I can successfully set speed and name with AT commands, but I never receive any RESPONSE, like "OK" as supposed.
I've double check the bluetooth TX wire, it seems its everything ok.
When I send 2 "AT" commands the BT module don't assume the "enter" between the two commands, see the image attached.
the 2nd image is a capture from my phone, look what I found.. name+ second command I sent
you might need to hook the BT to the other soft serial if your using a terminal program to read from the arduino. also you dont seem to be reading the tx line into the arduino sketch code.
