Bluetooth shield problem
Guys my bluetooth shield is not functioning....
i uploaded the slave.pde and the red and green leds are blinking and when i connect my fone using terminal it stops....
but i cant see the recived characters in the serial monitor and i cant even see
+BITSTATE: 3
CONNECT: OK
+BITSTATE: 4
Connected!
i cant see this in terminal... i used to get this before now its not coming what must be the problem?
i am running the basic code :frowning:
#include <SoftwareSerial.h>   //Software Serial Port
#define RxD 6
#define TxD 7
#define DEBUG_ENABLED  1
SoftwareSerial blueToothSerial(RxD,TxD);
  pinMode(RxD, INPUT);
  pinMode(TxD, OUTPUT);
  setupBlueToothConnection();
  char recvChar;
  while(1){
    if(blueToothSerial.available()){//check if there's any data sent from the remote bluetooth shield
      recvChar = blueToothSerial.read();
      Serial.print(recvChar);
    if(Serial.available()){//check if there's any data sent from the local serial terminal, you can add the other applications here
      recvChar  = Serial.read();
      blueToothSerial.print(recvChar);
void setupBlueToothConnection()
  Serial.println("1");
  blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
  Serial.println("2");
  blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
  Serial.println("3");
  blueToothSerial.print("\r\n+STNA=Bedroom\r\n"); //set the bluetooth name as "SeeedBTSlave"
  Serial.println("4");
  blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
  blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
  delay(2000); // This delay is required.
  blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
  Serial.println("The slave bluetooth is inquirable!");
  Serial.println("5");
  blueToothSerial.flush();
  while(1){
Why are you running an infinite loop inside an infinite loop?
its the same code found here
http://www.seeedstudio.com/wiki/index.php?title=Bluetooth_Shield
it worked before ... and if loop is not an infinite loop right?
i dint modify the code it is the same code given on seedstudio website... it worked before and i dont know why it stopped working....
bump
