Platform - Mac Latest OS - have sufficient storage
Seeed nRF 52840 Sense
Correct board and port selected - using data upc-c cable
Arduino IDE 2.2.1. All relevant preferences are not blocked
When I try to verify/compile - blink sketch get the following error message
Your topic has been moved to a more relevant forum category as whatever the problem is it does not relate to IDE version 1.x which is where it was originally posted
Verified that les (me) has "read and write" permission for /Users/les/Library/Arduino15/packages/Seeeduino/hardware/nrf52/1.1.7/tools/adafruit-nrfutil/macOS.
I think - The Seeduino tools appear to have automatically installed when I used Arduino IDE 2.2.1 Board manager to select the Seeed nRF52 Board 1.1.7 Therefore, unsure if that is an "admin" install..
I was able to reproduce it so it wasn't only some quirk of @lesfuji's installation. The file is downloaded from a release asset in Adafruit's adafruit/Adafruit_nRF52_Arduino repository:
Specifically the "nrfjprog-9.4.0-mac.tar.bz2" link under the "Assets" section of that page.
For others with the problem, the 1.1.8 update for Seeed nRF52 hardware has this same error and this solution works perfectly (obviously change 'les' in the address to your user name on mac)
Sorry to comment again, but has anyone actually gotten blink.ino AND a serial connection to work using:
Mac OS
Arduino IDE 2.3.2 (current)
Seeed nRF52 Board core v1.1.8 (non-mbed)
I'm able to upload the blink sketch to the MCU, but then lose serial connection. The LED does blink, but the Mac OS no longer detects the board and new code can't be uploaded unless the RESET is pressed twice. Have also tried with an earlier BSP (v1.1.1) and earlier Arduino IDE (1.8.16)
I have no issue with the mbed board core and the blink.ino
