'boolean OK' redeclared as different kind of symbol
hi all,im still beginer ,i try to make multiple menu in oled display 0.96" in arduino uno.and my program could running well.but when i change device with esp32 this problem happen.
this is my code:
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
Adafruit_SSD1306 lcd(128, 64, &Wire, 4);
#define btnUp   7
#define btnOk   6
#define btnDown 5
#define btnBack 4
boolean statusBtnUp   = false;
boolean statusBtnOk   = false;
boolean statusBtnDown = false;
boolean statusBtnBack = false;
boolean statusAkhirBtnUp   = false;
boolean statusAkhirBtnOk   = false;
boolean statusAkhirBtnDown = false;
boolean statusAkhirBtnBack = false;
boolean UP   = false;
boolean OK   = false;
boolean DOWN = false;
boolean BACK = false;
int halaman  = 1;
int menuItem = 1;
  lcd.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  lcd.clearDisplay();
  pinMode(btnUp,   INPUT_PULLUP);
  pinMode(btnOk,   INPUT_PULLUP);
  pinMode(btnDown, INPUT_PULLUP);
  pinMode(btnBack, INPUT_PULLUP);
  tampil();
  statusBtnUp   = digitalRead(btnUp);
  statusBtnOk   = digitalRead(btnOk);
  statusBtnDown = digitalRead(btnDown);
  statusBtnBack = digitalRead(btnBack);
  saatUpDitekan();
  saatOkDitekan();
  saatDownDitekan();
  saatBackDitekan();
  //  untuk button up
  if (UP && halaman == 1) {
    UP = false;
    menuItem --;
    if (menuItem < 1)menuItem = 4;
  //untuk button down
  if (DOWN && halaman == 1) {
    DOWN = false;
    menuItem ++;
    if (menuItem > 4)menuItem = 1;
  //  untuk button ok
  if (OK) {
    OK = false;
    if (halaman == 1 && menuItem == 1) {
      halaman = 2;
    } else if (halaman == 1 && menuItem == 2) {
      halaman = 3;
    } else if (halaman == 1 && menuItem == 3) {
      halaman = 4;
    } else if (halaman == 1 && menuItem == 4) {
      halaman = 5;
  //  untuk button back
  if (BACK) {
    BACK = false;
    if (halaman == 2 || halaman == 3 || halaman == 4 || halaman == 5) {
      halaman = 1;
  Serial.println(menuItem);
  delay(100);
void saatUpDitekan() {
  if (statusBtnUp != statusAkhirBtnUp) {
    if (statusBtnUp == 0) {
      UP = true;
    delay(50);
  statusAkhirBtnUp = statusBtnUp;
void saatOkDitekan() {
  if (statusBtnOk != statusAkhirBtnOk) {
    if (statusBtnOk == 0) {
      OK = true;
    delay(50);
  statusAkhirBtnOk = statusBtnOk;
void saatDownDitekan() {
  if (statusBtnDown != statusAkhirBtnDown) {
    if (statusBtnDown == 0) {
      DOWN = true;
    delay(50);
  statusAkhirBtnDown = statusBtnDown;
void saatBackDitekan() {
  if (statusBtnBack != statusAkhirBtnBack) {
    if (statusBtnBack == 0) {
      BACK = true;
    delay(50);
  statusAkhirBtnBack = statusBtnBack;
//semua yang tampil di lcd ada di fungsi ini
void tampil() {
  if (halaman == 1) {
    lcd.clearDisplay();
    lcd.setTextSize(1);
    lcd.setTextColor(WHITE);
    lcd.setCursor(30, 0);
    lcd.print("DAFTAR MENU");
    if (menuItem == 1) {
      lcd.setCursor(5, 17);
      lcd.print("> menuItem 1");
      lcd.print("  menuItem 1");
    if (menuItem == 2) {
      lcd.setCursor(5, 27);
      lcd.print("> menuItem 2");
      lcd.print("  menuItem 2");
    if (menuItem == 3) {
      lcd.setCursor(5, 37);
      lcd.print("> menuItem 3");
      lcd.print("  menuItem 3");
    if (menuItem == 4) {
      lcd.setCursor(5, 47);
      lcd.print("> menuItem 4");
      lcd.print("  menuItem 4");
  } else if (halaman == 2) {
    lcd.clearDisplay();
    lcd.setTextSize(2);
    lcd.setCursor(25, 25);
    lcd.print("nilai sensor gps module");
  } else if (halaman == 3) {
    lcd.clearDisplay();
    lcd.setTextSize(2);
    lcd.setCursor(10, 15);
    lcd.print("try reading sensor");
    lcd.setCursor(30, 35);
    lcd.print("nilai sensor dht22");
  } else if (halaman == 4) {
    lcd.clearDisplay();
    lcd.setTextSize(2);
    lcd.print("nilai sensor bme 280");
  } else if (halaman == 5) {
    lcd.clearDisplay();
    lcd.setTextSize(2);
    lcd.print("hal 5");
  lcd.display();
this is the problem ive shown below:
