Bluetooth and SoftwareSerial
I have bluetooth shield serial comms up and running no problem. I am now trying to add an RFID reader which has a serial connection to the Arduino UNO. As soon as I open the RFIDSerial connection the Bluetooth connection stops working.
I thought that SoftwareSerial supported several simultaneous serial connections? Any help greatly appreciated.
#include <SoftwareSerial.h>
SoftwareSerial BlueTooth(6, 7); // RX, TX
SoftwareSerial RFIDSerial(9, 10); // RX, TX
char message = 0; //incoming message as a single character
  // initialize serial communication at 9600 bits per second:
  BlueTooth.begin(9600);
  RFIDSerial.begin(9600);
  //check for messages from the PC
  if (BlueTooth.available() > 0) {
    // read the incoming byte:
    message = BlueTooth.read();
  //check for messages from the RFID Reader and send over Bluetooth to PC
  //if (RFIDSerial.available() > 0) {
    // read the incoming data:
    //BlueTooth.write(RFIDSerial.read());
Your code compiles OK, so it is kosher as far as it goes. Your entire loop is as follows. It has a condition but does nothing, so it probably has too many comments.
Apologies. I commented out the section that reads the RFID serial input and then writes it straight out to the Bluetooth wireless connection to the PC. As soon as I open the SoftwareSerial port to the RFID reader using RFIDSerial.begin(9600) the Bluetooth connection stops working :slightly_frowning_face:
This is actual code in full:
const int SWITCH = 2; // The input switch is connected to pin 2
boolean lastSwitch = LOW; //variable containing previous switch state
boolean currentSwitch = LOW; //variable containing current switch state
boolean state = false; // The input state toggleFALSE=LOW and TRUE=HIGH
unsigned long switchtime = 0;   // Time of latest switch change
unsigned long lastswitchtime = 0; // Time of previous switch change
unsigned long zerotime = 0; //to store time of zeroing so can be subtracted from switch time
int OnCount = 0; //counts the ON switches
int OffCount = 0;  //counts the OFF switches
String SketchVersion = "2015.1";              //version of this sketch
String Copyright = "Copyright 2015 Innervations"; //copyright
String SerialNumber = "OK00001"; //serial numer assigned to Arduino
String ArduinoModel = "ArduinoUNO"; //model of Arduino
  // Set up digital pin 2 to be an input
  pinMode(SWITCH, INPUT); //make it an input
  RFIDSerial.begin(9600); // This is the line of code that stops the Bluetooth connection working
  zerotime=millis();
  currentSwitch = digitalRead(SWITCH);
  if (currentSwitch != lastSwitch) //change of switch status
     switchtime=millis()-zerotime;
    if (switchtime - lastswitchtime >10) //try to ignore switch bounce
        if (currentSwitch == HIGH) { OnCount ++; BlueTooth.print(SerialNumber); BlueTooth.print("_"); BlueTooth.print(OnCount); BlueTooth.print("_ON_"); BlueTooth.print(switchtime); BlueTooth.println("#"); }
        if (currentSwitch == LOW) { OffCount ++; BlueTooth.print(SerialNumber); BlueTooth.print("_"); BlueTooth.print(OffCount); BlueTooth.print("_OFF_"); BlueTooth.print(switchtime); BlueTooth.println("#"); }
      switchtime = lastswitchtime;
      lastSwitch=currentSwitch;
    // read the incoming message byte from the PC:
    ProcessMessage(message);
    // read the incoming RFID data and immediately write this out to the PC over Bluetooth:
void arduinoinfo()
  BlueTooth.println("Model " + ArduinoModel);
  BlueTooth.println("SerialNumber " + SerialNumber);
  BlueTooth.println("Sketch Version " + SketchVersion);
  BlueTooth.println(Copyright);
void ProcessMessage(char msg)
  switch (msg) {
    case 'm':
    case 's':
    case 'v':
    case 'c':
    case 'z': //reset the counts
      OnCount = 0;
      OffCount = 0;
      zerotime=millis();
I'm afraid I can't comment much on this. I don't even know what an RFID is. I'm sure you are right in that SoftwareSerial should handle several ports but be aware that there are all sorts of restrictions to its use, and I wouldn't use it for anything.
I admit to being biased on the matter but I don't understand why you aren't using bluetooth on the hardware serial port, thereby isolating it from whatever dancing is going on with software serial.
Thanks for the reply. RFID is a radio frequency identification reader. When you put an RFID card or key fob near it the reader sends the unique ID code over a serial connection to the Arduino.
Good suggestion about using hardware serial for the Bluetooth. I will see if the shield will do this and come back to you.
OK, LOL. If one won't go on hardware, I imagine the other would. I'm not au fait with any bluetooth shield but there are probably jumpers to set the pins.
Are you sure the baud rate of your rfid is 9600? because usually it isn't. Did you try to read data of the tags without the Bluetooth?
