDE/deployedPlugins does not exist.
2026-10-17T18:41:36.448Z root WARN The local plugin referenced by local-dir:C:\Users\ascar\.arduinoIDE\plugins does not exist.
2026-10-17T18:41:36.456Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\ascar\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\ascar\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\ascar\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2026-10-17T18:41:36.456Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2026-10-17T18:41:36.456Z config INFO Loaded the CLI configuration.
2026-10-17T18:41:37.176Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/ascar/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/ascar/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2026-10-17T18:41:37.176Z config INFO Validating the CLI configuration...
2026-10-17T18:41:37.176Z config INFO The CLI config is valid.
2026-10-17T18:41:37.176Z config INFO <<< Initialized the CLI configuration.
2026-10-17T18:41:37.210Z root INFO Resolve plugins list: 767.8 ms [Finished 1.507 s after backend start]
2026-10-17T18:41:37.272Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="arduino-cli version 1.5.1"
2026-10-17T18:41:37.298Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Using config file: c:\\Users\\ascar\\.arduinoIDE\\arduino-cli.yaml"
time="2026-10-17T14:41:37-04:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:64643
{"IP":"127.0.0.1","Port":"64643"}
2026-10-17T18:41:37.299Z daemon INFO Daemon is running.
2026-10-17T18:41:37.379Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Checking signature" index="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2026-10-17T14:41:37-04:00" level=info msg="Loading hardware from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages"
2026-10-17T18:41:37.390Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Loading package arduino from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2026-10-17T18:41:37.403Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Missing signature file" index="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json"
time="2026-10-17T14:41:37-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.5"
time="2026-10-17T14:41:37-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2026-10-17T14:41:37-04:00" level=info msg="Loading tools from dir: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2026-10-17T18:41:37.407Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2026-10-17T18:41:37.422Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Loading package builtin from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2026-10-17T14:41:37-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2026-10-17T14:41:37-04:00" level=info msg="Loading tools from dir: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.6"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.1.0"
2026-10-17T18:41:37.423Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.2"
2026-10-17T18:41:37.423Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.5.2"
2026-10-17T18:41:37.434Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.10.0"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
time="2026-10-17T14:41:37-04:00" level=info msg="Loading package esp32 from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2026-10-17T18:41:37.501Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.3"
time="2026-10-17T14:41:37-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2026-10-17T14:41:37-04:00" level=info msg="Loading tools from dir: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp32:esptool_py@3.3.0"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2026-10-17T18:41:37.502Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2026-10-17T18:41:37.509Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
time="2026-10-17T14:41:37-04:00" level=info msg="Loading package esp8266 from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2026-10-17T18:41:37.531Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded platform" platform="esp8266:esp8266@2.3.0"
time="2026-10-17T14:41:37-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2026-10-17T14:41:37-04:00" level=info msg="Loading tools from dir: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp8266:esptool@0.4.9"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@0.1.2"
time="2026-10-17T14:41:37-04:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2"
2026-10-17T18:41:37.560Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.3.0\\libraries" isSingleLibrary=false location=platform
2026-10-17T18:41:37.568Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries" isSingleLibrary=false location=platform
2026-10-17T18:41:37.585Z daemon INFO time="2026-10-17T14:41:37-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\libraries" isSingleLibrary=false location=platform
time="2026-10-17T14:41:37-04:00" level=info msg="Loading libraries index file" index="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\library_index.json"
2026-10-17T18:41:37.706Z root INFO Deploy plugins list: 1263.9 ms [Finished 2.003 s after backend start]
2026-10-17T18:41:38.020Z daemon INFO time="2026-10-17T14:41:38-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2026-10-17T18:41:38.021Z daemon INFO time="2026-10-17T14:41:38-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
Restoring workspace roots: c:\Users\ascar\Documents\Arduino\Libraries\WiFiEsp\examples\WebServer\WebServer.ino
isTempSketch: false. Input was c:\Users\ascar\Documents\Arduino\Libraries\WiFiEsp\examples\WebServer\WebServer.ino
2026-10-17T18:41:40.226Z daemon INFO time="2026-10-17T14:41:40-04:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from C:\\Users\\ascar\\Documents\\Arduino\\libraries\\ESP32_Arduino_Servo_Library: invalid library: no header files found"
2026-10-17T18:41:40.230Z discovery-log INFO start resolved watching
2026-10-17T18:41:40.352Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2026-10-17T18:41:40.352Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2026-10-17T18:41:43.942Z root INFO creating connection for 1
2026-10-17T18:41:48.572Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 3735.8 ms [Finished 9.340 s after frontend start]
2026-10-17T18:41:48.611Z root WARN A command editor.action.toggleStickyScroll is already registered.
