I've used this GPS before but now when I need it the most it stops working. When I run the demo sketch in the TinyGPSPlus lib it says in serial monitor "No GPS detected: check wiring". I dont think I did anything wrong with the wiring but I've noticed that when I do connect the tx and rx of the GPS to the arduino it stops blinking the blue light. When I flip it, it starts blinking again but it doesn't send anything in the serial monitor. I can tell its working and not the modules fault because I got u-connect and tried it on there and it showed me my location and everything. I even tried different baud rates ranging from 4800 - 115200. Here is my wiring:
GPS Arduino
SDA (pin 1) ---> SDA (A4)
GND (pin 2) ----> GND
TX (pin 3) ----> D3
RX (pin 4) ----> D4
VCC (pin 5) ----> 5v
SCL (pin 6) ----> SCL (A5)
Here is the demo sketch I used:
#include <TinyGPSPlus.h>
#include <SoftwareSerial.h>
This sample sketch demonstrates the normal use of a TinyGPSPlus (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
// The TinyGPSPlus object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
Serial.println(F("DeviceExample.ino"));
Serial.println(F("A simple demonstration of TinyGPSPlus with an attached GPS module"));
Serial.print(F("Testing TinyGPSPlus library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F("by Mikal Hart"));
// This sketch displays information every time a new sentence is correctly encoded.
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
void displayInfo()
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
Thanks for reading!
