Gerade nicht, aber super erklärt
danke. Ich konnte mein Projekt mit den Informationen jetzt auch die Fehler ausradieren.
Hatte jetzt wie du schon in den anderen Threads gesagt hast (auch andere, ich weiß), debuggen und alles nacheinander
Und es klappt
#include <AFMotor.h>
#include <Arduino.h>
#include <HCSR04.h>
#include <SoftwareSerial.h>
SoftwareSerial BlueTooth(10, 11); // RX, TX
byte triggerPin = 9;
byte echoPin = 7;
int duration, distance;
int number;
char BT_input;
char oldInput;
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
unsigned char smile[] = { 0x00, 0x00, 0x1c, 0x02, 0x02, 0x02, 0x5c, 0x40, 0x40, 0x5c, 0x02, 0x02, 0x02, 0x1c, 0x00, 0x00 };
unsigned char herz[] = { 0x00, 0x00, 0x00, 0x0c, 0x12, 0x21, 0x41, 0x82, 0x41, 0x21, 0x12, 0x0c, 0x00, 0x00, 0x00, 0x00 };
unsigned char vor[] = { 0x00, 0x00, 0x02, 0x04, 0x09, 0x12, 0x24, 0x48, 0x90, 0x48, 0x24, 0x12, 0x09, 0x04, 0x02, 0x00 };
#define SCL_Pin A4
#define SDA_Pin A5
Serial.begin(57600);
Serial.println(F("Start..."));
BlueTooth.begin(9600);
pinMode(SCL_Pin, OUTPUT);
pinMode(SDA_Pin, OUTPUT);
motor1.setSpeed(120);
motor2.setSpeed(120);
motor3.setSpeed(120);
motor4.setSpeed(120);
pinMode(triggerPin, OUTPUT);
pinMode(echoPin, INPUT);
bluetooth();
getData();
void getData() {
while (BlueTooth.available()) {
//char myChar = Serial.read();
char myChar = BlueTooth.read();
if (isAlpha(myChar)) {
myChar = ucase(myChar);
switch (myChar) {
case 'Y':
case 'X':
case 'B': //backward
case 'F': //forward
case 'L': //left
case 'R': //right
case 'S': //stop
Serial.print(F("Input Char: "));
Serial.println(myChar);
BT_input = myChar;
break; //gültiges Zeichen
default:
if (myChar >= ' ') {
Serial.print(F("FailChar: "));
Serial.println(myChar, HEX);
BT_input = 'S';
if (oldInput != BT_input) {
car_Stop();
delay(20); // kurze Pause schont die Antriebe!
oldInput = BT_input;
char ucase(const char c) {
if (c >= 'a' && c <= 'z') {
return (c + ('A' - 'a'));
return c;
void bluetooth() {
getData();
switch (BT_input) {
case 'X': switchdrive();break;
case 'Y': bluetooth();break;
case 'B': car_back(); break;
case 'F': car_front(); break;
case 'L': car_left(); break;
case 'R': car_right(); break;
case 'S': car_Stop(); break;
void switchdrive() {
distance = 0;
digitalWrite(triggerPin, LOW);
delayMicroseconds(4);
digitalWrite(triggerPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = round(duration * .0343) / 2;
Serial.print("Distance: ");
Serial.println(distance);
delay(100);
switch (distance) {
case 1 ... 15:
car_front();
Serial.println("zurueck");
delay(1200);
drive();
Serial.println(number);
matrix_display(herz);
case 16 ... 30:
motor1.setSpeed(90);
motor2.setSpeed(90);
motor3.setSpeed(90);
motor4.setSpeed(90);
car_back();
Serial.println("langsam vor");
matrix_display(smile);
case 31 ... 45:
car_back();
Serial.println("Vorwaerts");
matrix_display(vor);
default:
car_back();
Serial.println("default");
void drive() {
number = random(3);
if (number == 1) {
car_left();
delay(1500);
if (number == 2) {
car_right();
delay(1500);
car_right();
delay(3000);
void car_back() {
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
void car_front() {
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
void car_left() {
motor1.run(RELEASE);
motor2.run(RELEASE);
void car_right() {
motor3.run(RELEASE);
motor4.run(RELEASE);
void car_Stop() {
void matrix_display(unsigned char matrix_value[]) {
IIC_start(); //the function that calls the data transfer start condition
IIC_send(0xc0); //select address
for (int i = 0; i < 16; i++) //the pattern data is 16 bytes
IIC_send(matrix_value[i]); //Transmit the data of the pattern
IIC_end(); //End pattern data transmission
IIC_start();
IIC_send(0x8A); //Display control, select 4/16 pulse width
IIC_end();
//Conditions under which data transmission begins
void IIC_start() {
digitalWrite(SDA_Pin, HIGH);
digitalWrite(SCL_Pin, HIGH);
delayMicroseconds(3);
digitalWrite(SDA_Pin, LOW);
digitalWrite(SCL_Pin, LOW);
//Indicates the end of data transmission
void IIC_end() {
//transmit data
void IIC_send(unsigned char send_data) {
for (byte mask = 0x01; mask != 0; mask <<= 1) //Each byte has 8 bits and is checked bit by bit starting at the lowest level
if (send_data & mask) { //Sets the high and low levels of SDA_Pin depending on whether each bit of the byte is a 1 or a 0
digitalWrite(SCL_Pin, HIGH); //Pull the clock pin SCL_Pin high to stop data transmission
digitalWrite(SCL_Pin, LOW); //pull the clock pin SCL_Pin low to change the SIGNAL of SDA
