BMP085 not compiling for 8266
Hello,
As the Topic suggests, I'm trying to compile BMP085 using adafruit's own library and sample program only to get the following errors on NodeMCU platform: (funny thing is that it used to work many years ago and I'm using IDE 2.3.6)
c:/users/nadir/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\nadir\AppData\Local\arduino\sketches\D5C5863019F8B34D6E4451AB020E5AAE\libraries\Adafruit_BMP085_Library\Adafruit_BMP085.cpp.o:(.text._ZN15Adafruit_BMP0855read8Eh+0x0): undefined reference to `_ZN18Adafruit_I2CDevice15write_then_readEPKhjPhjb'
c:/users/nadir/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\nadir\AppData\Local\arduino\sketches\D5C5863019F8B34D6E4451AB020E5AAE\libraries\Adafruit_BMP085_Library\Adafruit_BMP085.cpp.o: in function `_ZN15Adafruit_BMP0855read8Eh':
c:\Users\nadir\Documents\Arduino\libraries\Adafruit_BMP085_Library/Adafruit_BMP085.cpp:288: undefined reference to `_ZN18Adafruit_I2CDevice15write_then_readEPKhjPhjb'
c:/users/nadir/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\nadir\AppData\Local\arduino\sketches\D5C5863019F8B34D6E4451AB020E5AAE\libraries\Adafruit_BMP085_Library\Adafruit_BMP085.cpp.o: in function `_ZN15Adafruit_BMP0856read16Eh':
c:\Users\nadir\Documents\Arduino\libraries\Adafruit_BMP085_Library/Adafruit_BMP085.cpp:300: undefined reference to `_ZN18Adafruit_I2CDevice15write_then_readEPKhjPhjb'
c:/users/nadir/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: c:\Users\nadir\Documents\Arduino\libraries\Adafruit_BMP085_Library/Adafruit_BMP085.cpp:306: undefined reference to `_ZN18Adafruit_I2CDeviceC1EhP7TwoWire'
c:/users/nadir/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\nadir\AppData\Local\arduino\sketches\D5C5863019F8B34D6E4451AB020E5AAE\libraries\Adafruit_BMP085_Library\Adafruit_BMP085.cpp.o:(.text._ZN15Adafruit_BMP0855beginEhP7TwoWire+0x4): undefined reference to `_ZN18Adafruit_I2CDevice5beginEb'
c:/users/nadir/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\nadir\AppData\Local\arduino\sketches\D5C5863019F8B34D6E4451AB020E5AAE\libraries\Adafruit_BMP085_Library\Adafruit_BMP085.cpp.o:(.text._ZN15Adafruit_BMP0855beginEhP7TwoWire+0x3f): undefined reference to `_ZN18Adafruit_I2CDeviceC1EhP7TwoWire'
c:/users/nadir/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\nadir\AppData\Local\arduino\sketches\D5C5863019F8B34D6E4451AB020E5AAE\libraries\Adafruit_BMP085_Library\Adafruit_BMP085.cpp.o: in function `_ZN15Adafruit_BMP0855beginEhP7TwoWire':
c:\Users\nadir\Documents\Arduino\libraries\Adafruit_BMP085_Library/Adafruit_BMP085.cpp:36: undefined reference to `_ZN18Adafruit_I2CDevice5beginEb'
c:/users/nadir/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: c:\Users\nadir\Documents\Arduino\libraries\Adafruit_BMP085_Library/Adafruit_BMP085.cpp:60: undefined reference to `_ZN18Adafruit_I2CDevice5writeEPKhjbS1_j'
c:/users/nadir/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\nadir\AppData\Local\arduino\sketches\D5C5863019F8B34D6E4451AB020E5AAE\libraries\Adafruit_BMP085_Library\Adafruit_BMP085.cpp.o: in function `_ZN15Adafruit_BMP0856write8Ehh':
c:\Users\nadir\Documents\Arduino\libraries\Adafruit_BMP085_Library/Adafruit_BMP085.cpp:63: undefined reference to `_ZN18Adafruit_I2CDevice5writeEPKhjbS1_j'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "Adafruit_I2CDevice.h"
  Used: C:\Users\nadir\Documents\Arduino\libraries\Adafruit_I2CDevice
  Not used: C:\Users\nadir\Documents\Arduino\libraries\Adafruit_BusIO
exit status 1
Compilation error: exit status 1
The sample code is as follows:
#include <Adafruit_BMP085.h>
  This is an example for the BMP085 Barometric Pressure & Temp Sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> https://www.adafruit.com/products/391
  These pressure and temperature sensors use I2C to communicate, 2 pins
  are required to interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
// Connect VCC of the BMP085 sensor to 3.3V (NOT 5.0V!)
// Connect GND to Ground
// Connect SCL to i2c clock - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 5
// Connect SDA to i2c data - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 4
// EOC is not used, it signifies an end of conversion
// XCLR is a reset pin, also not used here
Adafruit_BMP085 bmp;
  if (!bmp.begin()) {
	Serial.println("Could not find a valid BMP085 sensor, check wiring!");
	while (1) {}
    Serial.print("Temperature = ");
    Serial.print(bmp.readTemperature());
    Serial.println(" *C");
    Serial.print("Pressure = ");
    Serial.print(bmp.readPressure());
    Serial.println(" Pa");
    // Calculate altitude assuming 'standard' barometric
    // pressure of 1013.25 millibar = 101325 Pascal
    Serial.print("Altitude = ");
    Serial.print(bmp.readAltitude());
    Serial.println(" meters");
    Serial.print("Pressure at sealevel (calculated) = ");
    Serial.print(bmp.readSealevelPressure());
  // you can get a more precise measurement of altitude
  // if you know the current sea level pressure which will
  // vary with weather and such. If it is 1015 millibars
  // that is equal to 101500 Pascals.
    Serial.print("Real altitude = ");
    Serial.print(bmp.readAltitude(101500));
Appreciate any ideas as this is a part of my weather station project.
I compiled your code with IDE 1.8.9 and it compiled correctly.
Library:
name=Adafruit BMP085 Library
version=1.0.0
I compiled the code with IDE 2.3.6 and Adafruit BMP085 Library version 1.0.0 with no errors.
Thanks ruilviana and a slap to Adafruit.
Cheers.