2026-10-17T18:41:48.650Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\ascar\Documents\Arduino\Libraries\WiFiEsp\examples\WebServer\WebServer.ino>, response: <c:\Users\ascar\Documents\Arduino\Libraries\WiFiEsp\examples\WebServer>.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2026-10-17T18:41:52.419Z root INFO Start frontend contributions: 3994.1 ms [Finished 9.521 s after frontend start]
2026-10-17T18:41:52.419Z root INFO Changed application state from 'init' to 'started_contributions'.
2026-10-17T18:41:52.419Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2026-10-17T18:41:52.419Z root INFO >>> Restoring the layout state...
2026-10-17T18:41:52.427Z root INFO [db5fc42b-6840-4607-84b5-268fe073d29c] Waiting for backend deployment: 3672.9 ms [Finished 13.189 s after frontend start]
2026-10-17T18:41:53.032Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144) starting instance
[Object: null prototype] {}
2026-10-17T18:41:53.848Z root INFO [db5fc42b-6840-4607-84b5-268fe073d29c] Sync of 23 plugins: 1427.1 ms [Finished 14.616 s after frontend start]
2026-10-17T18:41:53.883Z root INFO ------- SERIALIZED LAYOUT DATA -------
2026-10-17T18:41:53.883Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ascar/Documents/Arduino/Libraries/WiFiEsp/examples/WebServer/WebServer.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":137,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":325,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2026-10-17T18:41:53.883Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2026-10-17T18:41:54.349Z root INFO <<< The layout has been successfully restored.
2026-10-17T18:41:54.454Z root INFO Initialize the workbench layout: 5572.4 ms [Finished 15.118 s after frontend start]
2026-10-17T18:41:54.457Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2026-10-17T18:41:54.460Z root INFO [db5fc42b-6840-4607-84b5-268fe073d29c] Loading plugin contributions
2026-10-17T18:41:54.461Z root INFO [db5fc42b-6840-4607-84b5-268fe073d29c] Load contributions of 23 plugins: 100.0 ms [Finished 15.220 s after frontend start]
2026-10-17T18:41:54.527Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2026-10-17T18:41:54.528Z root WARN a registered grammar configuration for 'cpp' language is overridden
2026-10-17T18:41:54.701Z root ERROR [hosted-plugin: 10144] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2026-10-17T18:41:54.701Z root ERROR [hosted-plugin: 10144] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2026-10-17T18:41:54.701Z root ERROR [hosted-plugin: 10144] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2026-10-17T18:41:54.701Z root ERROR [hosted-plugin: 10144] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
2026-10-17T18:41:54.701Z root ERROR [hosted-plugin: 10144] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2026-10-17T18:41:54.753Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): PluginManagerExtImpl/init()
2026-10-17T18:41:54.757Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-arduino-api@0.1.2 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:54.969Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(json-language-features@1.88.1 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:54.999Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(cortex-debug@1.5.1 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.000Z root INFO [hosted-plugin: 10144] Debugger contribution has been registered: cortex-debug
2026-10-17T18:41:55.004Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-arduino-tools@0.1.3 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.006Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(cpp@1.88.1 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.014Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(json@1.88.1 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.019Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.021Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-cs@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.023Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-de@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.031Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-es@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.035Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-fr@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.037Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.040Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-it@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.042Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-ja@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.048Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-ko@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.051Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.053Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-pl@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.054Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-pt-BR@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.056Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-ru@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.058Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-tr@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.067Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.069Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-zh-hans@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.072Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): initializing(vscode-language-pack-zh-hant@1.96.0 with C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2026-10-17T18:41:55.135Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): PluginManagerExtImpl/loadPlugin(C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\node\jsonClientMain)
2026-10-17T18:41:55.225Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): PluginManagerExtImpl/loadPlugin(C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2026-10-17T18:41:55.274Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): PluginManagerExtImpl/loadPlugin(C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2026-10-17T18:41:55.285Z root INFO [hosted-plugin: 10144] calling activation function on VS Code Arduino Tools
2026-10-17T18:41:55.286Z root INFO [hosted-plugin: 10144] calling activation function on Arduino IDE API for VS Code extensions
2026-10-17T18:41:55.306Z root INFO [db5fc42b-6840-4607-84b5-268fe073d29c] Starting plugins.
