I wrote the below Arduino uno code to control a sensored bldc motor using the attached schematic diagram circuit.
The controller can run the motor in the tow rotation directions(cw & ccw) and the speed can be controlled using a potentiometer connected to A0. In the code there are tow functions fwd() and bwd() each function is for the rotation direction selected by switches on pins 10 & 11, the switch on pin 12 is to stop the motor.
Project Blog: http://elecnote.blogspot.com
#include <PWM.h>
int32_t frequency = 20000; //pwm frequency in Hz
unsigned int n = 0, timer2_initial_value, s = 0;
void setup(){
InitTimersSafe();
bool success = SetPinFrequencySafe(9, frequency);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(13, OUTPUT);
pinMode(0, INPUT);
pinMode(1, INPUT);
pinMode(2, INPUT);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
pinMode(12, INPUT_PULLUP);
// initialize timer2 interrupt for adc reading
noInterrupts(); // disable all interrupts
TCCR2A = 0;
TCCR2B = 0;
timer2_initial_value = 0;
TCNT2 = timer2_initial_value; // preload timer
TCCR2B |= (1 << CS22) |(1 << CS21) | (1 << CS20); // 1024 prescaler
TIMSK2 |= (1 << TOIE2); // enable timer overflow interrupt
interrupts(); // enable all interrupts
ISR(TIMER2_OVF_vect) // interrupt service routine
n++;
if (n>20){
n = 0;
if (s != analogRead(A0)){
s = analogRead(A0);
pwmWrite(9,s/4);}}
int fwd(){
while(1){
if (digitalRead(2)==1){
if (digitalRead(1)==0){
if (digitalRead(0)==1){
digitalWrite(8,0);digitalWrite(7,0);digitalWrite(6,0);
digitalWrite(5,1);digitalWrite(4,1);digitalWrite(3,0);}
else {
digitalWrite(8,1);digitalWrite(7,0);digitalWrite(6,0);
digitalWrite(5,1);digitalWrite(4,0);digitalWrite(3,0);}}
if (digitalRead(1)==1){
if (digitalRead(0)==0){
digitalWrite(5,0);digitalWrite(4,0);digitalWrite(3,1);}}}
if (digitalRead(2)==0){
digitalWrite(8,0);digitalWrite(7,0);digitalWrite(6,1);
else {
digitalWrite(8,0);digitalWrite(7,1);digitalWrite(6,1);
digitalWrite(5,0);digitalWrite(4,0);digitalWrite(3,0);}}
digitalWrite(8,0);digitalWrite(7,1);digitalWrite(6,0);
digitalWrite(5,0);digitalWrite(4,1);digitalWrite(3,0);}}}
if (digitalRead(12)==0) break;}
int bwd(){
while(1){
else {
else {
void loop(){
digitalWrite(13, LOW);
pwmWrite(9,s);
if (digitalRead(10)==0) {digitalWrite(13, HIGH);bwd();}
if (digitalRead(11)==0) {digitalWrite(13, HIGH);fwd();}
This video shows the working:
