blink or duty cycle without using delay, with use of modulus operator
To whom it may concern: An example how to use the modulus operator for making something go periodically on/off, with duty cycle and frequency of your choice. Not for critical timing functions, but for slow stuff I think it's good.
  Serial.println(millis()%60000<10000); // you chose duty cycle and period; example 10s HIGH and 50s LOW during the 60s period
have you considered
if (! (millis() % N)
gcjr:
have you considered
hmm, I think you risk missing the 'millis' count where the modulus result is zero. You also have no control over duty cycle.
The '%' operator is computationally expensive compared with the standard comparison and increment. It's taking a step backwards.
just ran this piece of code:
uint32_t nowMillis;
uint32_t prevMillis;
boolean thing;
  prevMillis=micros();
  thing=millis()%60000<10000; // you chose duty cycle and period; example 10s HIGH and 50s LOW during the 60s period
  nowMillis=micros();
  Serial.println("modulus operator took " + String(nowMillis-prevMillis) + " micro-seconds to compute");
  Serial.println("thing state: " + String(thing));
result from the serial monitor:
modulus operator took 2 micro-seconds to compute
thing state: 1
thing state: 1
thing state: 0
thing state: 0
thing state: 0
thing state: 0
thing state: 0
When the code is much more elegant and compact than comparison and increment solution, who cares about 2 micro-seconds?
