Hi guys:
I have an application that communicates with Bluetooth between two Nano 33 BLE's. The BLE will only connect if the two circuits are reset in the right order, then the Bluetooth works just fine...as long as the radio connection remains intact. If I disconnect power from either one or take it out of range, the other one just keeps looping like nothing happened. If it is brought back into range or powered up, the Bluetooth does not reconnect and you have to reset them in a certain order again.
What I want is something more robust. I want to be able to turn on the two units, in any order, and for them to automatically connect. I also want for them to automatically reconnect if the signal or power is restored.
I thought that's what
BLEDevice peripheral = BLE.available();
if(peripheral) {...}
and
BLEDevice central = BLE.available();
if(central) {...}
were for. But they seem to just ignore when communication is disconnected. If I just had an indicator to tell me when the connection is lost, I could write the code to do everything I want.
I'm not always passing data, so I can't just use data to tell if they're connected. Isn't there a simple way to know when radio communication has failed?
Don