2026-10-17T18:41:55.567Z root INFO Frontend application start: 7010.0 ms [Finished 19.864 s after backend start]
Checking for update
2026-10-17T18:41:56.082Z root INFO Replace loading indicator with ready workbench UI (animation): 860.0 ms [Finished 16.088 s after frontend start]
2026-10-17T18:41:56.082Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2026-10-17T18:41:56.082Z root WARN Linked preference "workbench.colorCustomizations" not found.
Update for version 2.3.10 is not available (latest version: 2.3.10, downgrade is allowed).
2026-10-17T18:41:56.232Z daemon INFO time="2026-10-17T14:41:56-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2026-10-17T18:41:56.345Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2026-10-17T18:41:56.388Z daemon INFO time="2026-10-17T14:41:56-04:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <Lathe Tachometer.ino> and sketch folder name <Tachometer>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <tachometer-using-arduino.ino> and sketch folder name <Documents>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <camera.ino> and sketch folder name <Camera Shield>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <Commander.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <Date_Time.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <Process_Alarms.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <SFE_T5403_example.ino> and sketch folder name <t5403>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <DHT11OnVersalino.pde> and sketch folder name <dht11OnVersalino>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <SFE_T5403_example.ino> and sketch folder name <SFE_T5403>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <Log.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <test.ino> and sketch folder name <FreqPeriodCounter-master>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <Util.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <TimeLine.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <TopPanel.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <MainFrame.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <BlinkMComm.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <BurnDialog.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <PlayButton.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <RightPanel.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <Dryer_Has_Stopped.ino> and sketch folder name <Dryer_Has_Stopped - Copy>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <ColorChooser.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <ColorPreview.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <ConnectDialog.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <BlinkMSequencer.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <DurationPullDown.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <SetArduinoClock.pde> and sketch folder name <Processing>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <Temp_Sensor_DHT22_AM2302.ino> and sketch folder name <Temp_Sensor_DHT_AM2302>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <LightTempSdfat.pde> and sketch folder name <FridgeLogger>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <lighttemplogger.pde> and sketch folder name <FridgeLogger>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <LightTempStreams.pde> and sketch folder name <FridgeLogger>. Skipping
2026-10-17T18:41:56.782Z sketches-service WARN Mismatching sketch file <Dryer_Motion_Detector_New.ino> and sketch folder name <Dryer_Motion_Detector_New_wTimer - Copy>. Skipping
2026-10-17T18:41:56.783Z sketches-service WARN Mismatching sketch file <SFE_T5403_example.ino> and sketch folder name <t5403>. Skipping
2026-10-17T18:41:56.783Z sketches-service WARN Mismatching sketch file <Commander.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.783Z sketches-service WARN Mismatching sketch file <Date_Time.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.783Z sketches-service WARN Mismatching sketch file <Process_Alarms.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.783Z sketches-service WARN Mismatching sketch file <SetArduinoClock.pde> and sketch folder name <Processing>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <Lathe Tachometer.ino> and sketch folder name <Tachometer>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <tachometer-using-arduino.ino> and sketch folder name <Documents>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <camera.ino> and sketch folder name <Camera Shield>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <Commander.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <Date_Time.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <Process_Alarms.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <SFE_T5403_example.ino> and sketch folder name <t5403>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <DHT11OnVersalino.pde> and sketch folder name <dht11OnVersalino>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <SFE_T5403_example.ino> and sketch folder name <SFE_T5403>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <Log.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <test.ino> and sketch folder name <FreqPeriodCounter-master>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <Util.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <TimeLine.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <TopPanel.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <MainFrame.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <BlinkMComm.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <BurnDialog.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <PlayButton.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <RightPanel.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <Dryer_Has_Stopped.ino> and sketch folder name <Dryer_Has_Stopped - Copy>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <ColorChooser.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <ColorPreview.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <ConnectDialog.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <BlinkMSequencer.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <DurationPullDown.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <SetArduinoClock.pde> and sketch folder name <Processing>. Skipping
2026-10-17T18:41:56.804Z sketches-service WARN Mismatching sketch file <Temp_Sensor_DHT22_AM2302.ino> and sketch folder name <Temp_Sensor_DHT_AM2302>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <LightTempSdfat.pde> and sketch folder name <FridgeLogger>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <lighttemplogger.pde> and sketch folder name <FridgeLogger>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <LightTempStreams.pde> and sketch folder name <FridgeLogger>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <Dryer_Motion_Detector_New.ino> and sketch folder name <Dryer_Motion_Detector_New_wTimer - Copy>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <DHT11OnVersalino.pde> and sketch folder name <dht11OnVersalino>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <SFE_T5403_example.ino> and sketch folder name <t5403>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <Commander.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <Date_Time.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <Process_Alarms.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.805Z sketches-service WARN Mismatching sketch file <SetArduinoClock.pde> and sketch folder name <Processing>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <Lathe Tachometer.ino> and sketch folder name <Tachometer>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <tachometer-using-arduino.ino> and sketch folder name <Documents>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <camera.ino> and sketch folder name <Camera Shield>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <Commander.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <Date_Time.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <Process_Alarms.ino> and sketch folder name <Alarm_Clock>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <SFE_T5403_example.ino> and sketch folder name <t5403>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <DHT11OnVersalino.pde> and sketch folder name <dht11OnVersalino>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <SFE_T5403_example.ino> and sketch folder name <SFE_T5403>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <Log.