I have this code I entered
It basically controls 3 relays and one button + bmp180
Everything works dandy... only issue is that in case the bmp180 sda or sda cables disconnect phisically, my nodemcu goes into reset loop.
I'd like to optimize it in a way that the relays keep working in case cable/module fail
Is there another way?
thx
#include <Homotica.h>
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <SimpleTimer.h>
#include <SPI.h>
#include <OneWire.h>
#include <Adafruit_BMP085.h>
Adafruit_BMP085 bmp;
//FRONT DOOR=D4 GATE=D3 GLASS DOOR = D5
#define WDOOR D4
#define GDOOR D5
#define GATE D3
const int buttonPin = D6; // The number of the Pushbutton pin
//BUTTON declarations
SimpleTimer timer;
int buttonState = 0; // Variable for reading the pushbutton status
long previousMillis = 0; // will store last time LED was updated
long interval = 5000; // interval at which to blink (milliseconds)
long currentValue;
float Dtemp;
int buttonstatedoor = 0;
WiFiClient client;
//MODIFY THESE PARAMETERS
const char* ssid = ""; //your wifi ssid
const char* password = ""; //your wifi password
WiFiServer serverbmp(80);
IPAddress ip(10,0,0,190); //your arduino IP
IPAddress gateway(10,0,0,1); //your network gateway
IPAddress subnet(255, 255, 255, 0); //your network subnet mask
unsigned int mUdpPort = 5858;
static String code = "qawsedrf";
Homotica homotica;
unsigned long lastMillis = 0;
Serial.begin(74880);
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
//D4= DOOR D5=GATE
pinMode(buttonPin, INPUT);
pinMode(WDOOR, OUTPUT);
pinMode(GATE, OUTPUT);
// digitalWrite(WDOOR, HIGH);
homotica.addUsedPinOutput(WDOOR);
homotica.addUsedPinOutput(GATE);
homotica.addUsedPinOutput(GDOOR);
homotica.attachInputFunction(myCustomInputFunction, 'M');
//homotica.setActiveLow(); //<-- only if you need it
homotica.set(mUdpPort, code);
//homotica.turnOn(WDOOR);
//homotica.turnOn(GDOOR);
homotica.turnOn(GATE);
timer.setInterval(1200L, emergencybtn);
timer.setInterval(2000L, gateoff);
timer.setInterval(1000L, exchangevars);
if (!bmp.begin()) {
Serial.println("No BMP180 / BMP085");// Crap! No Bmp180
while (1) {}
homotica.refresh();
timer.run();
int16_t myCustomInputFunction(){
//read sensors or do stuff
int16_t returnValue = 1234;
return returnValue;
//if an error has occurred - like the sensor didn't respond - you could
//refuse to return a valid value; in this case use:
//return homotica.SENSOR_ERROR;
//which will generate a negative response to the app.
//NOTE: the method does not accept negative values
void emergencybtn()
//REDBUTTON EMERGENCY (Opens door by button press in case wifi jammed)
previousMillis = millis();
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
//The button is pushed
while (buttonState == HIGH)
Serial.println(buttonState);
currentValue = millis() - previousMillis;
if (currentValue > interval) //If the button has been pressed for >inverval open it
// save the last time relays has been turned on
digitalWrite(WDOOR, HIGH); //opendoor
delay(4000); //give time to get in
digitalWrite(WDOOR, LOW); //close it
yield();
void gateoff()
// This function scans continually gate relay status and resets relay to high
buttonstatedoor = digitalRead(GATE);
if (buttonstatedoor == LOW)
Serial.println("Close DA GATE");
delay (500);
digitalWrite(GATE, HIGH);
void exchangevars(){
//Send variables to Central arduino station
float TempIN = (bmp.readTemperature());
float Pres = ((bmp.readPressure()));
WiFiClient client = serverbmp.available();
if (client) {
if (client.connected()) {
Serial.println("Sending data..");
String request = client.readStringUntil('\r'); // reads the message from the client
client.flush();
client.print(String(TempIN)); // sends variable 1
client.print(',');
client.print(String(Pres)); // sends variable 2
client.print('\r');
client.stop(); // disconnects the client