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\AppData\Local\Temp\arduino_build_41282\sketch\oledmenu_uno.ino.cpp" -o "C:\Users\ridho\AppData\Local\Temp\arduino_build_41282\sketch\oledmenu_uno.ino.cpp.o"
oledmenu_uno:24:9: error: 'boolean OK' redeclared as different kind of symbol
boolean OK = false;
In file included from C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos/freertos/FreeRTOSConfig.h:120:0,
             from C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos/freertos/FreeRTOS.h:99,
             from C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Arduino.h:32,
             from C:\Users\ridho\AppData\Local\Temp\arduino_build_41282\sketch\oledmenu_uno.ino.cpp:1:
C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32/rom/ets_sys.h:630:5: note: previous declaration 'STATUS OK'
 OK = 0,
C:\Users\ridho\Documents\Arduino\oledmenu_uno\oledmenu_uno.ino: In function 'void loop()':
oledmenu_uno:70:8: error: lvalue required as left operand of assignment
 OK = false;
C:\Users\ridho\Documents\Arduino\oledmenu_uno\oledmenu_uno.ino: In function 'void saatOkDitekan()':
oledmenu_uno:108:10: error: lvalue required as left operand of assignment
   OK = true;
Multiple libraries were found for "Adafruit_SSD1306.h"
Used: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306
Not used: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306-master
Not used: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306_Wemos_Mini_OLED
Using library Wire at version 1.0.1 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire
Using library Adafruit_SSD1306 at version 2.4.4 in folder: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306
Using library arduino_696289 at version 1.10.10 in folder: C:\Users\ridho\Documents\Arduino\libraries\arduino_696289
Using library SPI at version 1.0 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI
Using library Adafruit_BusIO at version 1.7.2 in folder: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO
exit status 1Preformatted text
and this is my code:
#include <Wire.h>
#define btnUp   7
#define btnOk   6
#define btnDown 5
#define btnBack 4
boolean UP   = false;
boolean OK   = false;
int halaman  = 1;
int menuItem = 1;
  lcd.clearDisplay();
  tampil();
  saatUpDitekan();
  saatOkDitekan();
  saatDownDitekan();
  saatBackDitekan();
  //  untuk button up
    UP = false;
    menuItem --;
  //untuk button down
    DOWN = false;
    menuItem ++;
  //  untuk button ok
  if (OK) {
    OK = false;
      halaman = 2;
      halaman = 3;
      halaman = 4;
      halaman = 5;
  if (BACK) {
    BACK = false;
      halaman = 1;
  delay(100);
      UP = true;
    delay(50);
      OK = true;
    delay(50);
      DOWN = true;
    delay(50);
      BACK = true;
    delay(50);
void tampil() {
  if (halaman == 1) {
    lcd.clearDisplay();
    lcd.setTextSize(1);
    lcd.clearDisplay();
    lcd.setTextSize(2);
    lcd.clearDisplay();
    lcd.setTextSize(2);
    lcd.clearDisplay();
    lcd.setTextSize(2);
    lcd.clearDisplay();
    lcd.setTextSize(2);
    lcd.print("hal 5");
  lcd.display();
this is the result when i try in arduino uno:
I've never understood why the "boolean" type was introduced, when "bool" already exists.
OK is already defined, I think in an enum. So you can't use it again.
Try to change it to
boolean _OK   = false;
If that solves the problem, think about alternative names for the booleans.
ive been change and this is work,and after that the problem like this happen :
'lcd' was not declared in this scope
Post code, not pictures
Post error messages, not pictures
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0.1]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0.1]
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\Documents\Arduino\libraries\arduino_696289\glcdfont.c" -o nul
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src\SPI.cpp" -o nul
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp" -o nul
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp" -o nul
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp" -o nul
Generating function prototypes...
