BME280 only showing up in I2C scanner. - SOLVED
Hello, I'm using the bme280 on the esp82 D1 mini. My problem is not recognizing in serial monitor with the Adafruit bme280 library. When I scanner in the i2c scanner it shows up in 0x77. Which matches up in the library Adafruit_BME680.h. I used the Example sketch that comes with the library. I'm including the sketch below. Not sure what to do. Please help me to try to figure this out?
  This is a library for the BME680 gas, humidity, temperature & pressure sensor
  Designed specifically to work with the Adafruit BME680 Breakout
  ----> http://www.adafruit.com/products/3660
  These sensors use I2C or SPI to communicate, 2 or 4 pins are required
  to interface.
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing products
  from Adafruit!
  Written by Limor Fried & Kevin Townsend for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME680 bme; // I2C
//Adafruit_BME680 bme(BME_CS); // hardware SPI
//Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO,  BME_SCK);
  while (!Serial);
  Serial.println(F("BME680 test"));
  if (!bme.begin()) {
    Serial.println("Could not find a valid BME680 sensor, check wiring!");
    while (1);
  // Set up oversampling and filter initialization
  bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
  if (! bme.performReading()) {
    Serial.println("Failed to perform reading :(");
    return;
  Serial.print("Temperature = ");
  Serial.print(bme.temperature);
  Serial.println(" *C");
  Serial.print("Pressure = ");
  Serial.print(bme.pressure / 100.0);
  Serial.println(" hPa");
  Serial.print("Humidity = ");
  Serial.print(bme.humidity);
  Serial.println(" %");
  Serial.print("Gas = ");
  Serial.print(bme.gas_resistance / 1000.0);
  Serial.println(" KOhms");
  Serial.print("Approx. Altitude = ");
  Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
  Serial.println(" m");
  delay(2000);
Results:
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
V)
L⸮⸮`⸮9⸮H⸮⸮$hR⸮ BME680 test
Soft WDT reset
Exception (4):
epc1=0x402027ad epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffe50 end: 3fffffd0 offset: 0160
3fffffb0:  feefeffe 00000000 3ffee8bc 4020481c
3fffffc0:  feefeffe feefeffe 3fffdab0 40100f21
<<<stack<<<
Joseph
try explicitly setting the I2C address
 if (!bme.begin(0x77) {
@horace I did change the address that didn't work. I even jump SD0 to high to change the address for 0x77 made no difference.
just noticed you are including the BME680 header - are you sure this library works with the BME280 module?
code I used with a ESP8266 and a BME280
// BME280 sensor
// ESP8266 nodeMCU v3 GPIO5 D1 SCL GPIO4 D2 SDA
// ESP32 devkit GPIO22 SCL GPIO21 SDA
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BME280.h>
Adafruit_BME280 bme; // I2C
//Adafruit_BME280 bme(BME_CS); // hardware SPI
//Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
unsigned long delayTime;
  Serial.println(F("BME280 test"));
  bool status;
  // default settings
  // (you can also pass in a Wire library object like &Wire2)
  status = bme.begin(0x76);
  if (!status) {
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    while (1);
  Serial.println("-- Default Test --");
  delayTime = 1000;
  printValues();
  delay(delayTime);
void printValues() {
  Serial.print(bme.readTemperature());
  // Convert temperature to Fahrenheit
  /*Serial.print("Temperature = ");
  Serial.print(1.8 * bme.readTemperature() + 32);
  Serial.println(" *F");*/
  Serial.print(bme.readPressure() / 100.0F);
  Serial.print(bme.readHumidity());
sample output
Temperature = 20.10 *C
Pressure = 1031.72 hPa
Approx. Altitude = -152.69 m
Humidity = 42.14 %
Temperature = 20.11 *C
Pressure = 1031.73 hPa
Humidity = 42.13 %
@horace Oh man I'm so sorry. You are right that worked. Thank you verty much. I thought I was using the 280 code and didn't realize it was the 680.
