Blink Clock dots with rainbow effect
I made a Neopixel clock with rainbow effect its working fine but without flashing dots. I make display 148 leds, 5 leds per segment *7 +2 leds for dots Total 37 leds for each digit.
I want to blink dots. This is my sketch.
#include <Wire.h>
#include "RTClib.h"
#define PIN (6)
RTC_DS3231 rtc;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(148, PIN, NEO_GRB + NEO_KHZ800);
// Setup the LED strip and RTC module.
strip.begin();
strip.show();
rtc.begin();
// Cycle the clock digits through rainbow colors.
rainbowCycle(100);
/* (Methods to un-set certain LEDs to form 7-segment digits.) */
void unsetTimeDigits() {
DateTime now = rtc.now();
flip_digits(now.hour() / 10, now.hour() % 10, now.minute() / 10, now.minute() % 10);
void flip_digits(int d1, int d2, int d3, int d4) {
// First digit.
flip_digit(111, d1);
// Second digit.
flip_digit(74, d2);
// Third digit.
flip_digit(37, d3);
// Fourth digit.
flip_digit(0, d4);
void flip_digit(int first_led, int val) {
if (val == 0) {
//strip.setPixelColor(first_led, 0);
strip.setPixelColor(first_led + 15, 0);
strip.setPixelColor(first_led + 16, 0);
strip.setPixelColor(first_led + 17, 0);
strip.setPixelColor(first_led + 18, 0);
strip.setPixelColor(first_led + 19, 0);
else if (val == 1) {
// strip.setPixelColor(first_led, 0);
strip.setPixelColor(first_led + 5, 0);
strip.setPixelColor(first_led + 6, 0);
strip.setPixelColor(first_led + 7, 0);
strip.setPixelColor(first_led + 8, 0);
strip.setPixelColor(first_led + 9, 0);
strip.setPixelColor(first_led + 10, 0);
strip.setPixelColor(first_led + 11, 0);
strip.setPixelColor(first_led + 12, 0);
strip.setPixelColor(first_led + 13, 0);
strip.setPixelColor(first_led + 14, 0);
strip.setPixelColor(first_led + 25, 0);
strip.setPixelColor(first_led + 26, 0);
strip.setPixelColor(first_led + 27, 0);
strip.setPixelColor(first_led + 28, 0);
strip.setPixelColor(first_led + 29, 0);
strip.setPixelColor(first_led + 30, 0);
strip.setPixelColor(first_led + 31, 0);
strip.setPixelColor(first_led + 32, 0);
strip.setPixelColor(first_led + 33, 0);
strip.setPixelColor(first_led + 34, 0);
else if (val == 2) {
strip.setPixelColor(first_led + 20, 0);
strip.setPixelColor(first_led + 21, 0);
strip.setPixelColor(first_led + 22, 0);
strip.setPixelColor(first_led + 23, 0);
strip.setPixelColor(first_led + 24, 0);
else if (val == 3) {
else if (val == 4) {
else if (val == 5) {
strip.setPixelColor(first_led , 0);
strip.setPixelColor(first_led + 1, 0);
strip.setPixelColor(first_led + 2, 0);
strip.setPixelColor(first_led + 3, 0);
strip.setPixelColor(first_led + 4, 0);
else if (val == 6) {
else if (val == 7) {
else if (val == 8) {
else if (val == 9) {
Welcome to the forum
Use [color = red]code tags[/color] (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
I highly recommend looking into arrays and loops. If you use arrays and loops, your program will become several times smaller and better understood.
Would you draw a picture? I can imagine a 5x7 character, but not "two dots" per character.
Where's rainbowCycle() (your main program)?
The colon between digits maybe ?
That makes sense, but "two per digit?"
Two dots equals one colon ?
I can see one colon, but each digit? Does OP numbers use umlauts?
"5 leds per segment *7 +2 leds for dots Total 37 leds for each digit."
I have the WOKWI barbi fired up... waiting for the missing function (rainbowCycle)
Files for WOKWI.COM
sketch.ino
#include <Wire.h>
#include "RTClib.h"
#define PIN (6)
#define NUM_PIX 4 * 35 + 2 // four 5x7 matrices and a colon
RTC_DS3231 rtc;
  strip.begin();
  strip.show();
  rtc.begin();
  // rainbowCycle(100);
  test();
void test() {
  for (int i = 0; i < NUM_PIX; i++)
    strip.setPixelColor(i, random(256), random(256), random(256));
  strip.show();
  // First digit.
