Hi! I'm trying to make a custom board definition - it is my first time and so today has been massive trial and error, but with some progress!
I can now specify and have the IDE read the json file, and it recognises the board.txt file. The board.txt file points toward
cadalogger.build.core=MCUdude:MegaCoreX
which if I understand right from here
https://arduino.github.io/arduino-cli/0.32/platform-specification/
(most of the way down, under the header " Referencing another core, variant or tool") should allow me to reference MegaCoreX in general, but otherwise limit options that show up in the 'tools' menu as appropriate to my board.
However, on trying to compile a sketch, I get the error:
Using core 'coreX-corefiles' from platform in folder: /Users/mbm5/Library/Arduino15/packages/cadalogger/hardware/avr/0.1.0
Warning: Board cadalogger:avr:4808 doesn't define a 'build.board' preference. Auto-set to: AVR_4808
Detecting libraries used...recipe.preproc.macros pattern is missing
Error compiling for board cadalogger.
It seems I'm not properly understanding what goes in the boards.txt file. I've just adjusted for the name of my board, and reduced to those items that I would like to have appear in the menu. Clearly I've been a bit naive (for one thing, the menu items I was expecting are not appearing in the 'tools' menu in the IDE).
I'll put my current attempt at the boards.txt file below. I hope someone will be able to quickly see where my misunderstanding is!
Thanks,
Michael
cadalogger.name=cadalogger
cadalogger.upload.tool=avrdude
cadalogger.upload.maximum_data_size=6144
cadalogger.upload.speed=115200
cadalogger.bootloader.tool=avrdude
cadalogger.build.core=coreX-corefiles
cadalogger.build.board=AVR_ATmega4808
cadalogger.build.mcu=atmega4808
cadalogger.build.extra_flags={build.oscillator}
# Fuses we don't need to modify in the tools menu
cadalogger.bootloader.WDTCFG=0x00
cadalogger.bootloader.TCD0CFG=0x00
cadalogger.bootloader.SYSCFG1=0x06
cadalogger.bootloader.APPEND=0x00
cadalogger.bootloader.LOCKBIT=0xC5
# menu item in megacoreX, not here
cadalogger.pinout.32pin_standard=32 pin standard
cadalogger.pinout.32pin_standard.build.variant=32pin-standard
# EEPROM
cadalogger.menu.eeprom.keep=EEPROM retained
cadalogger.menu.eeprom.keep.bootloader.eesave_bit=1
cadalogger.menu.eeprom.erase=EEPROM not retained
cadalogger.menu.eeprom.erase.bootloader.eesave_bit=0
# Reset pin -- menu item in megacoreX but not here
cadalogger.resetpin.reset=Reset
cadalogger.resetpin.reset.bootloader.SYSCFG0=0b1100100{bootloader.eesave_bit}
# Brown out detection
cadalogger.menu.BOD.2v6=BOD 2.6V
cadalogger.menu.BOD.2v6.bootloader.BODCFG=0x54
cadalogger.menu.BOD.4v3=BOD 4.3V
cadalogger.menu.BOD.4v3.bootloader.BODCFG=0xF4
cadalogger.menu.BOD.4v0=BOD 4.0V
cadalogger.menu.BOD.4v0.bootloader.BODCFG=0xD4
cadalogger.menu.BOD.3v7=BOD 3.7V
cadalogger.menu.BOD.3v7.bootloader.BODCFG=0xB4
cadalogger.menu.BOD.3v3=BOD 3.3V
cadalogger.menu.BOD.3v3.bootloader.BODCFG=0x94
cadalogger.menu.BOD.2v9=BOD 2.9V
cadalogger.menu.BOD.2v9.bootloader.BODCFG=0x74
cadalogger.menu.BOD.2v1=BOD 2.1V
cadalogger.menu.BOD.2v1.bootloader.BODCFG=0x34
cadalogger.menu.BOD.1v8=BOD 1.8V
cadalogger.menu.BOD.1v8.bootloader.BODCFG=0x14
cadalogger.menu.BOD.disabled=BOD disabled
cadalogger.menu.BOD.disabled.bootloader.BODCFG=0x00
# Clock - menu items retained for internal clock options only
cadalogger.menu.clock.internal_16MHz=Internal 16 MHz
cadalogger.menu.clock.internal_16MHz.upload.speed=115200
cadalogger.menu.clock.internal_16MHz.bootloader.OSCCFG=0x01
cadalogger.menu.clock.internal_16MHz.build.oscillator=
cadalogger.menu.clock.internal_16MHz.build.f_cpu=16000000L
cadalogger.menu.clock.internal_4MHz=Internal 4 MHz
cadalogger.menu.clock.internal_4MHz.upload.speed=115200
cadalogger.menu.clock.internal_4MHz.bootloader.OSCCFG=0x01
cadalogger.menu.clock.internal_4MHz.build.oscillator=
cadalogger.menu.clock.internal_4MHz.build.f_cpu=4000000L
cadalogger.menu.clock.internal_1MHz=Internal 1 MHz
cadalogger.menu.clock.internal_1MHz.upload.speed=115200
cadalogger.menu.clock.internal_1MHz.bootloader.OSCCFG=0x01
cadalogger.menu.clock.internal_1MHz.build.oscillator=
cadalogger.menu.clock.internal_1MHz.build.f_cpu=1000000L
# Bootloader - subset of options from megacoreX
cadalogger.menu.bootloader.no_bootloader=No bootloader
cadalogger.menu.bootloader.no_bootloader.upload.maximum_size=49152
cadalogger.menu.bootloader.no_bootloader.upload.extra_params=
cadalogger.menu.bootloader.no_bootloader.build.text_section_start=.text=0x0
cadalogger.menu.bootloader.no_bootloader.build.export_merged_output=false
cadalogger.menu.bootloader.no_bootloader.bootloader.file=empty/empty.hex
cadalogger.menu.bootloader.no_bootloader.bootloader.BOOTEND=0x00
cadalogger.menu.bootloader.uart2_default=Optiboot (UART2 default pins)
cadalogger.menu.bootloader.uart2_default.upload.maximum_size=48640
cadalogger.menu.bootloader.uart2_default.upload.protocol=arduino
cadalogger.menu.bootloader.uart2_default.upload.port=UART2_DEF
cadalogger.menu.bootloader.uart2_default.upload.extra_params=
cadalogger.menu.bootloader.uart2_default.build.text_section_start=.text=0x200
cadalogger.menu.bootloader.uart2_default.build.export_merged_output=true
cadalogger.menu.bootloader.uart2_default.bootloader.file=optiboot/bootloaders/mega0/{upload.speed}/Optiboot_mega0_{upload.port}_{uploa>
cadalogger.menu.bootloader.uart2_default.bootloader.BOOTEND=0x02
cadalogger.menu.bootloader.uart2_default.bootloader.SYSCFG0=0b1100100{bootloader.eesave_bit}