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <test.ino> and sketch folder name <FreqPeriodCounter-master>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <Util.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <TimeLine.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <TopPanel.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <MainFrame.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <BlinkMComm.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <BurnDialog.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <PlayButton.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <RightPanel.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <Dryer_Has_Stopped.ino> and sketch folder name <Dryer_Has_Stopped - Copy>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <ColorChooser.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <ColorPreview.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <ConnectDialog.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <BlinkMSequencer.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <DurationPullDown.pde> and sketch folder name <source>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <SetArduinoClock.pde> and sketch folder name <Processing>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <Temp_Sensor_DHT22_AM2302.ino> and sketch folder name <Temp_Sensor_DHT_AM2302>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <LightTempSdfat.pde> and sketch folder name <FridgeLogger>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <lighttemplogger.pde> and sketch folder name <FridgeLogger>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <LightTempStreams.pde> and sketch folder name <FridgeLogger>. Skipping
2026-10-17T18:41:56.916Z sketches-service WARN Mismatching sketch file <Dryer_Motion_Detector_New.ino> and sketch folder name <Dryer_Motion_Detector_New_wTimer - Copy>. Skipping
2026-10-17T18:41:56.955Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Sensor Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Sensor%20Projects/libraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:56.955Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Sensor Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Sensor%20Projects/libraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:56.955Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Sensor Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Sensor%20Projects/libraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:56.955Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Sensor Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Sensor%20Projects/libraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:56.955Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Bluetooth Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Bluetooth%20Projects/libraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:56.955Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Bluetooth Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Bluetooth%20Projects/libraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:56.955Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Bluetooth Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Bluetooth%20Projects/libraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:56.956Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Bluetooth Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Bluetooth%20Projects/libraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:56.956Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:56.956Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:56.956Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:56.956Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:56.957Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeSerialDateStrings is already registered.
2026-10-17T18:41:56.957Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xbee Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xbee%20Projects/libraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:56.957Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xbee Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xbee%20Projects/libraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:56.957Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xbee Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xbee%20Projects/libraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:56.957Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xbee Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xbee%20Projects/libraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:56.957Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:LED Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/LED%20Projects/libraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:56.957Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:LED Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/LED%20Projects/libraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:56.957Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:LED Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/LED%20Projects/libraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:56.958Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:LED Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/LED%20Projects/libraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:57.085Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Sensor Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Sensor%20Projects/libraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:57.085Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Sensor Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Sensor%20Projects/libraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:57.086Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Sensor Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Sensor%20Projects/libraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:57.086Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Sensor Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Sensor%20Projects/libraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:57.086Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Bluetooth Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Bluetooth%20Projects/libraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:57.086Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Bluetooth Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Bluetooth%20Projects/libraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:57.086Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Bluetooth Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Bluetooth%20Projects/libraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:57.086Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Bluetooth Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Bluetooth%20Projects/libraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:57.086Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:57.086Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xlibraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xlibraries/Time/Examples/TimeSerialDateStrings is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xbee Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xbee%20Projects/libraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xbee Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xbee%20Projects/libraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xbee Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xbee%20Projects/libraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:Xbee Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/Xbee%20Projects/libraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:LED Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/LED%20Projects/libraries/Time/Examples/TimeGPS is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:LED Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/LED%20Projects/libraries/Time/Examples/TimeNTP is already registered.