  // Second digit.
  flip_digit(74, d2);
  // Third digit.
  flip_digit(37, d3);
  // Fourth digit.
  flip_digit(0, d4);
  if (val == 0) {
diagram.json
  "version": 1,
  "author": "Anonymous maker",
  "editor": "wokwi",
  "parts": [
    { "type": "wokwi-arduino-nano", "id": "nano", "top": 4.8, "left": -144.5, "attrs": {} },
      "type": "wokwi-neopixel-matrix",
      "id": "ring1",
      "top": -197.16,
      "left": -134.94,
      "attrs": { "pixleate": "1", "rows": "7", "cols": "5" }
      "id": "ring2",
      "top": -197.16,
      "left": -0.54,
      "id": "ring3",
      "top": -197.16,
      "left": 162.66,
      "id": "ring4",
      "top": -197.16,
      "left": 297.06,
    { "type": "wokwi-vcc", "id": "vcc1", "top": -66.44, "left": -163.2, "attrs": {} },
    { "type": "wokwi-gnd", "id": "gnd1", "top": 0, "left": -163.8, "attrs": {} },
    { "type": "wokwi-neopixel", "id": "rgb1", "top": -157.1, "left": 133.4, "attrs": {} },
    { "type": "wokwi-neopixel", "id": "rgb2", "top": -99.5, "left": 133.4, "attrs": {} }
  "connections": [
    [ "ring1:DIN", "nano:6", "green", [ "v0" ] ],
    [ "ring1:DOUT", "ring2:DIN", "green", [ "v9.6", "h105.6" ] ],
    [ "ring2:DOUT", "ring3:DIN", "green", [ "v9.6", "h144" ] ],
    [ "ring3:DOUT", "ring4:DIN", "green", [ "v9.6", "h124.8" ] ],
    [ "gnd1:GND", "ring1:GND", "black", [ "v-9.6", "h86.4" ] ],
    [ "vcc1:VCC", "ring1:VCC", "red", [ "v19.2", "h86.4" ] ],
    [ "ring1:GND", "ring2:GND", "black", [ "v28.8", "h134.4" ] ],
    [ "ring2:GND", "ring3:GND", "black", [ "v28.8", "h163.2" ] ],
    [ "ring3:GND", "ring4:GND", "black", [ "v28.8", "h134.4" ] ],
    [ "ring1:VCC", "ring2:VCC", "red", [ "v19.2", "h134.4" ] ],
    [ "ring2:VCC", "ring3:VCC", "red", [ "v19.2", "h163.2" ] ],
    [ "ring3:VCC", "ring4:VCC", "red", [ "v19.2", "h134.4" ] ],
    [ "rgb2:DIN", "rgb1:DOUT", "white", [ "v-19.2", "h-20" ] ],
    [ "ring4:DOUT", "rgb1:DIN", "white", [ "h-211.2", "v-115.2" ] ],
    [ "ring3:VCC", "rgb2:VDD", "white", [ "v0", "h-96", "v-57.6" ] ],
    [ "rgb2:VDD", "rgb1:VDD", "white", [ "h-9.6", "v-57.6" ] ],
    [ "ring3:GND", "rgb2:VSS", "white", [ "v0", "h-67.2" ] ],
    [ "rgb2:VSS", "rgb1:VSS", "white", [ "v0" ] ]
  "dependencies": {}
You are right... every number has a two-dot colon. LEDs are:
  0 -  34 +  35,  36
 37 -  71 +  72,  73
 74 - 108 + 109, 110
111 - 145 + 146, 147
Files for WOKWI.COM
sketch.ino
#include <Wire.h>
#include "RTClib.h"
#define PIN (6)
RTC_DS3231 rtc;
  strip.begin();
  strip.show();
  rtc.begin();
  // test();
  markpix();
void markpix () {
  // first pixel RED
  strip.setPixelColor(111, 255, 0, 0);
  strip.setPixelColor(74, 255, 0, 0);
  strip.setPixelColor(37, 255, 0, 0);
  strip.setPixelColor(0, 255, 0, 0);
  // last pixel GRN
  strip.setPixelColor(145, 0, 255, 0);
  strip.setPixelColor(108, 0, 255, 0);
  strip.setPixelColor(71, 0, 255, 0);
  strip.setPixelColor(34, 0, 255, 0);
  // colon CYN:MAG
  strip.setPixelColor(147, 255, 0, 255);
  strip.setPixelColor(146, 0, 255, 255);
  strip.setPixelColor(110, 255, 0, 255);
  strip.setPixelColor(109, 0, 255, 255);
  strip.setPixelColor(73, 255, 0, 255);
  strip.setPixelColor(72, 0, 255, 255);
  strip.setPixelColor(36, 255, 0, 255);
  strip.setPixelColor(35, 0, 255, 255);
  strip.show();
void test() {
  strip.show();
  // First digit.
