I have uploaded successfully bootloader to the chip ATmega328p with the Arduino Nano 3.0.
Switching to the FTDI FT232RL USB adapter I can not upload the Blink code to the chip. The chip is sitting in an TQFP Adapter on a breadboard.
Using this Guide:
https://www.electronoobs.com/eng_arduino_tut6.php
Arduino: 1.8.12 (Windows 10), Board: “ATmega328, Yes (UART0), 328P / 328PA, BOD 1.8V, LTO disabled, External 16 MHz”
Error message:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\barna\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\barna\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\barna\Documents\Arduino\libraries -fqbn=MiniCore:avr:328:bootloader=uart0,variant=modelP,BOD=1v8,LTO=Os,clock=16MHz_external -vid-pid=0403_6001 -ide-version=10812 -build-path C:\Users\barna\AppData\Local\Temp\arduino_build_507572 -warnings=none -build-cache C:\Users\barna\AppData\Local\Temp\arduino_cache_365354 -prefs=build.warn_data_percentage=75 -verbose C:\Users\barna\Desktop\Blink2\Blink2.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\barna\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\barna\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\barna\Documents\Arduino\libraries -fqbn=MiniCore:avr:328:bootloader=uart0,variant=modelP,BOD=1v8,LTO=Os,clock=16MHz_external -vid-pid=0403_6001 -ide-version=10812 -build-path C:\Users\barna\AppData\Local\Temp\arduino_build_507572 -warnings=none -build-cache C:\Users\barna\AppData\Local\Temp\arduino_cache_365354 -prefs=build.warn_data_percentage=75 -verbose C:\Users\barna\Desktop\Blink2\Blink2.ino
Using board ‘328’ from platform in folder: C:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4
Using core ‘MCUdude_corefiles’ from platform in folder: C:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4
Detecting libraries used…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR “-IC:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4\cores\MCUdude_corefiles” “-IC:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4\variants\standard” “C:\Users\barna\AppData\Local\Temp\arduino_build_507572\sketch\Blink2.ino.cpp” -o nul
Generating function prototypes…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR “-IC:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4\cores\MCUdude_corefiles” “-IC:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4\variants\standard” “C:\Users\barna\AppData\Local\Temp\arduino_build_507572\sketch\Blink2.ino.cpp” -o “C:\Users\barna\AppData\Local\Temp\arduino_build_507572\preproc\ctags_target_for_gcc_minus_e.cpp”
“C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives “C:\Users\barna\AppData\Local\Temp\arduino_build_507572\preproc\ctags_target_for_gcc_minus_e.cpp”
Compiling sketch…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR “-IC:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4\cores\MCUdude_corefiles” “-IC:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4\variants\standard” “C:\Users\barna\AppData\Local\Temp\arduino_build_507572\sketch\Blink2.ino.cpp” -o “C:\Users\barna\AppData\Local\Temp\arduino_build_507572\sketch\Blink2.ino.cpp.o”
Compiling libraries…
Compiling core…
Using precompiled core: C:\Users\barna\AppData\Local\Temp\arduino_cache_365354\core\core_097c30f0e700ef29f10e5ad4a4e0387d.a
Linking everything together…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc” -w -Os -Wl,–gc-sections -mmcu=atmega328p -o “C:\Users\barna\AppData\Local\Temp\arduino_build_507572/Blink2.ino.elf” “C:\Users\barna\AppData\Local\Temp\arduino_build_507572\sketch\Blink2.ino.cpp.o” “C:\Users\barna\AppData\Local\Temp\arduino_build_507572/…\arduino_cache_365354\core\core_097c30f0e700ef29f10e5ad4a4e0387d.a” “-LC:\Users\barna\AppData\Local\Temp\arduino_build_507572” -lm
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy” -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 “C:\Users\barna\AppData\Local\Temp\arduino_build_507572/Blink2.ino.elf” “C:\Users\barna\AppData\Local\Temp\arduino_build_507572/Blink2.ino.eep”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy” -O ihex -R .eeprom “C:\Users\barna\AppData\Local\Temp\arduino_build_507572/Blink2.ino.elf” “C:\Users\barna\AppData\Local\Temp\arduino_build_507572/Blink2.ino.hex”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-size” -A “C:\Users\barna\AppData\Local\Temp\arduino_build_507572/Blink2.ino.elf”
Sketch uses 1068 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\barna\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\barna\AppData\Local\Temp\arduino_build_507572/Blink2.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “C:\Users\barna\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.4/avrdude.conf”
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xcd
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
