Hi Community,
Recently I am trying to establish a stable connection between my computer (Mac) and my Nicla Voice via BLE.
The connections seems to be unstable. And I realised I am not the only one who faces such issues. I read on stackoverflow someone shared the same:
Has anyone managed to get BLE working on your nicla voice successfully?
Here's my code on both the python and arduino:
Callback LED
This example creates a Bluetooth® Low Energy peripheral with service that contains a
characteristic to control an LED. The callback features of the
library are used.
The circuit:
- Arduino MKR WiFi 1010, Arduino Uno WiFi Rev2 board, Arduino Nano 33 IoT,
Arduino Nano 33 BLE, or Arduino Nano 33 BLE Sense board.
You can use a generic Bluetooth® Low Energy central app, like LightBlue (iOS and Android) or
nRF Connect (Android), to interact with the services and characteristics
created in this sketch.
This example code is in the public domain.
#include <ArduinoBLE.h>
#include <Nicla_System.h>
BLEService ledService("00001101-0000-1000-8000-00805f9b34fb"); // create service
// create switch characteristic and allow remote device to read and write
BLEByteCharacteristic switchCharacteristic("00001143-0000-1000-8000-00805f9b34fb", BLERead | BLEWrite);
// const int ledPin = LED_BUILTIN; // pin to use for the LED
while (!Serial);
pinMode(LED_BUILTIN, OUTPUT); // use the LED pin as an output
// begin initialization
if (!BLE.begin()) {
Serial.println("starting Bluetooth® Low Energy module failed!");
while (1);
// set the local name peripheral advertises
BLE.setLocalName("LEDCallback");
// set the UUID for the service this peripheral advertises
BLE.setAdvertisedService(ledService);
// add the characteristic to the service
ledService.addCharacteristic(switchCharacteristic);
// add service
BLE.addService(ledService);
// assign event handlers for connected, disconnected to peripheral
BLE.setEventHandler(BLEConnected, blePeripheralConnectHandler);
BLE.setEventHandler(BLEDisconnected, blePeripheralDisconnectHandler);
// assign event handlers for characteristic
switchCharacteristic.setEventHandler(BLEWritten, switchCharacteristicWritten);
// set an initial value for the characteristic
switchCharacteristic.setValue(0);
// start advertising
BLE.advertise();
Serial.println(("Bluetooth® device active, waiting for connections..."));
// poll for Bluetooth® Low Energy events
BLE.poll();
void blePeripheralConnectHandler(BLEDevice central) {
// central connected event handler
Serial.print("Connected event, central: ");
Serial.println(central.address());
void blePeripheralDisconnectHandler(BLEDevice central) {
// central disconnected event handler
Serial.print("Disconnected event, central: ");
void switchCharacteristicWritten(BLEDevice central, BLECharacteristic characteristic) {
// central wrote new value to characteristic, update LED
Serial.print("Characteristic event, written: ");
if (switchCharacteristic.value()) {
Serial.println("LED on");
digitalWrite(LED_BUILTIN, HIGH);
Serial.println("LED off");
digitalWrite(LED_BUILTIN, LOW);
import asyncio
from bleak import BleakScanner, BleakClient
import logging
logging.basicConfig()
log = logging.getLogger(__name__)
# Discover Device, Get UUID + Name
async def discover_devices():
devices = await BleakScanner.discover()
for device in devices:
print(device)
async def connect_to_device(address, loop):
log.info(f"Connecting to {address}")
async with BleakClient(address, loop=loop) as client:
log.info("Connected. Reading data...")
while True:
data = await client.read_gatt_char("2A06")
log.info(f"Received data: {data}")
# Fill this up
UUID = "861A4982-F830-BD55-C091-D5A7E3CBC0AE"
loop = asyncio.get_event_loop()
asyncio.run(discover_devices())
loop.run_until_complete(connect_to_device(UUID, loop))
Output Logs:
10:54:46.143 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
10:54:46.208 -> Connected event, central: 6c:7e:67:cb:7c:8f
10:54:47.362 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
10:54:48.351 -> Connected event, central: 6c:7e:67:cb:7c:8f
10:54:49.503 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
10:59:38.761 -> Bluetooth® device active, waiting for connections...
10:59:53.289 -> Connected event, central: 6c:7e:67:cb:7c:8f
10:59:54.408 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
10:59:54.671 -> Connected event, central: 6c:7e:67:cb:7c:8f
10:59:56.121 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
10:59:56.186 -> Connected event, central: 6c:7e:67:cb:7c:8f
10:59:56.548 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
11:10:32.914 -> Connected event, central: 6c:7e:67:cb:7c:8f
11:10:34.138 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
11:10:34.138 -> Connected event, central: 6c:7e:67:cb:7c:8f
11:10:35.354 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
11:10:35.816 -> Connected event, central: 6c:7e:67:cb:7c:8f
11:10:37.004 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
11:10:37.297 -> Connected event, central: 6c:7e:67:cb:7c:8f
11:10:38.846 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
11:10:39.342 -> Connected event, central: 6c:7e:67:cb:7c:8f
11:10:40.490 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
11:10:40.490 -> Connected event, central: 6c:7e:67:cb:7c:8f
11:10:41.713 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
11:10:41.713 -> Connected event, central: 6c:7e:67:cb:7c:8f
11:10:42.834 -> Disconnected event, central: 6c:7e:67:cb:7c:8f
Thank you for your help
