Hi, I am using BMP180 for a project. In the code I provide initial altitude for the program to measure pressure. But when I want to get back value of altitude it returns the same value.
My question is,
Isn't it possible to measure altitude with BMP180, if it is can use please help me with the code of the program?
#include <Wire.h> //Including wire library
#include <SFE_BMP180.h> //Including BMP180 library
#define ALTITUDE 35 //Altitude where I live (change this to your altitude)
SFE_BMP180 pressure; //Creating an object
Serial.begin(9600); //Starting serial communication
Serial.println("Program started");
if (pressure.begin()) //If initialization was successful, continue
Serial.println("BMP180 init success");
else //Else, stop code forever
Serial.println("BMP180 init fail");
while (1);
char status;
double T, P, p0, altitude_; //Creating variables for temp, pressure and relative pressure
Serial.print("You provided altitude: ");
Serial.print(ALTITUDE, 0);
Serial.println(" meters");
status = pressure.startTemperature();
if (status != 0) {
delay(status);
status = pressure.getTemperature(T);
if (status != 0) {
Serial.print("Temp: ");
Serial.print(T, 1);
Serial.println(" deg C");
status = pressure.startPressure(3);
if (status != 0) {
delay(status);
status = pressure.getPressure(P, T);
if (status != 0) {
Serial.print("Pressure measurement: ");
Serial.print(P); //absolute pressure -- P
Serial.println(" hPa (Pressure measured using temperature)");
p0 = pressure.sealevel(P, ALTITUDE); //sealevel pressure -- p0
Serial.print("Relative (sea-level) pressure: ");
Serial.print(p0);
Serial.println("hPa");
altutude_= 44330 * (1 - pow((P/p0), (1/5.255)));
Serial.print("Altitude: ");
Serial.print(hundurluk);
Serial.println(" meterino");