2026-10-17T18:41:57.087Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:LED Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/LED%20Projects/libraries/Time/Examples/TimeRTCSet is already registered.
2026-10-17T18:41:57.089Z root WARN A command arduino-open-example-menubar:1_file:0_sketch:1_sketchbook:LED Projects:libraries:Time:Examples--file:///c%3A/Users/ascar/Documents/Arduino/LED%20Projects/libraries/Time/Examples/TimeSerial is already registered.
2026-10-17T18:41:57.191Z daemon INFO time="2026-10-17T14:41:57-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2026-10-17T18:41:57.228Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2026-10-17T18:41:57.900Z root ERROR ---- !!!SLOW!!! DURATION: search took 1818.625 ms. Args: [{"type":"Updatable"}] ----
2026-10-17T18:41:59.139Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@3.3.0"
time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
2026-10-17T18:41:59.140Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2026-10-17T18:41:59.140Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2026-10-17T18:41:59.140Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s3-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2026-10-17T18:41:59.140Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.5.2"
2026-10-17T18:41:59.140Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2026-10-17T18:41:59.140Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2"
2026-10-17T18:41:59.140Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2026-10-17T18:41:59.140Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.1.0"
2026-10-17T18:41:59.140Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2026-10-17T18:41:59.141Z daemon INFO time="2026-10-17T14:41:59-04:00" level=info msg="Tool required for debug" tool="esp8266:esptool@0.4.9"
2026-10-17T18:41:59.143Z root ERROR Failed to get debug config: esp32:esp32:esp32wrover:UploadSpeed=921600,FlashFreq=80,FlashMode=qio,PartitionScheme=default,DebugLevel=none, undefined Error: Debugging is not supported.
    at Object.callback (C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:3992120)
    at Object.onReceiveStatus (C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:6723173)
    at Object.onReceiveStatus (C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:2604626)
    at Object.onReceiveStatus (C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:2604071)
    at C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:4353123
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
2026-10-17T18:41:59.534Z root INFO [hosted-plugin: 10144] PLUGIN_HOST(10144): PluginManagerExtImpl/loadPlugin(C:\Users\ascar\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2026-10-17T18:41:59.587Z root INFO [hosted-plugin: 10144] Debug configuration provider has been registered: cortex-debug, trigger: 1
2026-10-17T18:41:59.587Z root INFO [hosted-plugin: 10144] calling activation function on Cortex-Debug
2026-10-17T18:41:59.597Z root INFO [hosted-plugin: 10144] GDB server console created
2026-10-17T18:41:59.606Z root INFO [db5fc42b-6840-4607-84b5-268fe073d29c] Start of 23 plugins: 5142.2 ms [Finished 20.373 s after frontend start]
2026-10-17T18:41:59.664Z root INFO Starting language server: esp32:esp32:esp32wrover:UploadSpeed=921600,FlashFreq=80,FlashMode=qio,PartitionScheme=default,DebugLevel=none
2026-10-17T18:42:00.197Z root INFO [hosted-plugin: 10144] calling activation function on JSON Language Features (built-in)
2026-10-17T18:42:03.189Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Checking signature" index="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2026-10-17T18:42:03.190Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loading hardware from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages"
2026-10-17T18:42:03.199Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loading package arduino from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2026-10-17T18:42:03.201Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Missing signature file" index="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json"
2026-10-17T18:42:03.203Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2026-10-17T14:42:03-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.5"
2026-10-17T18:42:03.203Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2026-10-17T14:42:03-04:00" level=info msg="Loading tools from dir: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2026-10-17T18:42:03.204Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2026-10-17T18:42:03.204Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2026-10-17T18:42:03.205Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2026-10-17T18:42:03.206Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loading package builtin from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\builtin"
2026-10-17T18:42:03.207Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2026-10-17T14:42:03-04:00" level=info msg="Loading tools from dir: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2026-10-17T18:42:03.207Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2026-10-17T18:42:03.208Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2026-10-17T18:42:03.208Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.6"
2026-10-17T18:42:03.208Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.1.0"
2026-10-17T18:42:03.208Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.2"
2026-10-17T18:42:03.209Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2026-10-17T18:42:03.209Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.5.2"
2026-10-17T18:42:03.209Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.10.0"
2026-10-17T18:42:03.209Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