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp" -o "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp" -o "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp.o"
C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino: In function 'void setup()':
buttonmenu_esp32:38:3: error: 'lcd' was not declared in this scope
lcd.begin(SSD1306_SWITCHCAPVCC, 0x3C);
C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino: In function 'void loop()':
buttonmenu_esp32:75:8: error: lvalue required as left operand of assignment
 OK = false;
C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino: In function 'void saatOkDitekan()':
buttonmenu_esp32:113:10: error: lvalue required as left operand of assignment
   OK = true;
C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino: In function 'void tampil()':
buttonmenu_esp32:144:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:191:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:197:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:205:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:211:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:218:3: error: 'lcd' was not declared in this scope
lcd.display();
exit status 1
Error messages do get much clearer than that.
We can't see your code
Use code tags
And auto format the code first , so that indents for { can be seen .
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ridho\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ridho\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10815 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_476536 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_326920 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ridho\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ridho\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10815 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_476536 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_326920 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino
Using board 'esp32' from platform in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\partitions.csv" copy /y "C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\partitions.csv" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\partitions.csv"
cmd /c if not exist "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\partitions.csv" copy "C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\tools\partitions\default.csv" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\partitions.csv"
    1 file(s) copied.
Detecting libraries used...
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0.1]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0.1]
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp" -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306_Wemos_Mini_OLED@1.1.2 Adafruit_SSD1306@2.4.4 Adafruit_SSD1306-master@2.4.4]
ResolveLibrary(Adafruit_SSD1306.h)
-> candidates: [Adafruit_SSD1306_Wemos_Mini_OLED@1.1.2 Adafruit_SSD1306@2.4.4 Adafruit_SSD1306-master@2.4.4]
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [arduino_696289@1.10.10]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [arduino_696289@1.10.10]
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "C:\Users\ridho\Documents\Arduino\libraries\arduino_696289\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.7.2]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit_BusIO@1.7.2]
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\Documents\Arduino\libraries\arduino_696289\Adafruit_GrayOLED.cpp" -o nul
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\Documents\Arduino\libraries\arduino_696289\Adafruit_SPITFT.cpp" -o nul
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\Documents\Arduino\libraries\arduino_696289\glcdfont.c" -o nul
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src\SPI.cpp" -o nul
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" \Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\ridho\Documents\Arduino\libraries\arduino_696289" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp" -o "C:\Users\ridho\AppData\Local\Temp\arduino_build_476536\sketch\buttonmenu_esp32.ino.cpp.o"
C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino: In function 'void setup()':
buttonmenu_esp32:38:3: error: 'lcd' was not declared in this scope
lcd.begin(SSD1306_SWITCHCAPVCC, 0x3C);
C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino: In function 'void loop()':
buttonmenu_esp32:75:8: error: lvalue required as left operand of assignment
 OK = false;
C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino: In function 'void saatOkDitekan()':
buttonmenu_esp32:113:10: error: lvalue required as left operand of assignment
   OK = true;
C:\Users\ridho\Documents\Arduino\buttonmenu_esp32\buttonmenu_esp32.ino: In function 'void tampil()':
buttonmenu_esp32:144:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:191:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:197:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:205:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:211:5: error: 'lcd' was not declared in this scope
 lcd.clearDisplay();
buttonmenu_esp32:218:3: error: 'lcd' was not declared in this scope
lcd.display();
Multiple libraries were found for "Adafruit_SSD1306.h"
Used: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306
Not used: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306_Wemos_Mini_OLED
Not used: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306-master
Using library Wire at version 1.0.1 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\Wire
Using library Adafruit_SSD1306 at version 2.4.4 in folder: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_SSD1306
Using library arduino_696289 at version 1.10.10 in folder: C:\Users\ridho\Documents\Arduino\libraries\arduino_696289
Using library SPI at version 1.0 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI
Using library Adafruit_BusIO at version 1.7.2 in folder: C:\Users\ridho\Documents\Arduino\libraries\Adafruit_BusIO
exit status 1
ive shown the coode in my problem
ive edited my problem error massage
Hi @ridhoazhar313 ,
Very strange.
I compiled your sketch from post #1 and it really gave the error
"'boolean OK' redeclared as different kind of symbol".
Replaces all "OK" with "_OK", and compiled correctly.
Looking at the image you put in post #4, the error happens on line 218, but your sketch for post #1 only has 213 lines.
What happened, did he grow up?
RV mineirin
Please do not ask to see the OP’s full sketch again, my iPad can’t take it any more !
I think I broke my scrolling thumb
Discourse really needs to see a big paste-block, and do something else with it.
(unfortunately it doesn’t know it happened until the post is posted!)