  // Second digit.
  flip_digit(74, d2);
  // Third digit.
  flip_digit(37, d3);
  // Fourth digit.
  flip_digit(0, d4);
  if (val == 0) {
diagram.json
  "version": 1,
  "editor": "wokwi",
  "parts": [
      "id": "ring1",
      "top": -225.96,
      "left": -144.54,
      "id": "ring2",
      "top": -225.96,
      "left": -0.54,
      "id": "ring3",
      "top": -225.96,
      "left": 143.46,
      "id": "ring4",
      "top": -225.96,
      "left": 287.46,
    { "type": "wokwi-vcc", "id": "vcc1", "top": -66.44, "left": -124.8, "attrs": {} },
    { "type": "wokwi-gnd", "id": "gnd1", "top": 0, "left": 47.4, "attrs": {} },
      "id": "rgb3",
      "top": -188.3,
      "left": -20,
      "rotate": 180,
      "attrs": {}
      "id": "rgb4",
      "top": -121.1,
      "left": -20,
      "rotate": 180,
      "attrs": {}
      "id": "rgb1",
      "top": -188.3,
      "left": 124,
      "rotate": 180,
      "attrs": {}
      "id": "rgb2",
      "top": -121.1,
      "left": 124,
      "rotate": 180,
      "attrs": {}
      "id": "rgb5",
      "top": -188.3,
      "left": 268,
      "rotate": 180,
      "attrs": {}
      "id": "rgb6",
      "top": -121.1,
      "left": 268,
      "rotate": 180,
      "attrs": {}
      "id": "rgb7",
      "top": -188.3,
      "left": 412,
      "rotate": 180,
      "attrs": {}
      "id": "rgb8",
      "top": -121.1,
      "left": 412,
      "rotate": 180,
      "attrs": {}
  "connections": [
    [ "rgb4:VDD", "rgb3:VDD", "white", [ "h-9.6", "v-57.6" ] ],
    [ "rgb4:VSS", "rgb3:VSS", "white", [ "v0" ] ],
    [ "rgb4:DOUT", "rgb3:DIN", "white", [ "h0.2", "v-30.3", "h-19.2" ] ],
    [ "rgb2:VDD", "rgb1:VDD", "white", [ "h4.77", "v-67.2" ] ],
    [ "rgb2:VSS", "rgb1:VSS", "white", [ "v0" ] ],
    [ "rgb2:DOUT", "rgb1:DIN", "white", [ "h0.2", "v-30.3", "h-19.2" ] ],
    [ "rgb6:VDD", "rgb5:VDD", "white", [ "h4.77", "v-67.2" ] ],
    [ "rgb6:VSS", "rgb5:VSS", "white", [ "v0" ] ],
    [ "rgb6:DOUT", "rgb5:DIN", "white", [ "h0.2", "v-30.3", "h-19.2" ] ],
    [ "rgb8:VDD", "rgb7:VDD", "white", [ "h4.77", "v-67.2" ] ],
    [ "rgb8:VSS", "rgb7:VSS", "white", [ "v0" ] ],
    [ "rgb8:DOUT", "rgb7:DIN", "white", [ "h0.2", "v-30.3", "h-19.2" ] ],
    [ "ring1:DOUT", "rgb4:DIN", "white", [ "v9.6", "h48" ] ],
    [ "rgb3:DOUT", "ring2:DIN", "white", [ "h0", "v125.7", "h67.2" ] ],
    [ "ring2:DOUT", "rgb2:DIN", "white", [ "v9.6", "h57.6" ] ],
    [ "rgb1:DOUT", "ring3:DIN", "white", [ "h0", "v125.7", "h67.2" ] ],
    [ "ring3:DOUT", "rgb6:DIN", "white", [ "v9.6", "h48" ] ],
    [ "rgb5:DOUT", "ring4:DIN", "white", [ "h0", "v125.7", "h67.2" ] ],
    [ "ring4:DOUT", "rgb8:DIN", "white", [ "v9.6", "h48" ] ]
  "dependencies": {}