2026-10-17T18:42:03.210Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loading package esp32 from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2026-10-17T18:42:03.241Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2026-10-17T18:42:03.242Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.3"
2026-10-17T18:42:03.242Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2026-10-17T14:42:03-04:00" level=info msg="Loading tools from dir: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2026-10-17T18:42:03.243Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp32:esptool_py@3.3.0"
2026-10-17T18:42:03.243Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2026-10-17T18:42:03.244Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2026-10-17T18:42:03.244Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2026-10-17T18:42:03.244Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2026-10-17T18:42:03.244Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2026-10-17T18:42:03.247Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
2026-10-17T18:42:03.249Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loading package esp8266 from: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2026-10-17T18:42:03.261Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2026-10-17T14:42:03-04:00" level=info msg="Loaded platform" platform="esp8266:esp8266@2.3.0"
2026-10-17T18:42:03.261Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2026-10-17T14:42:03-04:00" level=info msg="Loading tools from dir: C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
2026-10-17T18:42:03.263Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp8266:esptool@0.4.9"
2026-10-17T18:42:03.264Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@0.1.2"
2026-10-17T18:42:03.265Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2"
2026-10-17T18:42:03.292Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
2026-10-17T18:42:03.293Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2026-10-17T18:42:03.293Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2026-10-17T18:42:03.309Z daemon INFO time="2026-10-17T14:42:03-04:00" level=error msg="Killing discovery process: Access is denied." discovery="builtin:serial-discovery"
2026-10-17T18:42:03.309Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
2026-10-17T18:42:03.310Z daemon INFO time="2026-10-17T14:42:03-04:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:serial-discovery"
2026-10-17T18:42:03.312Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2026-10-17T18:42:03.327Z daemon INFO time="2026-10-17T14:42:03-04:00" level=error msg="Killing discovery process: Access is denied." discovery="builtin:mdns-discovery"
2026-10-17T18:42:03.327Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
2026-10-17T18:42:03.327Z daemon INFO time="2026-10-17T14:42:03-04:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:mdns-discovery"
2026-10-17T18:42:03.445Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2026-10-17T18:42:03.445Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2026-10-17T18:42:03.476Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\libraries" isSingleLibrary=false location=platform
2026-10-17T18:42:03.482Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries" isSingleLibrary=false location=platform
2026-10-17T18:42:03.534Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.3.0\\libraries" isSingleLibrary=false location=platform
time="2026-10-17T14:42:03-04:00" level=info msg="Loading libraries index file" index="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\library_index.json"
2026-10-17T18:42:03.887Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2026-10-17T18:42:03.888Z daemon INFO time="2026-10-17T14:42:03-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ascar\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2026-10-17T18:42:05.210Z daemon INFO time="2026-10-17T14:42:05-04:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from C:\\Users\\ascar\\Documents\\Arduino\\libraries\\ESP32_Arduino_Servo_Library: invalid library: no header files found
This is where it stopped, " invalid library: no header files found", but
the IDE edit window actually opened up with code in it. And it wants me to update libraries and boards.
Thanks.
I actually think I know how this occured. I clicked on ** Libraries INSTALL ALL** and it was hung up on that last library, it wasn't moving, so I clicked on Boards INSTALL ALL and nothing happened at all for many minutes. So I shut the IDE down. I guess that was a mess up right there.
What do you think I should do next? Should I try undating all the libraries again?
Thanks.
The IDE is robust. It can handle a sudden halt. I would just restart your IDE and let it work for thirty minutes to update all needed files.
I do this when my IDE hangs. I also did my best to move the IDE, libraries folder, and sketches folder OFF of OneDrive. My WiFi or Internet tends to do the "hanging." The IDE just takes the brunt of my actions.
Ok, we'll give it a try.
Thanks so much for your help.
You should realize your helping an 83 year old, old programmer. Been doing this since 1976 I think.
Be well and thanks again.
Here we go...
Great news!
Unfortunately there is a bug in Arduino IDE that causes the library update process to never terminate when you update multiple libraries:
I'll provide you with instructions you can follow to update your libraries without encountering the bug:
  1. Start Arduino IDE.
  2. When you see the "Updates are available for some of your libraries" notification, click the "INSTALL MANUALLY" button instead of the "UPDATE ALL" button.
    Library Manager will open, with a list of the updatable libraries.
  3. Click the "UPDATE" button on the first of the entries in Library Manager for a library you wish to update.
  4. Wait for the update to finish, as indicated by the appearance of a "Successfully installed library ..." notification.
  5. Repeat steps (2)-(3) until you have updated all the libraries you wish to update.
