Hi guys, Im trying to build a mechanical keyboard using arduino - pico project with a raspberry pi pico W, I have used the keyboard code from 'datulab tech' and modified it quite a bit actually it almost works except for the modifier keys, i want the shift, ctrl , tab keys to act normally like they should stay pressed for the time they are actually presses, but with my code they keep spamming if you hold the key for more than 350 ms it starts spamming that modifier key, which is not what i want , (I have read somewhere that you need to use debounce time but i'm pretty new to programming and don't know how to implement that ). any help and suggestions will be greatly appreciated. i'm attaching my code below
* This code was written by David Wieland aka. Datulab Tech
* https://www.youtube.com/datulabtech to work with the
* custom PCBs showcased in this video: https://youtu.be/eH8FnLNZwlk
* A more detailed explanation can be found here: https://youtu.be/Iq3oY91x9Vk
* Feel free to use it for your projects, just know that you will have to
* change some things for it to work with your hardware.
#include <Keyboard.h>
#include <KeyboardBLE.h>
int longPressDelay = 350; //customizable encoderValues
int spamSpeed = 15;
int rowval=5;
int colval=7;
byte inputs[] = {16,17,18,19,20,21,22}; //declaring inputs and outputs
const int inCount = sizeof(inputs)/sizeof(inputs[0]);
byte outputs[] = {0,1,2,3,4};
const int outCount = sizeof(outputs)/sizeof(outputs[0]);
char layout[5][7] = { //layout grid for characters
{KEY_ESC, '1', '2', '3', '4', '5', '6'},
{KEY_TAB, 'Q', 'W', 'E', 'R', 'T', 'Y'},
{KEY_CAPS_LOCK, 'A', 'S', 'D', 'F', 'G', 'H'},
{KEY_LEFT_SHIFT, 'Z', 'X', 'C', 'V', 'B', 'N'},
{KEY_LEFT_CTRL, KEY_LEFT_GUI, KEY_LEFT_ALT,'[', KEY_PAUSE,'[' , '}'},
int keyDown[5][7];
bool keyLong[5][7];
void setup(){
for(int i=0; i<outCount; i++){ //declaring all the outputs and setting them high
pinMode(outputs[i],OUTPUT);
digitalWrite(outputs[i],HIGH);
for(int i=0; i<inCount; i++){ //declaring all the inputs and activating the internal pullup resistor
pinMode(inputs[i],INPUT_PULLUP);
KeyboardBLE.begin();
delay(5000);
//Main loop going through all the keys, then waiting 0.5ms
for (int i=0; i<rowval; i++)
digitalWrite(outputs[i],LOW); //setting one row low
delayMicroseconds(5); //giving electronics time to settle down
for(int j=0; j<colval; j++)
if(digitalRead(inputs[j]) == LOW)
keyPressed(i,j); //calling keyPressed function if one of the inputs reads low
else if(keyDown[i][j] != 0) //resetting the key if it is not pressed any more
resetKey(i,j);
delayMicroseconds(500); //setting the row high and waiting 0.5ms until next cycle
//if a key is pressed, this Funtion is called and outputs to serial the key location, it also sends the keystroke if not already done so
void keyPressed(int row, int col){
Serial.print("Output: ");
Serial.print(row);
Serial.print(" Input: ");
Serial.print(col);
Serial.print(" ");
Serial.println(layout[row][col]);
if(keyDown[row][col]==0){ //if the function is called for the first time for this key
KeyboardBLE.press(layout[row][col]);
KeyboardBLE.releaseAll();
else if(keyLong[row][col] && keyDown[row][col] > spamSpeed){ //if the key has been held long enough to warrant another keystroke set
keyDown[row][col] = 1;
else if(keyDown[row][col] > longPressDelay){ //if the key has been held for longer that longPressDelay, it switches into spam mode
keyLong[row][col] = true;
keyDown[row][col]++;
void resetKey(int row, int col){ //resetting the variables after key is released
keyDown[row][col] = 0;
keyLong[row][col] = false;
